    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 20.6k Views 6 Watching
      @jim said:
      Maybe they are using stderr instead of stdout? You could test on the command line:
      fc-list : family > out fc-list : family 2> err
      nada 😞
        Tried to output to file:
        fc-list : family >> ~/Desktop/fonts.txt
        Empty when run from within SketchUp, populated when run in a native console.
        Something is messed up with the messaging system! 😞
          system(fc-list : family | out) ?
          running out of permutations...
            Won't that just list fonts with "out" in them?
              The 'grep' is for pattern matching...
              The | pipes/passes the output to something else ['out'].
              What do you call the 'output' on a MAC ??
              The > puts the output into a file.
              The >> appends the output to a file.
              How do you 'pass/send' something ?
                driven
                TT
                what osx are you running.
                'shell' change to AT&T version with 10.5 , so the syntax needs to be checked
                FontBook has had lots of revisions/additions
                and those osascripts run it in the background, take miliseconds on my mac.
                the nice thing is people could set a 'SU 3D Font Collection in fontbook and you can allow them to use just those
                  10.5
                  But it works in the system console, and it works from IRB calling system command - but not from SketchUp calling system command.
                  Mine took a noticeable lag the first time I ran it, but quick the next runs. And Font Book's icon appeared in the dock.
                    driven
                    it is possible to get an output to Ruby Console using echo <dev/nul, but I need to dig thru for a working example..
                    I think I would run only once, hold the list in the plugin, but add an update function/item for people who add fonts to FontBook [very few]...
                    added to the end of the osascript should close it after use -e 'tell application "Font Book" to quit' -e 'end'
                      driven
                      I've been trying loads of different ways to get the exact font list that SU shows under 'Window' >> 'Show Fonts' all 297 on my mac, this is by far the easiest
                      macFonts=[]
                      macFonts=(`osascript -e 'tell application "Font Book" to set macFonts to name of every font family'`).split(",").uniq.each {|a| a.strip! if a.respond_to? ;strip! }.sort
                      quitFontBook=(`osascript -e 'tell application "Font Book" to quit'`)
                       if macFonts.length > 1
                       then quitFontBook
                      macFonts.length
                        I'll try it on my mac
                          driven
                          when you do...
                          For seeing if they all will work from code, I've been trying to make a '3d Font Sampler' using the 'macFont' array for both the 'string' and 'font' and the index number for 'z' position, but I keep screwing it up... could you cobble something together? or pointers...
                          another way to get the SU Font List, but not in ruby
                          tell application "Sketchup"
                          	activate
                          end tell
                          tell application "System Events"
                          	if UI elements enabled then
                          		tell process "SketchUp"
                          			click the menu "Window" of menu bar 1
                          			delay 1
                          			click menu item "Show Fonts" of menu "Window" of menu bar 1
                          			delay 1
                          			tell window "Fonts"
                          				set results to value of text field 1 of every row of table 1 of scroll area 3
                          				delay 1
                          			end tell
                          		end tell
                          				delay 1
                          				click menu item "Hide Fonts" of menu "Window" of menu bar 1
                          				delay 1
                          				return results
                          			end tell
                          		end tell
                          	else
                          		tell application "System Preferences"
                          			activate
                          			set current pane to pane "com.apple.preference.universalaccess"
                          			display dialog "UI element scripting is not enabled. Check \"Enable access for assistive devices\""
                          		end tell
                          	end if
                          end tell
                            driven
                            I managed to get a list to manually test all the fonts [via copy/paste]... they all work
                            but I can't work out how I can have each as a group, or how even how to get SU to just make them...
                            macFonts.each_with_index do |item, index|
                            puts %(Sketchup.active_model.entities.add_3d_text("#{item}" , TextAlignCenter, "#{item}" , true, false, 1.0, 0.0, #{index}, true, 0.05))
                            works as a puts which I can copy/paste in batches to make, but fails as a direct method
                            ...why???
                            • Dan RathbunD Offline
                              Dan Rathbun
                              Oh it's just a head-smackin' boo-boo.
                              The z arg takes a Numeric and the index is already a Numeric subclass ( Integer,)
                              so you do not use the #{ ... } string replacement syntax.
                              (But you don't want to stack them vertically, move them -Y so they are all in a column (see below.)
                              Another quirk about add_3d_text(), is that unlike the OEM tool, the Ruby method does not put the primitives into a group.
                              So we encourage you to create group(s) then call the method on the group's Entities collection:
                                grp = Sketchup.active_model.entities.add_group()
                                grp.entities.add_3d_text( "#{item}", TextAlignCenter, "#{item}",
                                  true, false, 1.0, 0.0, 0.0, true, 0.05 )
                                grp.name= item
                                grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-index,0)) )
                              I'm not here much anymore.
                                driven
                                cheers dan,
                                This is a one off, so dosen't really matter, but out of curiousity
                                as both 3DText and Group generation can lock up the mac, how can I split this into a batch mode, so SU makes first 12, then next 12, then next 12, etc... but still uses the original index for position.
                                Could I need to make a hash using -index%(:#{item}) then split into new arrays of hashes with max items(12), then process those, I was looking at
                                 puts %(#{item}, #{index}).to_a
                                and then
                                # use as array.chunk
                                class Array
                                  def chunk(pieces=2)
                                    len = self.length;
                                    mid = (len/pieces)
                                    chunks = []
                                    start = 0
                                    1.upto(pieces) do |i|
                                      last = start+mid
                                      last = last-1 unless len%pieces >= i
                                      chunks << self[start..last] || []
                                      start = last+1
                                    chunks
                                then
                                macFonts.chunk 12
                                then process those, but I do get lost... john
                                  driven
                                  Hi dan,
                                  It is very bad to modify base classes. (spanky spanky)
                                  it a one off, and the stand alone version was more complex for me to use...
                                  # use as standalone function
                                  def chunk_array(array, pieces=2)
                                    len = array.length;
                                    mid = (len/pieces)
                                    chunks = []
                                    start = 0
                                      last = start+mid
                                      chunks << array[start..last] || []
                                      start = last+1
                                    chunks
                                  I also do most my testing in a separate version of SU with Pluggins turned off, and often check if methods are defined already first...
                                  that works at the about the same speed as the first, not too slow, considering there are 297 fonts.
                                  what i was musing, was, is there a way to have SU make one, return true, make next, return true, then next, etc...
                                  so each operation is a single font... To see if that's actually faster or not. In theory it should be slower, but SU appears to bog down exponentially when I do them manually in sets of 6 V 12 V 18 V 24, and over 24 takes longer to run then the whole lot from either of your scripts.
                                  Another mac 3D Font oddity I have noticed:
                                  when using the native tool, I can make "ο£Ώο£Ώο£Ώ" as 3D text,
                                  which should be the apple icon although it may show as the windows icon on yours.
                                  If I use code to try and generate the 2D Text (from console or a webdialog) although I see 'it' in the input window, I get some bizarre encoded string.
                                  cheers again
                                    Dan Rathbun
                                    @driven said:
                                    what i was musing, was, is there a way to have SU make one, return true, make next, return true, then next, etc... so each operation is a single font...
                                    Set chunk = 1
                                    @driven said:
                                    ..., but SU appears to bog down exponentially when I do them manually in sets of 6 V 12 V 18 V 24, and over 24 takes longer to run then the whole lot from either of your scripts.
                                    It's a caveat of using high quality. A lot of primitives are going onto the undo stack.
                                    The higher the number of elements in the model, the slower things get.
                                    I think we already tried saving the model between operations (to clear the undo stack,) BUT tests showed it did not speed things up.
                                    @driven said:
                                    ... when using the native tool, I can make "ο£Ώο£Ώο£Ώ" as 3D text,
                                    It could be a unicode UTF16 codepoint. Ruby is UTF8.
                                    There are sometimes tricks you can do with Array.pack and String.unpack.
                                    Code-wise, try to save .rb files in "UTF8 (without BOM)" aka "ANSI as UTF8" encoding. I don't know what your Mac code editor calls it, but that's what Notepad++ does.
                                      driven
                                      I often use them as puts on mac only scripts to remind me it won't work on a PC, they show up in console returns, so that side is ok, also I can make 3D Text versions with the native tool (which I thought was based on Todd's 3D TextTool ruby)
                                      WebDialogs are UTF8 as well and they show up htere in most fonts [some don't have the charset]
                                      I looked into .encode to see if I could add a conditional to make one from code, i'll look into .pack... cheers
                                      everything 'ruby' on the mac is "UTF8 (without BOM)" with unix line endings, even 'pasteBoard', 'Terminal' and 'Applescript editor' are since OSX 10.5.
                                      It's only some downloaded rubies that need changing, although if it's just line endings any will work in SU.
                                        Dan Rathbun
                                        @dan rathbun said:
                                        Set chunk = 1
                                        I really meant, set:
                                        chunksize = 1
                                          Dan Rathbun
                                          This should do the job:
                                          chunksize = 12
                                          chunk = 1
                                          limit = macFonts.length
                                          model = Sketchup.active_model
                                          fsize = 1.0
                                          linespacing = 1.2
                                          bold = true
                                          italic = false
                                          thick = 0.05
                                          filled = true
                                          quality = 0.0
                                          i = 0
                                          while i < limit
                                            begin
                                              model.start_operation("3D Fontnames (#{chunk})")
                                                chunksize.times do |n|
                                                  break if i == limit
                                                  item = macFonts[i]
                                                  grp = model.entities.add_group()
                                                    bold, italic, fsize, quality, 0.0, filled, thick )
                                                  grp.name= item
                                                  grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-(i*linespacing),0)) )
                                                  i += 1
                                                end # chunk
                                              model.commit_operation()
                                            rescue Exception => e
                                              puts("\n*** macFonts group Error! ***")
                                              puts("  i = #{i}")
                                              puts("  chunk = #{chunk}")
                                              puts("  font = #{macFonts[i]}\n")
                                              model.abort_operation()
                                              puts("Error #<#{e.class.name}; #{e.message}>")
                                              puts(e.backtrace) if $VERBOSE
                                              raise
                                            chunk += 1
                                          end # while
                                          EDIT: Added a few Exception messages, and option vars before iteration.
                                          EDIT(2): Added linespacing var.
                                            Dan Rathbun
                                            EDIT(2) previous code post: Added linespacing var.
                                            • 2 / 6
