    Unfolding plugin idea
    19 Posts 9 Posters 6.8k Views 9 Watching
      MattC
      Thanks Everybody ! With Your help I got it working.
      After this long weekend I will post what I have done.
      Still there are some problems, but those I will try to solve later.
      Matt
        DOD3R
        nice would be the possibility to make UV mam from this
        • O Offline
          Orangutan
          Nice work. Thanks.
            MattC
            Hello Everybody
            Here is result of my work.
            Plugin will make a autounfold submenu , with 2 options: unroll and rotate to XY plane AND unroll and leave in plane of last element.
            Select elements to unroll first and then activate tool.
            Pick first face, and then pick one adjacent to define in which direction it schould be unfolded.
            Script is based on idea of unfoldtool , and made with help of this comunity.
            Therefore no rights reserved, and no responsibilities to be taken by author.
            Feel free to test,use and modify.
            C&C welcome!
            Matt
            Autounfold
            • PixeroP Offline
              Pixero
              Thanks! I will study it carefully. As you know I have an idea... ๐Ÿ˜‰
                Kuddl
                (old) Unfolding plugin idea
                (new) [Plugin] Unfolding automatically ๐Ÿ˜„
                Hi Matt,
                why do you do no official plug-in from this?
                Nice work. Thanks. ๐Ÿ‘
                You must not hide!
                Sorry my bad englishโ€ฆ ๐Ÿ˜ณ
                Kuddl
                  MattC
                  Hello
                  First, it is not finished, there are some things that I would like to change but have no time at this moment.
                  Second, it is not well tested, I know that on some conditions it will not work properly, I am still investigating the reasons.
                  Third, When it comes to large curved surfaces, that consist of more than 400 faces, because if the loops that sit in code it can freeze.
                  So no official plugin yet.Still lots of things to improve.
                  Matt
                    MattC
                    [Solved] BUT ideas are appreciated I am busy with reworking the code , but I found a small problem.
                    First situation:
                    Rectangle in XY plane, with a normal vector shown.
                    Then this rectangle was split with a line into two triangles, again with shown normals.
                    https://lh6.googleusercontent.com/-wwcErWmEVv8/Tjuv1W0tHLI/AAAAAAAABEY/e0rGPukMTkQ/s600/a1.PNG
                    https://lh3.googleusercontent.com/-maBwUfPqGIU/Tjuv1osNksI/AAAAAAAABEg/utV0_szKZio/s600/a2.PNG
                    No problem.
                    Second situation, with rectangle not in XY plane:
                    https://lh4.googleusercontent.com/-QXNPYC3ju_U/Tjuv19ltcrI/AAAAAAAABEk/wxlfgPhDme4/s600/a3.PNG
                    https://lh5.googleusercontent.com/-7_n-e9E7vGs/Tjuv1ZbMONI/AAAAAAAABEc/bUFnmOqAdrA/s600/a4.PNG
                    As you can see, there are smaal differences in coordinates.
                    But when checking if faces are coplanar ( by comparing normals, of planes of faces) it gives a false result.
                    Is there a walkaround? is it possible to perform some kind of rounding of coordinates?
                    Thanks for help.
                    Matt
                      Gade
                      Hello, i'm very interested into your plugin but it's not working on my computer... is it possible to use your plugin with mac ? i have sketchup 8? please help me to use your plugin i would like to make a model ...
                        MattC
                        Hi I will need some more informations to answer, I havn't used it in a long time, at least this version, but I see no reason why it should not work on Mac.
                        You can also take a look here:
                        http://www.papermodelers.com/forum/software/18100-spp-sketchup-paper-planes-tools-sketchup.html
                        Greets
                        Matt
