    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 59.4k Views 19 Watching
      Looks more like an issue with SketchUp's installer feature... Can you install other plugins without problems?
        Are you trying to install this RBZ file from a location on your computer - not the Internet 😕
        Do you have read AND write access to the 'plugins' folder?
        NOT the 'user' one, BUT the main one in the HD folder tree...
        If not then you can't auto-add files like this...
          [mod=Split topic:1mb3nheb]Split of the last few posts into a separate topic: http://sketchucation.com/forums/viewtopic.php?f=180&t=49354
          Related to using object ids for retrieving object instances.[/mod:1mb3nheb]
            How about this different approach.
            Avoiding worrying about 'id' etc...
            You assemble a collection of every material display_name and name, sorted ['matnames'].
            matnames=[]; model.materials.each{|m|matnames << [m.display_name.gsub(/[/\\?%*:|"<>.,']/, ''), m.name]} matnames.sort!
            You decide on what to gsub out etc...
            You then iterate that array to make another array of those materials ['mats'].
            mats=[]; matnames.each{|a|mats << model.materials[a[1]]}
            a[1] is the material's name used to access the material reference.
            At this point each index in the two arrays' point at a display_name (as a[0]) and its matching material.
            Now make the thumbnail images.
            matthumbs=[]; mats.each_with_index{|m, i|p=File.join(tempfolderpath, i.to_s+'.png'); matthumbs << p; m.write_thumbnail(p, 128)}
            AFTER all of the assembly, you might also want to thinkabout the '<Default>' material and always have that as item 0 in each array; e.g.
            mathames=[['<Default>']]+matnames mats=[nil]+mats matthumbs=[pathToDefaultThumbnailPNGinMMsubfolder]+matthumbs
            ###I suggest that you make a standard PNG, unless you want to create one based on the real two default-materials' colors got from:
            model.rendering_options["FaceFrontColor"] model.rendering_options["FaceBackColor"]
            You can then write the PNG's [or BMP file] bits etc using those color's RGB values to match... [I think that thomthom has some snippets on that - try bitmap2mesh etc al - there's also some good stuff here https://practicingruby.com/articles/shared/oelhlibhtlkx ]
            You now have three arrays of various 'matching' things to do with the SKP's materials, using the same indexing regime...
            Now... you assemble the materials list for the dialog...
            For example, the item under the dialog's index ' **3**', has a 'name' text-string taken from the matching matnames[**3**][0], and it displays the matching thumbnail-image matthubs[**3**], and that same index then used in mats[**3**] is the actual SKP material to be used when the Ruby does the changing, swapping etc... Because the item's 'index' is a simple integer, then converting to and then from a string, is straightforward in a 'callback', or whatever you use...
            The same ideas would also apply to the 'component-definitions' - the only addition would be to separate the thumbnail images use say i.to_s+'**x**.png' for the components...
              Myhand
              @cmd said:
              @myhand said:
              Bug fix version V2.1.1 released.
              ... CMD this should fix your problem also as the trace code that had the bug in is also now removed.
              Myhand,
              Good stuff! no more errors!
              .... but I am not getting material thumbnails nor am I getting component images to display.
              Is this due to the change for mac?
              Sorry this took so long but have been in the middle of something else. Here is a debug version that will trace the file paths the Javascript code is trying to load into the ruby console. Same install procedure as before.
              Please send me the console output.
              Thumbnail debug
              http://www.keepingmyhandin.com/
                driven
                broken again value = 0.0 !!!=> fromUIHandler: parameter string = 73-0__vzrefreshMaterialstruefalsefalse Error: #<NoMethodError: private methodputs' called for "73-0":String>`
                  Myhand
                  Hi John, I suspect you have installed an older version. I have just rechecked the Material_Maintenance_thumbnail_dbg_01.rbz file (you can unzip it) and the above two puts have been commented out. You can check by looking at lines 106 and 111 in the Material_Maintenance/Material_Maintenance.rb file within the .rbz archive.
                    driven
                    I used the SU installer to overwrite the old, but probably hit 'don't trust' in the setup dialog....
                    fresh instal
                    String Time = 6.0e-06 Total Entities = 0 null/Material2_150652410.png?1 String Time = 0.012297 Total Entities = 1063 null/Material2_150652410.png?2 String Time = 0.00685
                    I can help debug the images if you stop the width of you generated content autoresizing. or just PM instructions of where it's set so I can get a hook in for Web Inspector to check the paths.
                    BTW: I and Sketchup use ./tmp/* for temp file on mac, it's so simple....
                      Myhand
                      fresh instal
                      Very interesting. I will add some more trace tonight. All the way through the call stack this time.
                      @driven said:
                      I use a JS library called qooxdoo. So I cannot just change the HTML as all the html is generated and the "container" locks it down. So I need to figure out how do it through library. I tried a few minutes to manipulate the HTML directly which did not work. Will take another look tonight.
                      @driven said:
                      Is there a reliable way to determine OS in Ruby then I can change temp directory to the above when run on a MAC?
                        driven
                        my personal favourite [from SU's WebTextures]
                        # PC Load paths will have a ':' after the drive letter. @is_mac = ($LOAD_PATH[0][1..1] != ":")
                          Myhand
                          @archtrot said:
                          Great plugin...I've needed something like this for a long time.
                          The labels on the UI are getting reduced, regardless of window size.
                          See attached image. Any idea why this is?
                          I'm SU8 on Windows 7.
                          I tried to reproduce this on one of my Windows 7 machines but the labels look fine. Which version of IE are you on?
                          Has anyone else seen this problem?
                            Myhand
                            Ok thanks, I will try this next but would still like to see where the current version goes wrong. Do you mind testing the attached and sending me all the output again please?
                            Debug version
                              driven
                              seems to work, but I don't really use materials much, things like 'components that use this' are coming in blank, but that may be my test models fault. want to post a good working sample skp...
                              tempPath = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T @tempDir = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance exists!!! String Time = 0.040138 Total Entities = 3291 UI => null/[Translucent_Glass_Blue] copy_147939200.png?1 String Time = 0.053043 Total Entities = 3291 UI => null/[Translucent_Glass_Blue] copy_148426790.png?4
                              I also did a test and the images show in SU using set html and that path, there very small though...
                              > dlg2 = UI;;WebDialog.new("it works again2", true,"img", 250, 250, 400, 150, true);
                              dlg2.set_html(%q(<img src="file;////private/var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance/Cladding_Siding_White_148435700.png" alt="test image" title="my test2" >))
                              dlg2.show_modal
                              true
                              also I should be promoting the Boolean darwin version check
                              # this is mac only!
                              if( !( RUBY_PLATFORM =~ /darwin/i) )
                                UI.messagebox("This code is for Mac only!")
                              but which ever you choose add .show_modal as one off you mac conditionals...
                              • cmdC Offline
                                cmd
                                Myhand,
                                Here is the ruby console output on launch of your latest MM_debug ruby:
                                tempPath = /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T
                                @tempDir = /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T/material_maintenance
                                /var/folders/jt/x_n2z5n109n9v_qfj562bsc87bn_mb/T/material_maintenance exists!!!
                                String Time = 4.0e-06
                                Total Entities = 0
                                UI => null/jean blue_173796570.png?1
                                Here is the output after Component option=checked + RE-LOAD Materials section
                                String Time = 0.006283
                                Total Entities = 485
                                UI => null/jean blue_173786390.png?2
                                Here is the output after a material from list is selected and List Components Containing Selected Materials is activated
                                UI => Temp dir = null
                                I hope this helps
                                CMD
                                • CMD
                                  Myhand
                                  Are you sugesting I make the WebDialog modal? I have not set it as modal as I keep it open while working in the model. I flip between the model and the dialog often while cleaning up a model.
                                    driven
                                    modal is different on a mac. lots of reference available via search 😉
                                    but you'll want a conditional for mac
                                    if mac dlg.show_modal else show end
                                    then it doesn't vanish on us...
                                      Myhand
                                      OK thanks John. Will add it to the next bugfix release. Hopefully soon, if we can get the thumb problem sorted!
                                        driven
                                        Clear | Hide
                                        008398 Trying to load the following thumbnail files;
                                        008398 null/$Irr Cache_147979500.png?2
                                        008399 null/$Light Sprite_147980200.png?2
                                        008400 null/¶CorrogateShiny¶_147979050.png?2
                                        008401 null/¶DarkGreen¶_147977630.png?2
                                        008402 null/¶DarkOrange¶_147977780.png?2
                                        008403 null/¶White¶_147979200.png?2
                                        008404 null/Material1_147979350.png?2
                                        008404 null/Material2_147978860.png?2
                                        008405 null/Material3_147978680.png?2
                                        008406 null/Material4_147978530.png?2
                                        008407 null/Material5_147978380.png?2
                                        008408 null/Textile_Wheat_147978230.png?2
                                        008408 null/Vegetation_Bark_Walnut_147977440.png?2
                                        008409 null/Wood_Cherry_147978080.png?2
                                        008409 null/Wood_Deck_147977930.png?2
                                        008453 qx.ui.basic.Image[889-0]; Image could not be loaded; null/Vegetation_Bark_Walnut_147977440.png?2
                                        008453 qx.ui.basic.Image[1029-0]; Image could not be loaded; null/Vegetation_Bark_Walnut_147977440.png?2
                                        008453 qx.ui.basic.Image[899-0]; Image could not be loaded; null/Wood_Deck_147977930.png?2
                                        008454 qx.ui.basic.Image[1049-0]; Image could not be loaded; null/Wood_Deck_147977930.png?2
                                        008454 qx.ui.basic.Image[909-0]; Image could not be loaded; null/$Irr Cache_147979500.png?2
                                        008454 qx.ui.basic.Image[919-0]; Image could not be loaded; null/$Light Sprite_147980200.png?2
                                        008455 qx.ui.basic.Image[929-0]; Image could not be loaded; null/¶CorrogateShiny¶_147979050.png?2
                                        008455 qx.ui.basic.Image[939-0]; Image could not be loaded; null/¶DarkGreen¶_147977630.png?2
                                        008455 qx.ui.basic.Image[949-0]; Image could not be loaded; null/¶DarkOrange¶_147977780.png?2
                                        008455 qx.ui.basic.Image[959-0]; Image could not be loaded; null/¶White¶_147979200.png?2
                                        008455 qx.ui.basic.Image[969-0]; Image could not be loaded; null/Material1_147979350.png?2
                                        008455 qx.ui.basic.Image[979-0]; Image could not be loaded; null/Material2_147978860.png?2
                                        008455 qx.ui.basic.Image[989-0]; Image could not be loaded; null/Material3_147978680.png?2
                                        008455 qx.ui.basic.Image[999-0]; Image could not be loaded; null/Material4_147978530.png?2
                                        008455 qx.ui.basic.Image[1009-0]; Image could not be loaded; null/Material5_147978380.png?2
                                        008456 qx.ui.basic.Image[1019-0]; Image could not be loaded; null/Textile_Wheat_147978230.png?2
                                        008456 qx.ui.basic.Image[1039-0]; Image could not be loaded; null/Wood_Cherry_147978080.png?2
                                        tempPath = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T @tempDir = /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance /var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance exists!!! String Time = 6.0e-06 Total Entities = 0 String Time = 0.00061 Total Entities = 37
                                          driven
                                          this does show the image even with you odd ending...
                                          dlg2.set_html(%q(<img src="file;////private/var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/material_maintenance/Vegetation_Bark_Walnut_147977440.png" alt="test image" title="my test2" >))
                                          dlg2.show_modal
                                            Myhand
                                            > dlg2.show_modal
                                            yea I am pretty sure it is not the encoding, though I will fix that once we have the path sorted. Basically the temp path is not passed to JS. This path is passed as part of the startup sequence, which does not appear to run.
                                            • 6 / 8
