    Looking for rendering
    14 Posts 7 Posters 549 Views 7 Watching
      task
      hi every one.
      i am using sketchup fro last year, now i need to render my products. you are requested to guide me which software / plugin to use which is easy to use and produce good results.
      thanks in advance
      Task
        Take a look around the forum. There are many discussions about renderers. I expect you'll find them to be helpful. As to which one is best for you, there's probably no one answer at least that anyone else can give you. You'll have to sort out that question for yourself. Everyone will have opinions but there's no one best choice here.
          task
          Thanks for your reply. As a biggner, what do you suggest to start with, vray, maxwell etc
            I've been happy with Kerkythea which is free. YMMV.
              steved
              Hi Task, you should look at this post just a few posts down from yours in the newbie forum "Have you ever done a poll on render software" the questions you are asking is quite well covered there
              Cheers
              "If I agreed with you on that, then we would both be wrong"
                task
                could you please give me the link to download,
                regards
                task
                • massimoM Offline
                  massimo Moderator
                  Here is the 32-bit version and here is the 64-bit boost version (still a release candidate). Install one depending on your system.
                  Here you can find the plugin for Sketchup.
                  You have to install both: the application and the plugin.
                  Finally I strongly recommend to read this one before starting to play with the renderer.
                    Adorno
                    Notice V-Ray for SketchUp is only available in North America, Central America and the Caribbean Islands. Or you'll have to find a reseller within your region. It's also quite expensive.
                    But most renders I've seen offer demos, incl. Maxwell, V-ray, LightUp, Twilight and Shaderlight.
                    So try before you buy 😄
                    • soloS Offline
                      @task said:
                      hi every one.
                      thanks in advance
                      Task
                      The answer is simple to say but takes effort to do.
                      Download demo/trial versions of the software you think would be best, try them and the one you enjoy the most is the right one for you.
                      Now that you enjoy using the app you will play with it more which means you will learn more, the more you learn the better you will get.
                        task
                        i have installed that software with plugins. it is quite good. and i am happy with that. I am facing a problem yet, i could not able to import any jpeg with model through sketchup. all other model components are exporting, other then jpeg (that is already pasted in sketchup model wall). need your guidence
                        Regards
                        Tasawwar
                          Make the JPG a texture applied to a face in SketchUp. It'll export then.
                          Likely you can just explode the image and it'll become a texture applied to a surface.
                          • massimoM Offline
                            massimo Moderator
                            Yes explode the image and try again. Another issue could be that your materials, textures or path names contain some special characters like for example ' " ö ä å. Kerkythea uses xml as file format and can't handle those kind of characters.
                              ShrockFab
                              scaled1.jpgLightUp is the answer. Great price super easy to use.
                                task
                                Hi there,
                                i need help from sketchup. I need to past some picture on curved surface. I could past image on flat surface but unable on curved surface.
