    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 70.9k Views 19 Watching
      Myhand
      @driven said:
      but which ever you choose add .show_modal as one off you mac conditionals...
      Are you sugesting I make the WebDialog modal? I have not set it as modal as I keep it open while working in the model. I flip between the model and the dialog often while cleaning up a model.
      http://www.keepingmyhandin.com/
        driven
        modal is different on a mac. lots of reference available via search 😉
        but you'll want a conditional for mac
        if mac dlg.show_modal else show end
        then it doesn't vanish on us...
          Myhand
          OK thanks John. Will add it to the next bugfix release. Hopefully soon, if we can get the thumb problem sorted!
            driven
            Clear | Hide
            008398 Trying to load the following thumbnail files;
            008398 null/$Irr Cache_147979500.png?2
            008399 null/$Light Sprite_147980200.png?2
            008400 null/¶CorrogateShiny¶_147979050.png?2
            008401 null/¶DarkGreen¶_147977630.png?2
            008402 null/¶DarkOrange¶_147977780.png?2
            008403 null/¶White¶_147979200.png?2
            008404 null/Material1_147979350.png?2
            008404 null/Material2_147978860.png?2
            008405 null/Material3_147978680.png?2
            008406 null/Material4_147978530.png?2
            008407 null/Material5_147978380.png?2
            008408 null/Textile_Wheat_147978230.png?2
            008408 null/Vegetation_Bark_Walnut_147977440.png?2
            008409 null/Wood_Cherry_147978080.png?2
            008409 null/Wood_Deck_147977930.png?2
            008453 qx.ui.basic.Image[889-0]; Image could not be loaded; null/Vegetation_Bark_Walnut_147977440.png?2
            008453 qx.ui.basic.Image[1029-0]; Image could not be loaded; null/Vegetation_Bark_Walnut_147977440.png?2
            008453 qx.ui.basic.Image[899-0]; Image could not be loaded; null/Wood_Deck_147977930.png?2
            008454 qx.ui.basic.Image[1049-0]; Image could not be loaded; null/Wood_Deck_147977930.png?2
            008454 qx.ui.basic.Image[909-0]; Image could not be loaded; null/$Irr Cache_147979500.png?2
            008454 qx.ui.basic.Image[919-0]; Image could not be loaded; null/$Light Sprite_147980200.png?2
            008455 qx.ui.basic.Image[929-0]; Image could not be loaded; null/¶CorrogateShiny¶_147979050.png?2
            008455 qx.ui.basic.Image[939-0]; Image could not be loaded; null/¶DarkGreen¶_147977630.png?2
            008455 qx.ui.basic.Image[949-0]; Image could not be loaded; null/¶DarkOrange¶_147977780.png?2
            008455 qx.ui.basic.Image[959-0]; Image could not be loaded; null/¶White¶_147979200.png?2
            008455 qx.ui.basic.Image[969-0]; Image could not be loaded; null/Material1_147979350.png?2
            008455 qx.ui.basic.Image[979-0]; Image could not be loaded; null/Material2_147978860.png?2
            008455 qx.ui.basic.Image[989-0]; Image could not be loaded; null/Material3_147978680.png?2
            008455 qx.ui.basic.Image[999-0]; Image could not be loaded; null/Material4_147978530.png?2
            008455 qx.ui.basic.Image[1009-0]; Image could not be loaded; null/Material5_147978380.png?2
            008456 qx.ui.basic.Image[1019-0]; Image could not be loaded; null/Textile_Wheat_147978230.png?2
            008456 qx.ui.basic.Image[1039-0]; Image could not be loaded; null/Wood_Cherry_147978080.png?2
            tempPath = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T @tempDir = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance exists!!! String Time = 6.0e-06 Total Entities = 0 String Time = 0.00061 Total Entities = 37
              driven
              this does show the image even with you odd ending...
              dlg2 = UI;;WebDialog.new("it works again2", true,"img", 250, 250, 400, 150, true);
              dlg2.set_html(%q(<img src="file;////private/var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance/Vegetation_Bark_Walnut_147977440.png" alt="test image" title="my test2" >))
              dlg2.show_modal
                Myhand
                > dlg2.show_modal
                yea I am pretty sure it is not the encoding, though I will fix that once we have the path sorted. Basically the temp path is not passed to JS. This path is passed as part of the startup sequence, which does not appear to run.
                  Myhand
                  @driven said:
                  tempPath = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T @tempDir = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance exists!!! Total Entities = 0
                  Somehow the getSystemParameters method does not make it to Ruby... I have sent you a PM with another version to test if you don't mind. Probably better to take the debuging off-thread.
                    driven
                    might be a good idea to remove the spare rb files, I'll delete some posts as well, john
                      Myhand
                      @cmd said:
                      tempPath = /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T
                      @tempDir = /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T/material_maintenance
                      /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T/material_maintenance exists!!!
                      String Time = 4.0e-06
                      Total Entities = 0
                      UI => null/jean blue_173796570.png?1
                      Here is the output after a material from list is selected and List Components Containing CMD
                      I was expecting more trace statements so I have a hunch that this might have to do with my lazy loading the tempdir. This means that I have a situation where I am calling from JS to Ruby, to JS, back to Ruby and then back into JS all in one call. This works in Windows, but there might be a threading/race condition issue on the MAC.
                      I have now re-written this part of the code and also enabled tracing directly in the JavaScript side.
                      Can you please test again and send me the output (it might even just work now).
                      This time though you need to do an extra step to capture the trace in the WebDialog. Once the dialog is open and has focus, press the F7 key, this will bring up a console window which will contain client side trace. See screenshot.
                      Please send me both the JS and Ruby console output.
                        You are using .set_html()
                        This is known to be broken on recent MAC versions [Safari]...
                        http://sketchucation.com/forums/viewtopic.php?f=180&t=49338&p=443684#p443684
                        So it's time to recode that part so it becomes MAC friendly...
                          driven
                          @Tig,
                          I'm the one using .set_html on my mac, to test his image paths, because it does work on recent MAC versions, btw... Safari is only an indicator of 'next' the 'WebKit' version to be used by WebDialogs, it's always different and a step ahead.
                          I can only find one release of 'WebKit' where .set_html() fails, a 'WebKit' version sniffer would be more appropriate for a single release.
                            Myhand
                            Thanks TIG, I use my_dialog.set_file(html_path) in the plugin.
                            Do you mind waving your magic moderator wand and deleting the "to remove" posts above? 😄
                              Gone!
                                Myhand
                                @tig said:
                                Gone!
                                Thanks TIG! 👍
                                I will release an update soon. Mainly fixing the outstanding bugs on the MAC.
                                A special thanks to @driven and @cmd for helping me debug this remotely! 👍 👍
                                I have learned the following about Sketchup WebDialog on a MAC:
                                • Calls from JS to Ruby, i.e. window.location.href = "skp:xxx" are not synchronous on the MAC, nor are they buffered. In short this means that you can loose calls if they are made in quick succession. I had to create a JS side call stack/event pump
                                • you need to pre-pend the file protocol "file:///" to the start of file paths for them to load on the MAC
                                  404 Not Found
                                  (sketchucation.com)
                                    Myhand
                                    @thomthom said:
                                    404 Not Found
                                    (sketchucation.com)
                                    Ahaa, the lost manual indeed! 👍
                                    • Bob JamesB Offline
                                      Bob James
                                      I have three plugins that claim to change materials:
                                      1. Global Material Change
                                      2. Repaint
                                      3. Material Maintenance.
                                      Last night I thought I'd give all of them a try to see which is best.
                                      I had a transparent material and wanted to change it to a chain-link fence material.
                                      Global Material Change did nothing.
                                      Material Maintenance did nothing.
                                      Repaint fixed it as requested.
                                      I was really disappointed that Material Maintenance did not work. 😞
                                        Got a sample model?
                                          Myhand
                                          This could be due to the object_id bug for large models where the id's can get garbage collected. I have fixed this already and will release shortly, but a sample model would be useful or at least some info on where the material was applied to, what settings you used etc.
                                            Bob James
                                            This is the file I used
                                            Fence 2012-12-10.skp
                                            • 7 / 8
