    Texture export problem
    17 Posts 3 Posters 1.1k Views 3 Watching
    • iichiversiiI Offline
      iichiversii
      I have textured a detailed model with over 2000 faces and when i export the model it exports 7 more textures than used, in many occasions i would adjust the the texture but i normally wouldnt adjust the texture scale but obviously i must to because these extra texture export, is there a way in sketchup to highlight which surfaces have a unique texture so i can find where these textures are added to the model instead of re-texturing the entire model again.
      Bring on the Rain...
        Export format?
        N-Gons present?
        I've a Color-N-gons script in the plugins forum
          iichiversii
          @rich o brien said:
          Export format?
          N-Gons present?
          No N-Gons present, i have exported as a dae and obj and im receiving the same textures on export, when it should be 1 texture im getting 7 on export
            One mesh?
            No groups?
            Normals ok?
            No back faces textures?
            Any materials assigned to groups and not mesh?
              iichiversii
              @rich o brien said:
              One mesh?
              No groups?
              Normals ok?
              No Groups, just 1 componant, no backface textures and normals are πŸ‘
              What i must of done was changed the scale via the green pin when texturing 7 surfaces, this wasn't intentional but i have no idea which surfaces these textures are assigned to, is there a way to find out? maybe a plugin that shades unique textures as different colours, maybe πŸ˜•
                404 Not Found
                (sketchucation.com)
                Did you look at this?
                  iichiversii
                  @rich o brien said:
                  404 Not Found
                  (sketchucation.com)
                  Nope, but will check it out first thing in the morning Rich, cheers for that, ill let ya know if this can solve my problem πŸ‘
                    iichiversii
                    Unfortunately this doesn't help 😞
                      Wing me the file....if you can
                        iichiversii
                        Im gonna give this a few tests and if i end up with the same problem ill dropbox it to you πŸ‘
                          Aerilius
                          This should select all faces that SketchUp would export as unique textures:
                          FindProjectiveTextures.rb
                            Aerilius
                            SketchUp's exporter doesn't support texture distortion with all four pins changed (ie. that the pins don't form a parallelogram). You would have to reset the distortion on these faces.
                            Oh, and if a texture pin is only by a very little amount off (unintentional), maybe this code snippet could do an automatic fix: http://sketchucation.com/forums/viewtopic.php?f=180&t=45539&p=407003 [on your own risk, requires triangulated geometry, paste in Ruby Console, select surface and start it with realign_uvs]
                              iichiversii
                              Thanks Aerilius, this may help πŸ˜„
                                iichiversii
                                @Aerilius, i installed the plugin but cant find it in any menu, where can i find it and how do i use it?
                                  Adds menu item "Select textures that export as unique" to Plugins menu
                                    iichiversii
                                    Thanks Rich πŸ‘
                                      iichiversii
                                      Fantastic, this is exactly what i was looking for, did the trick, thanks to you both, a whole day banging my head off the wall for nothing thanks again lads πŸ‘
