    Thea for SketchUp - Available Now!
    extensions
    39 Posts 18 Posters 6.6k Views 18 Watching
    • soloS Offline
      Just remember this is a beta, there are still features being tested and implemented like animation, GPU rendering etc, that will become available once passed alpha/beta stage.
      • soloS Offline
        QUESTION Is there an upgrade cost from the THEA I have already purchased or is this a whole new buy-the-whole-thing-all-over-again package?
        Nope, we are still using version 1, so no cost upgrade.
          what a great update. well done all involved.
          πŸ‘
          • Chris FullmerC Offline
            Oh I am genuinely excited!
            • jeff hammondJ Offline
              bravO tomaz!
              that looks really nice..
              the obligatory one-click-wonder-test went well too.. installed it, open the skp of this thing I'm working on, pushed play..
              everything went smoothly and i actually received an image too πŸ˜„
              (last time i tried thea was a couple of years ago and things weren't so smooth then πŸ˜‰ (at least on the mac side of things)
              very promising and i'll definitely be exploring this one further.
              one click wonder test after 4or5 minutes ;)
              • boofredlayB Offline
                boofredlay
                A Merry Christmas indeed.
                • david_hD Offline
                  david_h
                  So is the upgrade worth it considering the world is going to end today? I'm downloading it now just in case. . .but I dunno. . . .
                  Sure is taking a long time. Are you guys overloading the servers??? πŸ’š
                    tomasz
                    Thank you for kind comments.
                    A note for existing users of Thea Studio 64bit version. To use 'Thea for SketchUp' you also have to install the 32bit version of the Studio.
                    • david_hD Offline
                      david_h
                      So I will go ahead and answer my own question. . .
                      Pretty Darn worth it. and I stink at this. . .so in the hands of you wizards---pure magic.
                      • ATLAStudioA Offline
                        ATLAStudio
                        Installed this afternoon and went through tutorial videos, quite excited to try out proxies as been v-raying for ages. Material editor is nice to use. For pic below I just imported the model, swung camera about, tweaked a couple materials and hit go, pretty impressed with result. Would like to know how to reduce noise if there's any experts reading! interior001.png
                        http://www.atlas-studio.co.uk
                        • N Offline
                          notareal
                          Not sure how materials and scene is set, but I do get a impression that most light comes from the Sun trough a glossy based glass (a real glass that creates caustics) curtain wall.
                          Some "tricks":
                          • Thin Film based glass (architectural glass) will speed up convergence a lot.
                          • TR2 will render most challenging light paths and materials (naturally with cost of render time)
                          • Super-Sapling set to "High" with TR1/TR2 helps to reduce noise
                          • Use some fill light (a emitter that is not visible to the camera) to boost convergence, if most of the light comes trough glossy based glass.
                            Note: light components and mesh emitters intersecting nearby mesh may cause noise as well as emitters that has really dense polygon mesh. Make sure that pure white and black are not used, keep diffuse colors in 6-96% range.
                          • pbacotP Offline
                            Similar here for the Mac! Some good rendering right off.
                            But no joy with materials. Soon as I go to material editor SU hangs, and no material.
                            • N Offline
                              notareal
                              Please, if issues are find, report those at related topic for all technical questions about Thea for SketchUp. There probably are some unfortunate bugs here and there, even as Thea for SketchUp is tested by our internal beta test team.
                              • soloS Offline
                                Playing with Thea4SU
                                • pbacotP Offline
                                  Thanks. As it is Beta, I expect to help by reporting issues I have. I registered and activated the account at Thea, logged in, but can't post.
                                    tomasz
                                    SketchUp sub-forum is divided into three sections: Versions & Resources, How do I...?, Bug Reports. You have to select a section first.
                                      pepa
                                      Hi nice render, everything works really fast, I tried insert my own proxy. I wanted save the custom model from thea studio, but I cant find a mod.thea format which is needed for inserting the proxy inside SU. So question is if is it possible insert own proxy into SU..?
                                      http://jsvizualizace.daportfolio.com/
                                      • FrederikF Offline
                                        Frederik
                                        Yes, of course it's possible... πŸ˜„
                                        However, the process is a little tedious at the moment, but a new process will be worked on...
                                        Once you get used to the guide below it really isn't that difficult... πŸ˜‰
                                        The proxy system is primary thought of to be used, when having a very high poly model/component, which can be difficult - if not even impossible - to work with inside SU... (I.e. high poly tree models (eg. Xfrog models) and alike)
                                        The steps are:
                                        1.) Open/import the model you want to use, in the Thea Render Studio.
                                        2.) Adjust all materials making it "render ready".
                                        3.) Group all parts of the model.
                                        4.) Make sure the gizmo of the group is adjusted so it aligns with the X, Y and Z point.
                                        (Use the parallel view in Thea, which makes it much easier to set...)
                                        5.) Click the Model tab and either right-click the part you want to make to a .mod.thea file and select "Automation > Build Preview" or click the "Build All Previews" icon.
                                        6.) In the Thea Browser panel, click the "+" (read: plus sign) and select the "/Models" option from the menu.
                                        By Default Thea4SU will open the "C:\ProgramData\Thea Render\Models" location, but you are able to create folders anywhere you want on your hard drive and browse for it.
                                        (personally I stick to the default location...)
                                        7.) If you want you can right-click in the Browser panel and create a new folder, making it easier for you to control the various models you're going to make.
                                        Double-click the folder where you want the .mod.thea file to be in.
                                        8.) From the Models tab, simply drag the model down to the folder in the Thea Browser panel.
                                        Voila, you're done and you can now use that model as a proxy model in SU using the Thea For SketchUp tool... πŸ˜„
                                        Cheers
                                        Kim Frederik
                                          pepa
                                          thanks for your detailed instructions. really helpful
                                            rv1974
                                            2 questions:
                                            Does this version support X64 architecture?
                                            Is there distributed rendering feature?
