    Texture export problem
    17 Posts 3 Posters 1.1k Views 3 Watching
    • iichiversiiI Offline
      iichiversii
      @rich o brien said:
      One mesh?
      No groups?
      Normals ok?
      No back faces textures?
      Any materials assigned to groups and not mesh?
      No Groups, just 1 componant, no backface textures and normals are πŸ‘
      What i must of done was changed the scale via the green pin when texturing 7 surfaces, this wasn't intentional but i have no idea which surfaces these textures are assigned to, is there a way to find out? maybe a plugin that shades unique textures as different colours, maybe πŸ˜•
      Bring on the Rain...
        404 Not Found
        (sketchucation.com)
        Did you look at this?
          iichiversii
          @rich o brien said:
          404 Not Found
          (sketchucation.com)
          Nope, but will check it out first thing in the morning Rich, cheers for that, ill let ya know if this can solve my problem πŸ‘
            iichiversii
            Unfortunately this doesn't help 😞
              Wing me the file....if you can
                iichiversii
                Im gonna give this a few tests and if i end up with the same problem ill dropbox it to you πŸ‘
                  Aerilius
                  This should select all faces that SketchUp would export as unique textures:
                  FindProjectiveTextures.rb
                    Aerilius
                    SketchUp's exporter doesn't support texture distortion with all four pins changed (ie. that the pins don't form a parallelogram). You would have to reset the distortion on these faces.
                    Oh, and if a texture pin is only by a very little amount off (unintentional), maybe this code snippet could do an automatic fix: http://sketchucation.com/forums/viewtopic.php?f=180&t=45539&p=407003 [on your own risk, requires triangulated geometry, paste in Ruby Console, select surface and start it with realign_uvs]
                      iichiversii
                      Thanks Aerilius, this may help πŸ˜„
                        iichiversii
                        @Aerilius, i installed the plugin but cant find it in any menu, where can i find it and how do i use it?
                          Adds menu item "Select textures that export as unique" to Plugins menu
                            iichiversii
                            Thanks Rich πŸ‘
                              iichiversii
                              Fantastic, this is exactly what i was looking for, did the trick, thanks to you both, a whole day banging my head off the wall for nothing thanks again lads πŸ‘
