    Rounded corner plugin - need help
    29 Posts 5 Posters 2.2k Views 5 Watching
      joe depok
      hi dave,
      I am using sketch up pro 8 and my OS is lion os X.
      I made a simple cube with 100 cm wide & tall.
      I click one of the corner using rounded corner which is automatically open when I started sketchup (i am sure that there is no error message when I open it) just like the other plugin I put the plugin into my plugin folder.
      Should i need to do any setting to operate rounded corner plugin ? ... but the other plug in i install have no problem at all & I don't need to made any setting.... i did watch the video on youtube & I followed it : made a shape, click the rounded corner tool, then click the corner / line / all geometry / then click to run ... event I tried to resize the corner radius (offset radius)..... then nothing happened but crush my sketch up operation.
      really need help.
      Cheers
      Joe
        I don't quite understand what you are doing. Probably a language thing. Anyway, take a look at this quick video.
        [flash=560,315:26rugp2x]http://www.youtube.com/v/fDCdX2sBVlY?version=3&hl=en_US[/flash:26rugp2x]
        It works the same way on my Mac, too.
        Activate the tool. Set the radius as needed.
        Click on the edges to be rounded. Do you see the colored lines when you do this?
        Move the cursor off the geometry and click.
        Have you tried running it with the Ruby Console open? Do you get any messages then?
          joe depok
          Dear Dave,
          Yes.. I did the same way. the same line, the same color (red is the corner & 2 green is the rounded radius), even i tried to change the radius the green line is changed.... but when I click off the geometry only show (sand time / waiting) i tried to wait and leave it and go to get my dinner for 1 hour still the waiting cursor still there while my geometry not change.... no messages ... there is no other way but to force quit my sketchup.
          I don't quite understand of "ruby console open" can you explain ?
          Cheers
          Joe
            How many segments have you set for the rounding? In my example it's only 6.
            the Ruby Console is found under the Window menu. Select it and then try running the plugin. Do you get any messages in the console window?
              joe depok
              i try only 1 segment.... i have only a box geometry and I click the rounded corner, then I select one of the segment on my box.
              I already open the ruby console and there is nothing message there....
              i don;t know what to do.
                Are you running Mountain Lion?
                Check to see that the Plugins folder has read and write permissions set to allow.
                Post a screen shot of your Plugins folder, please.
                  joe depok
                  i am using macbook pro os Lion X 10.7.3 - it's not a mountain lion.
                  I put my plug in at : Macintosh HD / Library / application support / google sketch up 8 / sketch up / plugins
                  Note : There is no other sketch up I installed in my laptop.
                  Just for your info that other plugin I put on the same folder and all is running well.
                  By the way how can I post a screen shot (put attachment on this post) ? .....
                  cheers
                  Joe
                  • massimoM Offline
                    massimo Moderator
                    See the picture below.
                      I wonder if it's an OpenGL setting issue. Go to the SketchUp menu (to the left of File) and choose Preferences>OpenGL and change the settings for Use Hardware Acceleration and/or Use Fast Feedback.
                        If you don't had full [read/write] permissions for the 'plugins' folder and all of its contents... then although you might have managed to wedge the files/folders in there and they appear to work at least initially, there are still some potential issues: e.g. Fredo's tools [and several others] need to write log/temp files into the 'plugins' folder, and/or make special subfolders for their own use... So if the permissions are at all restrictive you can get weirdness happening...
                        If you try the tool with the Ruby Console open what error messages [if any] do you get ?
                          joe depok
                          for the openGL setting :
                          (checked) Use hardware acceleration
                          (not checked) Use maximum texture size
                          (checked) Use fast feedback
                          Here i attached the rounded corner display on my sketch up & the folder.
                          cheers
                          Joe
                            Did you check the permissions for the Plugins folder as both TIG and I suggested?
                            Make sure you have both read and write permissions.
                            Did you try changing the OpenGL settings? πŸ˜’
                              joe depok
                              really sorry but how do I do the permission ?
                                joe depok
                                this is the open GL setting
                                  Navigate to the Plugins folder. Right click on it and choose Get Info. In the lower right corner click on the lock to unlock it and then change all of the permissions to Read and Write.
                                    Twice I've told you to try changing it. Might as well skip it now, though. πŸ˜’
                                      You seem to have some of the files/subfolder that Fredo's tools make, so it's unlikely to a be permissions issue...
                                      You do have a very old version of LibFredo [37?]
                                      The current one is 47 ! Get it here...
                                      http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
                                        joe depok
                                        Hi, I am really sorry for such several days not appear since not see the next page ... sorry.
                                        So still on the topic that my plugin (round corner) is not working.
                                        Here is the steps I already did :
                                        1. I download the libfred06 (the updated one)
                                        2. I download the round corner
                                        3. I delete my old sketch up & i install the new version (sketch up pro 😎 with "red box" icon - previous
                                          icon is house & pencil
                                        4. I install all the plugin : libred06 & round corner in my plugin folder
                                          macintosh HD/library/application support/google sketchup8/ sketch up/plugins
                                        5. I do the permission for my folder to be "Read & Write" for all (system, admin & everyone)
                                        6. I did the OpenGL : Use hardware acceleration (checked)
                                          Use maximum texture size (unchecked)
                                          Use fast feedback (checked)
                                        7. I do the round corner with ruby console open (no pop up appear) -- still the same
                                          that the program is "hang" - so I force quite my sketch up program
                                        I don't know what else to do 😞 .. in the mean time I really need this round corner soooo bad... 😞
                                        please .. please please help....
                                          If Sketchup becomes 'unresponsive' ["white-out"] it doesn't mean that it has 'hung'.
                                          It can simply be processing a lot of data.
                                          Left alone for a few minutes it might well complete the operation.
                                          Try it on a very simple object to test it.
                                          Make a square with 1m sides.
                                          PushPull it into a cube that is 1m high.
                                          Select just the cube's top face/edges [double-click].
                                          Run the Round Corners tool.
                                          In the controls set the radius to 100mm and the number of sides to 6.
                                            joe depok
                                            hellooo .... after such uninstall & install .. finally I can use the round corner success .... I again follow the instruction include the "permission" for the plugin folder. thank you thank youuuu ... but 😞 ....it seems that after I update mysketchup program I found that my cursor is not pointed on the right place... for example I want to point the angle . normally I just point my cursor on it and it will snap on the angle.. but now i have to put my cursor somewhere around it to get the snap .. 😞 oh my god....
