    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
      The menu item's code
      Sketchup.active_model.active_view.animation = FloatUpAnimation.new
      runs that class, making a new animation associated with the 'view', the class calls the lone special method nextFrame(view) - which affects the view's camera when it resets it with a new_eye position and uses show_frame to update the view...
      The ' .animation' is a method applied to a view, no a 'separate' class in it's own right...
      Your own class that you pass to the view.animation can do various things inside the nextFrame(view) method - changing the camera's eye position is just one example...
      It is an awkwardly set up method/class - but it will work as the example...
      • renderizaR
        renderiza
        Thanks TIG for explaining that
        I found this topic and it solves animating an object like I wanted to but I can't make a file.rb for leading in the plugins menu. It shows me this error;
        Load Errors
        Undefined method ‘transform!’ for nil:NilClassError Loading File
        jumper.rb
        undefined method ‘transform!’ for nil: NilClass
        If anyone nows how to solve this let me know
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • Dan RathbunD
          Dan Rathbun
          @burkhard said:
          I could not find a send_action value for Display or toggle the Measurement Toolbar. Just VCB hide / unhide with Statusbar.
          The VCB ("Measurements") toolbar is special. (It's really a ControlBar.) There are many native tools, and Ruby Tools that rely upon it. Therefore it cannot be hidden like other toolbars. (This is by design.)
          However when you "toggle" it, instead of it being a hide/show toggle, it is actually a StatusBar dock/undock toggle.
          @burkhard said:
          Is there an undocumented Value?
          Yes the dock/undock toggle is Sketchup.send_action(24157), but on PC only.
          When you undock it from the StatusBar, it will take on the user's undocked setting, which is either floating (the default,) or docked to one of the Toolbar Containers (top, left, right or bottom.)
          Be aware that the location of the VCB is a user preference. I myself have it undocked from the StatusBar, and docked in the top toolbar container, 2nd row, 2nd position (following the Layer ControlBar.)
          If your plugin was to call Sketchup.send_action(24157), the VCB would be moved back onto the StatusBar (where I hate it.) So you risk upsetting users if you move the VCB somewhere the user does not want it.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            You really should have started a new topic for your issue. (This topic about errors in the online API Dictionary.)
            You need to learn to read Exception messages. The full message will have a line number in your file where the error happen.
            You are calling the instance method transform! upon an object that you think is a Sketchup::Group instance (guessing,) ... but something had gone wrong in a previous statement when you assigned the ref to the object identifier, and some other method returned nil (the singleton instance of the NilClass.)
            It is standard in Ruby to first check for success, before continuing.
            obj = ents.add_edge( pt1, p2 )
            if obj # evals true if not false or nil
              obj.transform!(tr)
            else
              UI.messagebox("Error created the Edge object!")
            • Dan RathbunD
              Dan Rathbun
              Don't worry about that now (this topic is so long and cluttered it does not matter much. And likely will be locked when the next version of the online API Dictionary is updated.)
              Move your file (and all your authored scripts,) into a "Renderiza" subdir of the Plugins dir.
              When debugging.. start Sketchup, then open the Ruby Console.
              Enter load("Renderiza/myfile.rb")
              You'll see a more complete Exception message output to the console.
              • renderizaR
                renderiza
                Thanks Dan Rathbun for teaching me how to debug inside Ruby Console.
                I forgor to post the topic link I was referring to…
                http://forums.sketchucation.com/viewtopic.php?f=180&t=25498
                I still can’t find a way to load the jumper.rb and animate the object when active but I will sonn figure it out. And I promise that for next time I will make a new topic for my issues. 👍
                • W
                  wood_galaxy
                  Hi !
                  I haven't seen if it had benn reported but :
                  In Attribute reporting Tutorial in the function :
                  def clean_for_xml(value)
                      value = value.to_s
                      value = value.gsub(/\</,'<')
                      value = value.gsub(/\>/,'>')
                      value = value.gsub(/\"/,'"')
                      value = value.gsub(/\'/,''')
                      return value
                  The last gsub make that the rest of code is a comment...
                    @wood_galaxy
                    .gsub(/\'/,''')
                    should be
                    .gsub(/\'/,"'")
                    to 'wrap' the lone ' properly...
                    I'm unclear what you put in and what you expect to come out here 😕
                    The
                    could be made as
                    value.gsub**!**(/\</,'<')
                    changing 'value' rather than reassigning it to a modified version of itself.
                    You could also 'string' the gsub changes into one line...
                    return value.to_s.gsub(/\</,'<').gsub(/\>/,'>').gsub(/\"/,'"').gsub(/\'/,"'")
                    Although it's easier to read what you are doing your way.
                    It'd probably be slightly faster - but relatively unnoticeable if only a few values are processed...
                    Can you clarify?
                    • W
                      wood_galaxy
                      I thought this topic was used to identify inconsistencies in the API doc.
                      I had just noticed that the code of the tutorial was a mistake.
                      I started in ruby but I think the line "value = value.gsub(/'/,''')" contains an error.
                      Maybe I'm wrong and that it is normal that the two following functions can be found commented.
                      So TIG you say it should be .gsub(/'/,"'"). That's what I wanted to know and get noticed.
                      Sorry for the inconvenience.
                        @wood_galaxy
                        Now I understand you. 😒
                        It is indeed a typo in that example code and it should be "'" NOT ''' - the first two '' are taken as an empty string and the third one as a start of a new string - so it's not really a 'rem' - a # or =begin...=end does that in Ruby - it's simply made all of the following code into a string until it reaches the next ' which happens to be inside a comment "can**'**t", thereafter the code resumes again, but of course at that point it's garbled and will return errors and not work...
                        This type of error is sometimes hard to find but if you are using Notepad++ it'd be obvious, as the syntax highlighting would should a massive block of 'string' text where it shouldn't be, so looking at it's start/end delimiters ['] tells us what's up and what needs fixing...
                        See the original and the correction [the rest of the code - with the exception of the unnecessary $ variable in the menu setup seems OK]Capture.PNGCapture1.PNG
                        I thought you were using some of it for your own ends and having problems...
                        There are MANY errors in the API examples - it's been discussed, and indeed the main API docs used to have a user comments section at the end of each page where we pointed out the mistakes.
                        When Google moved the content these were 'lost'.
                        SketchUp still have the text but it's the way of including it that is lacking.
                        Various ways of introducing a 'wiki-like' system have been mooted, but nothing to date...
                        • H
                          honkinberry
                          I finally tracked down a bug that popped up with 7.1, but not sure if this is the best place to note it.
                          But for Transformation.scaling, both (scale) and (pt, scale) have a bug.
                          One instead needs to use (xscale, yscale, zscale), even though all 3 parameters will be the same.
                            Yea, that's a nasty one. It used to be in the comments of the API docs, but it disappeared some time ago.
                              mptak
                              Is anyone else having a hard time accessing the Sketchup Ruby API today?
                                Yeah, the URLs got messed up when they launched the new site. Hope the fix the forwarding soon. You find working links at the bottom of sketchup.com
                                Sent from my LT25i using Tapatalk 2
                                  Aerilius
                                  For now, you can add ".php" in the address bar.
                                    • X
                                      XorUnison
                                      I would assume typos can still be posted here? If so, here's one:
                                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool#onKeyDown
                                      Tool.onKeyDown SketchUp 6.0+
                                      The onKeyDown method is called by SketchUp when the user presses a key on the keyboard. If you want to get input from the VCB, you should implement onUserText rather than this method.
                                      This method is can be used for special keys such as the Shift key
                                      • TommyKT
                                        TommyK
                                        Model Observer:
                                        onAfterComponentSaveAs(model)
                                        and
                                        onBeforeComponentSaveAs(model)
                                        The "model" parameter is actually a ComponentInstance object - the one currently selected. This is the case at least in Sketchup 2015.
                                        • T
                                          Talha222 Newcomers
                                          Yeah! really great information about documentation about API .
                                          Thank You so much i will be helpful for me
                                          • 15
                                          • 16
                                          • 17
                                          • 18
                                          • 19
                                          • 19 / 19
