    Arcade Panel Intersecting
    5 Posts 4 Posters 288 Views 4 Watching
      btsp
      Hi new member, first post please inform me if i have this in the right topic
      I am currently designing a arcade control console.
      I wish to use the intersecting tools to connect the to parts of the panel with a piece i will be making out of wood.
      Is there a way i can get them to intersect and delete the access.
      Below are pictures that will help to explain
      Any help would be great
      this is what i am going for, this was sketched as an idea
      these are the two pieces i wish to connect by another piece sloping down from the bigger piece to the smaller piece
      so i have tried placing a square in between the two pieces and i cant seem to get it to work.
      • cottyC Offline
        cotty
        I'm not shure if I understand the problem, but Curviloft may help...
        my SketchUp gallery
          CurviLoft, and a number of other tools, will give a swept transition between the two surfaces.
          However, if you want a 'straight intersection' or simply 'a third angular insert solution', then think of it as a 'hipped roof'...
          If the two forms do intersect nicely then just two lines added across the gap will make a connecting top face [repeat this for the bottom/sides].
          BUT it they are 'skewed' then you need to add a diagonal as well to form two triangular facets.
          You can smooth any edges afterwards...
            Are you planning to bend the wood or shape it to make a curved transition from one piece to the other? Or will you have three flat pieces joined together?
            If it is the latter, just use the line tool to connect the corners between the center section and the side piece. If upon completion of the loop you don't get a face, the piece can't be made as a flat piece.
              btsp
              thank you all for the replys. i will try your suggestions
              Thanks again
