    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
    • W
      wood_galaxy
      I thought this topic was used to identify inconsistencies in the API doc.
      I had just noticed that the code of the tutorial was a mistake.
      I started in ruby but I think the line "value = value.gsub(/'/,''')" contains an error.
      Maybe I'm wrong and that it is normal that the two following functions can be found commented.
      So TIG you say it should be .gsub(/'/,"'"). That's what I wanted to know and get noticed.
      Sorry for the inconvenience.
        @wood_galaxy
        Now I understand you. 😒
        It is indeed a typo in that example code and it should be "'" NOT ''' - the first two '' are taken as an empty string and the third one as a start of a new string - so it's not really a 'rem' - a # or =begin...=end does that in Ruby - it's simply made all of the following code into a string until it reaches the next ' which happens to be inside a comment "can**'**t", thereafter the code resumes again, but of course at that point it's garbled and will return errors and not work...
        This type of error is sometimes hard to find but if you are using Notepad++ it'd be obvious, as the syntax highlighting would should a massive block of 'string' text where it shouldn't be, so looking at it's start/end delimiters ['] tells us what's up and what needs fixing...
        See the original and the correction [the rest of the code - with the exception of the unnecessary $ variable in the menu setup seems OK]Capture.PNGCapture1.PNG
        I thought you were using some of it for your own ends and having problems...
        There are MANY errors in the API examples - it's been discussed, and indeed the main API docs used to have a user comments section at the end of each page where we pointed out the mistakes.
        When Google moved the content these were 'lost'.
        SketchUp still have the text but it's the way of including it that is lacking.
        Various ways of introducing a 'wiki-like' system have been mooted, but nothing to date...
        • H
          honkinberry
          I finally tracked down a bug that popped up with 7.1, but not sure if this is the best place to note it.
          But for Transformation.scaling, both (scale) and (pt, scale) have a bug.
          One instead needs to use (xscale, yscale, zscale), even though all 3 parameters will be the same.
            Yea, that's a nasty one. It used to be in the comments of the API docs, but it disappeared some time ago.
              mptak
              Is anyone else having a hard time accessing the Sketchup Ruby API today?
                Yeah, the URLs got messed up when they launched the new site. Hope the fix the forwarding soon. You find working links at the bottom of sketchup.com
                Sent from my LT25i using Tapatalk 2
                  Aerilius
                  For now, you can add ".php" in the address bar.
                    • X
                      XorUnison
                      I would assume typos can still be posted here? If so, here's one:
                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool#onKeyDown
                      Tool.onKeyDown SketchUp 6.0+
                      The onKeyDown method is called by SketchUp when the user presses a key on the keyboard. If you want to get input from the VCB, you should implement onUserText rather than this method.
                      This method is can be used for special keys such as the Shift key
                      • TommyKT
                        TommyK
                        Model Observer:
                        onAfterComponentSaveAs(model)
                        and
                        onBeforeComponentSaveAs(model)
                        The "model" parameter is actually a ComponentInstance object - the one currently selected. This is the case at least in Sketchup 2015.
                        • T
                          Talha222 Newcomers
                          Yeah! really great information about documentation about API .
                          Thank You so much i will be helpful for me
                          • 15
                          • 16
                          • 17
                          • 18
                          • 19
                          • 19 / 19
