    Most used plugins SU 8
    13 Posts 10 Posters 976 Views 10 Watching
      Stermo
      Hi guys I want to know what is the most used plugins from you.Just write what plugins do you have installed now and which is most usuful plugins for you.
        The more funny is for me Random Painter by Chris Fullmer! 😎
        (Here used after Contour Line by Didier Bur) β˜€
        http://www.3dsaloon.fr/images/phocagallery/pilou-babel-f5bc/thumbs/phoca_thumb_l_grebble.jpg
        • Chris FullmerC Offline
          Frency, that's abuse of a perfectly good plugin! hehe πŸ˜„
            Stermo
            This is my most used plugins
            Selection Toys
            Joint Push Pull
            Subdivide and smooth
            FredoScale
            BezierSpline
            I just try to help someone who want to know which plugin to try and learn
              MartinK
              My TOP 6 are:
              1. Mirror
              2. Purge
              3. Cleanup
              4. Joint Push Pull
              5. Round Corner
              6. Selection Toys
              • F Offline
                faemow82
                I was just going to start a thread like this as I am a beginner and would like to know what the experts use on a daily basis.
                I don't really have a "top", but here are the plugins I use and work properly.
                Soap, Skin and Bubble
                Move to Origin
                Artisan
                Advanced Camera
                  Vertex Tools
                  TGI3D
                  Artisan
                  SketchUV
                  KeyFrame Animation
                  Mirror
                  QuadFace
                  Save to DropBox/Google Drive
                  FredoTools
                    Trogluddite
                    Without knowing what you want to model (or the the other folks who posted), it's hard to know how useful such a list will be - it depends so much on the style of modelling and final application. Also, "most used" is not always the same as "most useful" - a plugin that only gets used once a year can be "essential" if it saves several hours of manual modelling on a particularly urgent job.
                    Pretty much all those listed so far are installed here, but here's a handful of my essentials not yet mentioned (used for designing mechanical parts for manufacture)
                    Export face to SVG - saves me loads of dwg/dxf 'cleanup' time when exporting CAD for our laser cutting machine.
                    Pen Tools+ - very handy for directly drawing construction lines and points.
                    Hatch Faces - great for making hatched cross section drawings.
                    Joint Push Pull - instant "thickness" for curved parts.
                    Curvizard - for gluing lines into 'one-click-select' curves.
                    • mitcorbM Offline
                      mitcorb
                      Not yet mentioned here is Weld. I would say one of the oldest and most fundamental for me. And Recurve, a similar and more advanced tool.
                      • pbacotP Offline
                        the lists could be misleading to some.
                        There are utility plugins that may actually be most-used, and are a great boon (default layer geometry, CleanUp, remove lonely vertices, recurve, start frontface), but then there are major tools like FredoScale, Artisan, Extrusion Tools, Tru-Paint. Vertex Tools. And it depends on if you are texturing a house or sculpting a mermaid what you are apt to "most" use on a given day. Somewhere between are joint-push-pull (JPP), follow-me and keep (FMAK), Shape bender etc.
                        Good to see some lists though... Mirror--I never use it, I'm a fool.
                          Stermo
                          That is true And it will be good if everyone who post your most used plugins also share which plugins they use for a specific kind of modeling, because people like me who are beginning to learn new techniques will know which plugins to find and install and learn how to work and how to combine two or three plugins
                          • jeff hammondJ Offline
                            most used? i probably use these ones in every single drawing session:
                            3pt arc (didier)
                            3pt rectangle (google)
                            recurve (diggsy)
                            bezier (fredo)
                            mirror (TIG)
                              My little list of indispensables πŸ˜‰
