    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 477.3k Views 92 Watching
      That's looking mighty nice! And mighty heavy. Got a pure wireframe screenshot?
      I'm curious to how you worked this. How did you combine the mesh from Mesh from Heighmap into this sofa?
      • panixiaP Offline
        panixia
        in a pure grey hdr + infinte plane it renders quite fast in vray, few minutes with mediun settings at 2000x1666.. i will try it in a fully lihtened and reflective context to see what appens, i think.
        feel free to use this model for anything you like. (maibe doing a rendering of your granny house.. duh) πŸ˜„
        edit - the model is slightly more than 4mb and i have never create an account or uploaded something in sketchup wharehouse, so you can download the model from here:
        http://www.2shared.com/file/gZ9Jkupc/GRANNYS_SOFA.html
        hope it work, let me know..
          That's a nice sample model for me to use when testing Vertex Tools performance. Lots of vertices. And Soft-Selection rainbow looks pretty. πŸ˜„
          Mind if I show it off as a user example for Vertex Tools?
          • panixiaP Offline
            panixia
            mind? what? i would be relly proud man! 😲
              Sweet! πŸ˜„
              If you make more of these I'd love to see some work in progress that display the steps and actions. It'd be really nice to show this on the Vertex Tools site and G+ galleries.
              • panixiaP Offline
                panixia
                i will surely do it, i don't know exactly, but in the next days i think.. they should be part of an house rebuilt were they want to preserve the granny's sofa and harmachairs πŸ˜’
                the actual render should be done after christmas as far as iknow, but in the meanwhile i'm studing this monster furniture in the spare time.. you never know..
                  I see you are thrilled about his. πŸ˜†
                  • panixiaP Offline
                    panixia
                    any good reference about green velvet and gold painted wood vismat?? never tried to fake that.. πŸ˜•
                      Good painted wood - would you even see any wood grain in that? Isn't it typically a thick gold paint coating that completely covers the surface?
                      Think there is some velvet vismat in the Chaosgroup download section.
                      • panixiaP Offline
                        panixia
                        no there is no velvet vismat on their site.. usually i don't care about and rather prefer to start from scrach any new material and when i like it i save it so i'm building my own library. tried some material downloaded here and there, but most of the time i don't like them so much.
                        anyway i think the most tricky part about velvet is reflection. i found somewhere in yafaray site that velvet IOR should be set to 0.751002. so i will try this because i used a lot hgher ior and tried keeping the glossiness way low in both hilit and reflect. so i suspect the key maybe the filter? some pale green instead of default white??
                        according to the paint that's it, you can't see the wood. but anyway it should be different than pure gold metal. i tried a gold material with tex stucco in bump and reflect and the result is what you can see in the image, so it's quite crappy.
                        anyway i'll stop discuss this here cause some moderators around could ban me being completely off topic.. πŸ˜„
                          I had a very quick look at the materials. I'm not 100% sure how. But I'd try with a very glossy material. And reduce the Perpendicular value of the Frensel reflection to not be 100%. ... Not sure how the result will be - but I'd start there.
                          What about just a normal Noise map in the bump? A soft bump that will make the surface appear to be more uneven.
                          meh!
                            Made a quick little test.
                            I turned the bump map intensity way down - using a Noise map with a very small size.
                            For reflection I used a very glossy fresnel map, with very low Perpendicular value (15).
                            Played a little with anistrophy - but didn't seem to do a whole lots.
                            Bumps are still too strong and the reflection is still not right. Needs something in the environment to reflect.
                              The cushions need cheek marks. And there should be cat hair all over it πŸ˜„
                                Can you get fur-ball models at the Warehouse?
                                  Probably. Look in the feline section.
                                    Error 404 (Not Found)!!1
                                    (sketchup.google.com)
                                    • panixiaP Offline
                                      panixia
                                      this is better than mine already, but i feel the gold paint still looks a bit metallic, however i 100% agree, enviroment is needed. I didn't use noise because i don't use it from ages and i don't remember how to control the dimension of the noise itself.. 😳
                                      I think you are close there with the velvet.. mine looks more like a "loden.vismat" πŸ˜†
                                      i think when i rework this i can start a specific topic in vray section (or maybe wip?)
                                        Yea, the paint should be somewhat more matt.
                                        The Noise size is set by:
                                        It'd be nice with a thread for experimenting with these materials. Give me a nudge when you've done the model.
                                          • boofredlayB Offline
                                            boofredlay
                                            Finally got me a copy of Vertex Tools and I am quite impressed.
                                            One question. I am trying to turn on the "Select Only Visible" option and am not having luck. I click on it in the context menu or in the tools menu and it won't "turn on". I can click on the example image multiple times and each time I open the context menu I get what you see, not checked.
                                            Thanks.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 33
                                            • 34
                                            • 16 / 34
