    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      Hi, Sumaster.
      @sumaster said:
      HI tak2hata,
      Please chk this . . . .
      1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
      http://sketchucation.com/forums/viewtopic.php?t=30508
      [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
      and click APPLY ALL button . . . . .
      [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
      This is the Final Result . . . .
      another way is you can create the mark button . . .
      [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
      Sketchup File :
      [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
      THanks πŸ‘ πŸ‘
      Axis is very important for BST entity.
      So changing it as you like will not be control well by my tool.
      It is naturally phenomenon.
      Thanks.
      by TAK2HATA
      • sumasterS
        sumaster
        Oh. . . . ok . . .
        can you tell me . . . .
        when i change wall width / height its re-create base face & push-pull ?
        Thank you,
        SUmaster
        • sumasterS
          sumaster
          HI,
          CHK the Combine each tool not working . . . . .
          thanks
          Thank you,
          SUmaster
          • T
            tak2hata
            @sumaster said:
            HI,
            thanks
            I see it.
            I will correct it tonight(so means 12 hour later).
            This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
            I will add notice about never modifying inner Axis of the BST entities.
            In your case ,I think modifying the "align" to Center and bottom will almost well.
            I can not know where you modified the inner axis of BST entity.
            So there is no best answer.
            Please do not blame me.
            by TAK2HATA
            • T
              tak2hata
              Hi, I update to version1.5a in Nov 13,2012.
              Bugfix:Combine tool.
              Thanks...ZZZzzz...
              by TAK2HATA
              • sumasterS
                sumaster
                @tak2hata said:
                @sumaster said:
                HI,
                thanks
                I see it.
                Thanks . . . . πŸ‘
                OK . . . .
                yes i CHK this "align" to bottom of center radio button πŸ‘
                No no no . . . .
                Thank you,
                SUmaster
                • V
                  victor hugo
                  I updated the files to version 1.5 and when I check the version under the plugins menu it shows Version=1.4(Oct 14,2012. How do I know if it was updated?
                  Thanks.
                  • T
                    tak2hata
                    Thanks.
                    Hi,Victor.
                    It is my mistake.
                    I will correct it strongly in next update. πŸ‘
                    Thanks.
                    by TAK2HATA
                    • sumasterS
                      sumaster
                      HI,
                      Please CHK the draw by clicks tool
                      its not work in group . . . .
                      (when draw on plan)
                      BST - 2.skp
                      Thank you,
                      SUmaster
                      • T
                        tak2hata
                        Hi,All.
                        I update BTS version 1.5c in Dec.04,2012.
                        Add Showing "About this" and "About History".
                        Bug fix when Creating Walls in Group.
                        Thanks.
                        by TAK2HATA
                        • sumasterS
                          sumaster
                          now BST Tool working GOOD
                          Thanks Tak2hata . . . . . πŸ˜„ πŸ˜‰
                          Thank you,
                          SUmaster
                          • F
                            faluchdeviaro
                            Hy tak2hata I translate the lang.txt file but the plugin remains without translate.
                            How can I translate it?
                            • T
                              tak2hata
                              Happy New Year 😍
                              I update this script to v1.6 in Jan 01,2013.
                              Improve the parts of translater.
                              So Translate will work fine ,perhaps.
                              And I add new words to language file.
                              I create the support script for tranlate file.
                              This script aims at the creating the corrected language file from older,if you have already created the language file.
                              Thanks.
                              by TAK2HATA
                              • T
                                tak2hata
                                @hcltw1963 said:
                                I have found that your BST script is very helpful and potential. It's the beginning of the BIM in SKP. I think it might be useful for wood structure either, so I omit 'RC' keyword in the script. Here's the language translation of the traditional Chinese.
                                [attachment=0:3nwkabke]<!-- ia0 -->lang_zh_16.txt<!-- ia0 -->[/attachment:3nwkabke]
                                Hi,hcltw1963.
                                I'm glad to your translation! πŸ˜„
                                I add the link to here from the top of thread.
                                by TAK2HATA
                                • OxerO
                                  Oxer
                                  Hi and thanks for the plugin!!
                                  Spanish translation file.
                                  lang_es.txt
                                  There are some phrases that I can't translate for example these:
                                  I have added some lines to the end of the lang_es.txt file with the phrases without translation.
                                  • T
                                    tak2hata
                                    Hi,All.
                                    I update to v1.6a in Jan 05,2013.
                                    Add translation words to lang file.
                                    Add the menu about Athors of Translations.
                                    I add link to translations in top of thread.
                                    Thanks chon!
                                    Thanks oxer!
                                    I am very happy. πŸ˜„
                                    by TAK2HATA
                                    • H
                                      hcltw1963
                                      lang_zh_16.txt
                                      • OxerO
                                        Oxer
                                        Thanks to you!! πŸ‘
                                        • H
                                          hcltw1963
                                          Dear Tak2hata,
                                          Is it possible to generalize the script to use for another kind of construction type like wood? I thought that if the class name "RC_GIRDER","RC_BEAM","RC_WALL","RC_SLAB" substituted by "GIRDER","BEAM","WALL", and "SLAB", they will not be represented as RC construction only.
                                          So, it will be useful for different kind of construction cause materials been assigned clearly.
                                          • T
                                            tak2hata
                                            @hcltw1963 said:
                                            Dear Tak2hata,
                                            Hi,htcltw1963.
                                            It is possible.
                                            But STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,RC_GIRDER,RC_BEAM,RC_COLUMN,WOODEN_GIRDER,WOODEN_BEAM,WOODEN_COLUMN.....
                                            I think it too many class to select.
                                            "ALL" CLASS with searching word can find by "TAG" and "PROFILE".
                                            I can add the new CLASS If surely required.
                                            But it will be very hard.I must change TABLE EDITOR,too.
                                            If there is the request same otherwise, it will inquire collectively.
                                            Thanks.
                                            by TAK2HATA
