    Texture export problem
    17 Posts 3 Posters 954 Views 3 Watching
    • I Offline
      iichiversii
      @rich o brien said:
      Export format?
      N-Gons present?
      I've a Color-N-gons script in the plugins forum
      No N-Gons present, i have exported as a dae and obj and im receiving the same textures on export, when it should be 1 texture im getting 7 on export
      Bring on the Rain...
        One mesh?
        No groups?
        Normals ok?
        No back faces textures?
        Any materials assigned to groups and not mesh?
        • I Offline
          iichiversii
          @rich o brien said:
          One mesh?
          No groups?
          Normals ok?
          No Groups, just 1 componant, no backface textures and normals are πŸ‘
          What i must of done was changed the scale via the green pin when texturing 7 surfaces, this wasn't intentional but i have no idea which surfaces these textures are assigned to, is there a way to find out? maybe a plugin that shades unique textures as different colours, maybe πŸ˜•
            http://sketchucation.com/forums/viewtopic.php?t=41441
            Did you look at this?
            • I Offline
              iichiversii
              Nope, but will check it out first thing in the morning Rich, cheers for that, ill let ya know if this can solve my problem πŸ‘
              • I Offline
                iichiversii
                Unfortunately this doesn't help 😞
                  Wing me the file....if you can
                  • I Offline
                    iichiversii
                    Im gonna give this a few tests and if i end up with the same problem ill dropbox it to you πŸ‘
                      Aerilius
                      This should select all faces that SketchUp would export as unique textures:
                      FindProjectiveTextures.rb
                        Aerilius
                        SketchUp's exporter doesn't support texture distortion with all four pins changed (ie. that the pins don't form a parallelogram). You would have to reset the distortion on these faces.
                        Oh, and if a texture pin is only by a very little amount off (unintentional), maybe this code snippet could do an automatic fix: http://sketchucation.com/forums/viewtopic.php?f=180&t=45539&p=407003 [on your own risk, requires triangulated geometry, paste in Ruby Console, select surface and start it with realign_uvs]
                        • I Offline
                          iichiversii
                          Thanks Aerilius, this may help πŸ˜„
                          • I Offline
                            iichiversii
                            @Aerilius, i installed the plugin but cant find it in any menu, where can i find it and how do i use it?
                              Adds menu item "Select textures that export as unique" to Plugins menu
                              • I Offline
                                iichiversii
                                Thanks Rich πŸ‘
                                • I Offline
                                  iichiversii
                                  Fantastic, this is exactly what i was looking for, did the trick, thanks to you both, a whole day banging my head off the wall for nothing thanks again lads πŸ‘
