    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 108.6k Views 35 Watching
      Jspro
      I apologize for asking such a silly question, it's pretty obvious what this plugin does but I would like to ask anyway. My pictures that I have texture my model with in sketchup for Google Earth is making my file size too large to be accepted in Google earth. Very frustrating and i am running out of ideas,i had came across this plugin, is this something that would work for me not quite sure how it works? so do I finish my model first then download the plugin? I am new to these plugins and also new to geo modeling, any help would be appreciated John
        Aerilius
        As Gully already said this plugin works be decreasing the size of texture images (or quality). It can not relieve you from the task of efficent modeling, ie. only bringing images into SketchUp that you actually need.
        You can download it whenever you want. You should run it after you finished the model (you can keep an original version and use the plugin to make a lightweight degraded version).
          Jspro
          Hello Aerialius , im a sketchup user and i have finish my model and have tried to upload my model into the sketchup preview , and am sorry to say that ( KMZ too large. In order to include them in Google Earth, we convert uploaded SketchUp files like yours to another format: KMZ. The KMZ file size that we generated from your SketchUp file is too large. We recommend simplifying your model, splitting it into two or more models or reducing the resolution of your image textures. When you're done, try re-uploading )i had even unlocked the google terrain to lower the file size to 8,808 with the same affects, so im ready to use the plugin not familiar on how to use these , would you mind helping me, do i download the ImageMagick.zip first or is this the texture resizer? how do i get it into sketchup? sorry im just new to this John
            Jspro
            lookin for help i have downloaded the ImageMagick and the resizer into my su plugin folder and im not sure what im to expect is there a supposed to be a icon? i have win 7 not quite sure if i did this properly can some help me? thanks john
              driven
              hi
              In the 'Sketchup Menu' you should have 'Plugins' with a drop down item 'Texture Resizer'.
              If it can't find 'ImageMagics' it will ask you for the 'path' once you clicked on it.
              then follow the instructions in the first post...
                Jspro
                thank you for your reply i guess i did something wrong, the texture resizer isn't there in the plugin drop down
                  Jspro
                  yes i was able to load the resizer and tried to use it on my model, it wiped away the textures replace them with white faces , it was set by default at 50%, did this twice and tried to use the limit texture size with same results. is there something that im missing? thanks john
                    krokberg
                    I thought that I try the plugin to optimize some models that ware sent to me but I ran into a problem. When trying to run "Apply" I get the following error:
                    Error #<NameError:uninitialized constant AE::Bounds.>
                    I'm using SketchUp 8.0.3117 with Texture Resizer 1.4.0 and ImageMagick 6.8.0.
                    Any clues to what the problem might be?
                      Aerilius
                      Oh, thanks, I didn't notice that when testing. It should be AE::TextureResizer::Bounds.
                      I fixed it in version 1.4.1.
                        Just tried this - wanted to ensure texture where no larger than a given size.
                        I set percentage to 100% as I wanted to keep textures smaller at their original size - then I enabled Limit texture size.
                        I got this error:
                        Error #<NoMethodError:undefined methodempty?' for nil:NilClass.>`
                          Strange that there isn't any backtrace...
                            Aerilius
                            I found the bug and fixed it. The backtraces became lost because of a rescue Exception.
                              Thanks for that. 😄
                              Though ... I broke it again... 😕
                              Error #<NoMethodError;undefined method `entities' for #<Sketchup;;ComponentInstance;0x773ec0c>.>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;253;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `call'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `new'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `process'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;188;in `options_dialog'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `call'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `show_modal'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `options_dialog'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;114;in `run'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;61
                              It appear you're trying to use ComponentInstance.entities which doesn't exist in the API - all though a few plugins add this method to the ruby classes.
                                Changed line 253 to:
                                definition.entities.each{|e| block.call(e, s*scale)}
                                Working! 😄
                                  Here's the list of material in a model where I needed to size down the textures:
                                  Before:
                                  === TEXTURE MATERIALS BY SIZE ===
                                  Material4
                                    Size; 4000x4000 pixels
                                    Size; 45.78 MB estimated uncompressed RGB
                                    Size; 61.04 MB estimated uncompressed RGBA
                                    Path; C;/Users/ktn/AppData/Local/Temp/VfSTextureCache
                                  Material13
                                  Material3
                                    Size; 2255x1782 pixels
                                    Size; 11.50 MB estimated uncompressed RGB
                                    Size; 15.33 MB estimated uncompressed RGBA
                                  Material14
                                  Material1
                                    Size; 2048x1536 pixels
                                    Size; 9.00 MB estimated uncompressed RGB
                                    Size; 12.00 MB estimated uncompressed RGBA
                                  black3
                                    Size; 2814x850 pixels
                                    Size; 6.84 MB estimated uncompressed RGB
                                    Size; 9.12 MB estimated uncompressed RGBA
                                    File; glass.psd
                                    Path; E;\LIBRARY\DIGITAL LIBRARY\MORQ LIBRARY TEXTURES\Emiliano
                                  black1
                                    File; glass.psd
                                  treverk1
                                    Size; 1500x1500 pixels
                                    Size; 6.44 MB estimated uncompressed RGB
                                    Size; 8.58 MB estimated uncompressed RGBA
                                  treverk2
                                  Material15
                                    Size; 1416x1416 pixels
                                    Size; 5.74 MB estimated uncompressed RGB
                                    Size; 7.65 MB estimated uncompressed RGBA
                                  Material8
                                    Size; 1417x1408 pixels
                                    Size; 5.71 MB estimated uncompressed RGB
                                    Size; 7.61 MB estimated uncompressed RGBA
                                    File; Material8_extractedTex7662.tif
                                  Material16
                                    File; Material16_extractedTex62.tif
                                  Material5
                                    Size; 1000x975 pixels
                                    Size; 2.79 MB estimated uncompressed RGB
                                    Size; 3.72 MB estimated uncompressed RGBA
                                  Material30
                                  Then I ran the script, got some messages:
                                  black1; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                                  black3; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                                  I assume PDS files are not supported?
                                  After:
                                  black3
                                    File; glass.psd
                                  black1
                                    File; glass.psd
                                  Material15
                                  treverk1
                                    Size; 512x512 pixels
                                    Size; 768.00 KB estimated uncompressed RGB
                                    Size; 1.00 MB estimated uncompressed RGBA
                                    Path; C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480
                                  Material4
                                  treverk2
                                  Material13
                                  Material16
                                    Size; 512x508 pixels
                                    Size; 762.00 KB estimated uncompressed RGB
                                    Size; 1016.00 KB estimated uncompressed RGBA
                                  Material8
                                  Material5
                                    Size; 512x499 pixels
                                    Size; 748.50 KB estimated uncompressed RGB
                                    Size; 998.00 KB estimated uncompressed RGBA
                                  Material30
                                  Material3
                                    Size; 512x404 pixels
                                    Size; 606.00 KB estimated uncompressed RGB
                                    Size; 808.00 KB estimated uncompressed RGBA
                                  Material14
                                  Material1
                                    Size; 512x384 pixels
                                    Size; 576.00 KB estimated uncompressed RGB
                                    Size; 768.00 KB estimated uncompressed RGBA
                                  Notice Material15 which is a PNG still is larger than 512px. Why is that? There was no messages about this file.
                                    Aerilius
                                    It seems SketchUp's texture writer does not write psd files. In that case, I'll probably force a default extension.
                                    I have no idea what could cause to skip Material15. Is it reproducible? Can you send me a file with that material and its geometry (and group nesting...).
                                      It's 8MB (after removing the two PSD textures)
                                      PM me your email address and I'll send it to you.
                                        Aerilius
                                        I think I have fixed it now.
                                        Also the texture writer can export PSDs (I have no idea why these failed), but it can't convert psd into other formats by setting a different file extension.
                                          Does the texture resizer change the format?
                                            Aerilius
                                            Here not.
                                            But the underlaying ImageMagick.rb has the option to (temporarily) change lossy formats into lossless bmp. I use that in another plugin, mainly because bmps process much faster.
                                            • 3 / 6
