    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 20.6k Views 6 Watching
      How about [MAC]:
      fontList=system(/usr/bin/fc-list : file family | grep /Library)
        Returned false πŸ˜•
          How about:
          fontList=system("#!/bin/bash/usr/bin\n/fc-list : file family | grep /Library")
            false
              In normal Console:
              /usr/bin/fc-list : file family | grep \/Library
              Return:
              -bash: /usr/bin/fc-list: No such file or directory
              cd /usr/bin/ fc-list : family
              Return:
              List of just font names.
              Returns:
              Nothing
              But getting the result of system call under SketchUp, with the system method - all I get is false.
                http://stackoverflow.com/a/3159997/486990
                Either:
                system('foobarCommand')
                foobarCommand``
                The latter will return the output - the former will output to standard output but return true/false.
                ` >> system('echo hi')
                hi
                => true
                echo hi
                => "hi\n"`
                fc-list : family`` returns a list of font names.
                (This was using IRB from a system console)
                However, using Ruby Console:
                echo hi`` returns "hi\n"
                but fc-list : family`` returns "" πŸ˜•
                  System IRB console:
                  >> system 'echo hi' hi => true
                  SketchUp Console:
                  ` > system 'echo hi'
                  true
                  system 'fc-list'
                  false`
                  What gives?
                    How about something like...
                    fontList = system(fc-list : family)
                    Do you need to specify the 'shell-type' in the line like ?
                    fontList=system(#!/bin/bash usr/bin/fc-list : family)
                    When it works, then is it fast enough ?
                      See my previous post - the commands work in native consoles, but not in in SketchUp console - it doesn't appear to capture the output.
                        But the surely surrounding ` ``` '' "" etc can produce different results ??
                        So... are they all foobar?
                        My other example tried to force it to run as a 'bash' shell... Is that possible?
                        Not having a MAC available does somewhat curtail my help in this area πŸ˜’
                          Jim
                          Maybe they are using stderr instead of stdout? You could test on the command line:
                          fc-list : family > out fc-list : family 2> err
                            They all return false.
                              nada 😞
                                Tried to output to file:
                                fc-list : family >> ~/Desktop/fonts.txt
                                Empty when run from within SketchUp, populated when run in a native console.
                                Something is messed up with the messaging system! 😞
                                  system(fc-list : family | out) ?
                                  running out of permutations...
                                    Won't that just list fonts with "out" in them?
                                      The 'grep' is for pattern matching...
                                      The | pipes/passes the output to something else ['out'].
                                      What do you call the 'output' on a MAC ??
                                      The > puts the output into a file.
                                      The >> appends the output to a file.
                                      How do you 'pass/send' something ?
                                        driven
                                        TT
                                        what osx are you running.
                                        'shell' change to AT&T version with 10.5 , so the syntax needs to be checked
                                        FontBook has had lots of revisions/additions
                                        and those osascripts run it in the background, take miliseconds on my mac.
                                        the nice thing is people could set a 'SU 3D Font Collection in fontbook and you can allow them to use just those
                                          10.5
                                          But it works in the system console, and it works from IRB calling system command - but not from SketchUp calling system command.
                                          Mine took a noticeable lag the first time I ran it, but quick the next runs. And Font Book's icon appeared in the dock.
                                            driven
                                            it is possible to get an output to Ruby Console using echo <dev/nul, but I need to dig thru for a working example..
                                            I think I would run only once, hold the list in the plugin, but add an update function/item for people who add fonts to FontBook [very few]...
                                            added to the end of the osascript should close it after use -e 'tell application "Font Book" to quit' -e 'end'
                                            • 2 / 6
