    Looking for rendering
    14 Posts 7 Posters 926 Views 7 Watching
    • T
      task
      Thanks for your reply. As a biggner, what do you suggest to start with, vray, maxwell etc
        I've been happy with Kerkythea which is free. YMMV.
          steved
          Hi Task, you should look at this post just a few posts down from yours in the newbie forum "Have you ever done a poll on render software" the questions you are asking is quite well covered there
          Cheers
          "If I agreed with you on that, then we would both be wrong"
          • T
            task
            could you please give me the link to download,
            regards
            task
            • massimoM
              massimo Moderator
              Here is the 32-bit version and here is the 64-bit boost version (still a release candidate). Install one depending on your system.
              Here you can find the plugin for Sketchup.
              You have to install both: the application and the plugin.
              Finally I strongly recommend to read this one before starting to play with the renderer.
                Adorno
                Notice V-Ray for SketchUp is only available in North America, Central America and the Caribbean Islands. Or you'll have to find a reseller within your region. It's also quite expensive.
                But most renders I've seen offer demos, incl. Maxwell, V-ray, LightUp, Twilight and Shaderlight.
                So try before you buy 😄
                • soloS
                  @task said:
                  hi every one.
                  i am using sketchup fro last year, now i need to render my products. you are requested to guide me which software / plugin to use which is easy to use and produce good results.
                  thanks in advance
                  Task
                  The answer is simple to say but takes effort to do.
                  Download demo/trial versions of the software you think would be best, try them and the one you enjoy the most is the right one for you.
                  Now that you enjoy using the app you will play with it more which means you will learn more, the more you learn the better you will get.
                  • T
                    task
                    i have installed that software with plugins. it is quite good. and i am happy with that. I am facing a problem yet, i could not able to import any jpeg with model through sketchup. all other model components are exporting, other then jpeg (that is already pasted in sketchup model wall). need your guidence
                    Regards
                    Tasawwar
                      Make the JPG a texture applied to a face in SketchUp. It'll export then.
                      Likely you can just explode the image and it'll become a texture applied to a surface.
                      • massimoM
                        massimo Moderator
                        Yes explode the image and try again. Another issue could be that your materials, textures or path names contain some special characters like for example ' " ö ä å. Kerkythea uses xml as file format and can't handle those kind of characters.
                          ShrockFab
                          scaled1.jpgLightUp is the answer. Great price super easy to use.
                          • T
                            task
                            Hi there,
                            i need help from sketchup. I need to past some picture on curved surface. I could past image on flat surface but unable on curved surface.
