    Honeycomb for material reduction
    9 Posts 4 Posters 4.1k Views 4 Watching
    • cottyC Offline
      cotty
      Is there a plugin or a workflow to reduce material use within 3d printing like
      • inner parts of a solid as honeycomb structure (picture)
      • selective space structures
      my SketchUp gallery
        Got my little gray cells ticking over... πŸ€“
        • cottyC Offline
          cotty
          May the force be with you (and your little gray cells) 😎
          my SketchUp gallery
          • Rich O BrienR Online
            Doesn't your 3D printer software provide this?
            On mine I can dictate the internal lattice work form.
            • cottyC Offline
              cotty
              I don't have one, which one do you use?
              I have used an online print service some times and therefore I have to care about those things on my own (I think?) because I only upload a final STL- or collada-file ...
              my SketchUp gallery
              • cottyC Offline
                cotty
                TIG solved this problem with the plugin honeycomber.
                Thanks again!
                my SketchUp gallery
                  Sorry, I never replied to your query. Most printers allow you to dictate the internal structure,whether solid or lattice.
                  If your print has part that are suspended in air then the print will build an external scaffolding system to allow it to print.
                    mlSlade
                    Thanks again!
                    Too bad this only works with Pro version!
                    Will a donation get a version that works with the free version?
                    Anyone know of another alternative plugin or a (free) program that will take an skp or stl file and do internal honeycombing or equivalent material usage reduction (I want to 3D print at Shapeways and reduce my materials cost).
                    thanks
                      Unfortunately Honeycomber uses some pro-only API methods to subtract solids.
                      You could try OSCoolean Boolean http://sketchucation.com/forums/viewtopic.php?p=112055#p112055 - which works on free.
                      You will need to make a set of smaller solid shapes arranged in a 3d matrix [to form the 'holes'], ensuring that none of them stick through the surface of the original or leave a very thin outer shell - and then subtract those in turn from the original solid [the Outliner might help with these selections ?].
                      It's more work, but it will do it...
                      There are also some free suitable 'Shell' tools that will 'hollow-out' a solid - look for those in the Plugins Index...
