    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 28.8k Views 6 Watching
      Of course, running it a second time it's much faster. So it's the overhead of starting the Font Book app.
        How about [MAC]:
        fontList=system(/usr/bin/fc-list : file family | grep /Library)
          Returned false πŸ˜•
            How about:
            fontList=system("#!/bin/bash/usr/bin\n/fc-list : file family | grep /Library")
              false
                In normal Console:
                /usr/bin/fc-list : file family | grep \/Library
                Return:
                -bash: /usr/bin/fc-list: No such file or directory
                cd /usr/bin/ fc-list : family
                Return:
                List of just font names.
                Returns:
                Nothing
                But getting the result of system call under SketchUp, with the system method - all I get is false.
                  http://stackoverflow.com/a/3159997/486990
                  Either:
                  system('foobarCommand')
                  foobarCommand``
                  The latter will return the output - the former will output to standard output but return true/false.
                  ` >> system('echo hi')
                  hi
                  => true
                  echo hi
                  => "hi\n"`
                  fc-list : family`` returns a list of font names.
                  (This was using IRB from a system console)
                  However, using Ruby Console:
                  echo hi`` returns "hi\n"
                  but fc-list : family`` returns "" πŸ˜•
                    System IRB console:
                    >> system 'echo hi' hi => true
                    SketchUp Console:
                    ` > system 'echo hi'
                    true
                    system 'fc-list'
                    false`
                    What gives?
                      How about something like...
                      fontList = system(fc-list : family)
                      Do you need to specify the 'shell-type' in the line like ?
                      fontList=system(#!/bin/bash usr/bin/fc-list : family)
                      When it works, then is it fast enough ?
                        See my previous post - the commands work in native consoles, but not in in SketchUp console - it doesn't appear to capture the output.
                          But the surely surrounding ` ``` '' "" etc can produce different results ??
                          So... are they all foobar?
                          My other example tried to force it to run as a 'bash' shell... Is that possible?
                          Not having a MAC available does somewhat curtail my help in this area πŸ˜’
                            Jim
                            Maybe they are using stderr instead of stdout? You could test on the command line:
                            fc-list : family > out fc-list : family 2> err
                              They all return false.
                                nada 😞
                                  Tried to output to file:
                                  fc-list : family >> ~/Desktop/fonts.txt
                                  Empty when run from within SketchUp, populated when run in a native console.
                                  Something is messed up with the messaging system! 😞
                                    system(fc-list : family | out) ?
                                    running out of permutations...
                                      Won't that just list fonts with "out" in them?
                                        The 'grep' is for pattern matching...
                                        The | pipes/passes the output to something else ['out'].
                                        What do you call the 'output' on a MAC ??
                                        The > puts the output into a file.
                                        The >> appends the output to a file.
                                        How do you 'pass/send' something ?
                                          driven
                                          TT
                                          what osx are you running.
                                          'shell' change to AT&T version with 10.5 , so the syntax needs to be checked
                                          FontBook has had lots of revisions/additions
                                          and those osascripts run it in the background, take miliseconds on my mac.
                                          the nice thing is people could set a 'SU 3D Font Collection in fontbook and you can allow them to use just those
                                            10.5
                                            But it works in the system console, and it works from IRB calling system command - but not from SketchUp calling system command.
                                            Mine took a noticeable lag the first time I ran it, but quick the next runs. And Font Book's icon appeared in the dock.
                                            • 2 / 6
