    General Sketchup File Usage
    5 Posts 4 Posters 319 Views 4 Watching
      seasdes
      Hello all. When I am working on a Sketchup (V8 Pro)project I save a file to a different name for each day that I am working on a file. The file name has the date saved included in the name. This allows me to revert back to older files whenever designs revert back to older versions. However, I have been thinking whether this is the best method, especially when Xreffing and /or using Layout.
      What methodology do others use out there?
      Walter
      Using Sketchup Pro 2019
      • Chris FullmerC
        I don't often save copies of my models because so far I've never needed to go back to something modeled on a certain date. So I don't use this method, but what I would recommend is to have a single model you always work on with the same name, and then when you save it at the end of the day, save your model regular, then also do a "Save a Copy As" option. That will keep it so your working model stays the exact same, but every day you can save a backup copy with the date and stuff in the filename.
        • porch_unpluggedP
          porch_unplugged
          If I issue drawings from my sketchup model and I make note of them (drawing issue sheet). If I then revise the model/drawings, I save as a revision. I wouldn't necessarily save a copy at the end of each day, only if revised after drawings have been issued.
          So depending on the revisions, I might have several copies of the sketchup model in appropriate revision folders. I've just been finalising my proceedures for issuing sketchup drawings, jpeg exports, measured drawings, pdf's etc. as I'm starting to use sketchup more and more.
            Find my 'Archive' tool... this adds an item to the File menu.
            http://sketchucation.com/forums/viewtopic.php?p=149749#p149749
            It is much like the native Save_Copy_As BUT saves without a dialog, a copy of the Model is put into a folder located with the Model SKP, named 'Archives', and it appends a date/time-stamp to the end of the Model's name.
            Model.skp >>> Archives/Model[12-12-06_12-32-16].skp
            You can assign a shortcut to it, and at any time just use it to make a 'backup' or 'archive' of the Model as it is at that instant.
            With the files' date/time-stamps you can revert to any earlier version as desired...
              seasdes
              Thanks everyone for your help. I have downloaded TIG's Archiver.rb plugin and will give it a try.
              Walter
