    Outer supports for array of steps
    15 Posts 7 Posters 742 Views 7 Watching
    • C
      cattz
      Thank you. I realised about editing componants after I posted.
      http://www.longshots.co.uk/pics/treads.jpg
      Reality is only how the mind perceives it to be.
        That's a looooong staircase. ๐Ÿ˜ฒ
        For a stair's 'structure' it's normal to have 'stringers' - i.e. steel-beams running along the stair's sides to support the ends of the treads; or perhaps a beam, or beams, located below the flight to support it.
        These beams in turn are supported off adjacent cross-beams, walls or have columns/post to support them down to the ground/foundations.
        Incidentally, there are building-codes and safety-regulations that apply to all stairs - depending on their 'usage' - there should be horizontal 'landings' every so often - probably 12 to 16 steps. Also a long staircase should change direction after about 36 steps by at least 30 degrees in plan...
        A step's rise and its tread-going are also predicated...
        • C
          cattz
          Yes it's for the outside of an aircraft hanger.
          I'm only just trying different things out in GSU - not trying to comply with building regs. ๐Ÿ˜† but appreciate your input. Thank you.
            Even on large structures like Hangars and Gas-holders the stairs must be safe to use...
            Having hundreds of steps is a single line, without any landings would never get built, because someone will trip and fall and die... it'd also be extremely tiring to use, let alone frightening ๐Ÿ˜ฎ
            • massimoM
              massimo Moderator
              Here in Italy is max 14 steps before a landing.
                In the UK it's 12 in 'public building' and 16 inside houses and all other areas that are only accessed by able-bodied people - e.g. plant-rooms, hangar-roofs etc.
                  No matter how many steps are allowed, it isn't GSU anymore and hasn't been since the summer. ๐Ÿ˜‰
                  • C
                    cattz
                    What is it now then?
                    Trimble sketchup - is that right?
                      Yes.
                      But you can just call it SketchUp. ๐Ÿ˜‰
                      • GaieusG
                        @tig said:
                        ...there should be horizontal 'landings' every so often... Also a long staircase should change direction after about 36 steps by at least 30 degrees in plan...
                        Something like this?
                        • Bob JamesB
                          Bob James
                          ๐Ÿคฃ
                          • GaieusG
                            What??? ๐Ÿ˜•
                            Joking aside... Some architects would deserve living in the buildings they design. We have a certain one with quite a bit of fame here (all national awards they can get, professor of architecture at the university and such) and I know of a two storey house he designed where he forgot to add a staircase inside the house. Now imagine going upstairs every evening on the outside staircase in winter. ๐Ÿ˜’
                            (Worst thing is that the design and plan got the building permit)
