    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 26.0k Views 6 Watching
      How about:
      fontList=system("#!/bin/bash/usr/bin\n/fc-list : file family | grep /Library")
        false
          In normal Console:
          /usr/bin/fc-list : file family | grep \/Library
          Return:
          -bash: /usr/bin/fc-list: No such file or directory
          cd /usr/bin/ fc-list : family
          Return:
          List of just font names.
          Returns:
          Nothing
          But getting the result of system call under SketchUp, with the system method - all I get is false.
            http://stackoverflow.com/a/3159997/486990
            Either:
            system('foobarCommand')
            foobarCommand``
            The latter will return the output - the former will output to standard output but return true/false.
            ` >> system('echo hi')
            hi
            => true
            echo hi
            => "hi\n"`
            fc-list : family`` returns a list of font names.
            (This was using IRB from a system console)
            However, using Ruby Console:
            echo hi`` returns "hi\n"
            but fc-list : family`` returns "" πŸ˜•
              System IRB console:
              >> system 'echo hi' hi => true
              SketchUp Console:
              ` > system 'echo hi'
              true
              system 'fc-list'
              false`
              What gives?
                How about something like...
                fontList = system(fc-list : family)
                Do you need to specify the 'shell-type' in the line like ?
                fontList=system(#!/bin/bash usr/bin/fc-list : family)
                When it works, then is it fast enough ?
                  See my previous post - the commands work in native consoles, but not in in SketchUp console - it doesn't appear to capture the output.
                    But the surely surrounding ` ``` '' "" etc can produce different results ??
                    So... are they all foobar?
                    My other example tried to force it to run as a 'bash' shell... Is that possible?
                    Not having a MAC available does somewhat curtail my help in this area πŸ˜’
                      Jim
                      Maybe they are using stderr instead of stdout? You could test on the command line:
                      fc-list : family > out fc-list : family 2> err
                        They all return false.
                          nada 😞
                            Tried to output to file:
                            fc-list : family >> ~/Desktop/fonts.txt
                            Empty when run from within SketchUp, populated when run in a native console.
                            Something is messed up with the messaging system! 😞
                              system(fc-list : family | out) ?
                              running out of permutations...
                                Won't that just list fonts with "out" in them?
                                  The 'grep' is for pattern matching...
                                  The | pipes/passes the output to something else ['out'].
                                  What do you call the 'output' on a MAC ??
                                  The > puts the output into a file.
                                  The >> appends the output to a file.
                                  How do you 'pass/send' something ?
                                    driven
                                    TT
                                    what osx are you running.
                                    'shell' change to AT&T version with 10.5 , so the syntax needs to be checked
                                    FontBook has had lots of revisions/additions
                                    and those osascripts run it in the background, take miliseconds on my mac.
                                    the nice thing is people could set a 'SU 3D Font Collection in fontbook and you can allow them to use just those
                                      10.5
                                      But it works in the system console, and it works from IRB calling system command - but not from SketchUp calling system command.
                                      Mine took a noticeable lag the first time I ran it, but quick the next runs. And Font Book's icon appeared in the dock.
                                        driven
                                        it is possible to get an output to Ruby Console using echo <dev/nul, but I need to dig thru for a working example..
                                        I think I would run only once, hold the list in the plugin, but add an update function/item for people who add fonts to FontBook [very few]...
                                        added to the end of the osascript should close it after use -e 'tell application "Font Book" to quit' -e 'end'
                                          driven
                                          I've been trying loads of different ways to get the exact font list that SU shows under 'Window' >> 'Show Fonts' all 297 on my mac, this is by far the easiest
                                          macFonts=[]
                                          macFonts=(`osascript -e 'tell application "Font Book" to set macFonts to name of every font family'`).split(",").uniq.each {|a| a.strip! if a.respond_to? ;strip! }.sort
                                          quitFontBook=(`osascript -e 'tell application "Font Book" to quit'`)
                                           if macFonts.length > 1
                                           then quitFontBook
                                          macFonts.length
                                            I'll try it on my mac
                                            • 2 / 6
