    Unfolding plugin idea
    19 Posts 9 Posters 7.0k Views 9 Watching
    • K
      kyyu
      Also, You can output text to the status bar vs alot of message boxes: http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#status_text=
      Message boxes are especially good for alerting the user of errors and debugging your code.
      And there is a book that may help you out, concerning sketchup ruby. You can download the full pdf for free: http://www.autosketchup.com/
        MattC
        Thanks Everybody ! With Your help I got it working.
        After this long weekend I will post what I have done.
        Still there are some problems, but those I will try to solve later.
        Matt
          DOD3R
          nice would be the possibility to make UV mam from this
          • O
            Orangutan
            Nice work. Thanks.
              MattC
              Hello Everybody
              Here is result of my work.
              Plugin will make a autounfold submenu , with 2 options: unroll and rotate to XY plane AND unroll and leave in plane of last element.
              Select elements to unroll first and then activate tool.
              Pick first face, and then pick one adjacent to define in which direction it schould be unfolded.
              Script is based on idea of unfoldtool , and made with help of this comunity.
              Therefore no rights reserved, and no responsibilities to be taken by author.
              Feel free to test,use and modify.
              C&C welcome!
              Matt
              Autounfold
              • PixeroP
                Pixero
                Thanks! I will study it carefully. As you know I have an idea... ๐Ÿ˜‰
                • K
                  Kuddl
                  (old) Unfolding plugin idea
                  (new) [Plugin] Unfolding automatically ๐Ÿ˜„
                  Hi Matt,
                  why do you do no official plug-in from this?
                  Nice work. Thanks. ๐Ÿ‘
                  You must not hide!
                  Sorry my bad englishโ€ฆ ๐Ÿ˜ณ
                  Kuddl
                    MattC
                    Hello
                    First, it is not finished, there are some things that I would like to change but have no time at this moment.
                    Second, it is not well tested, I know that on some conditions it will not work properly, I am still investigating the reasons.
                    Third, When it comes to large curved surfaces, that consist of more than 400 faces, because if the loops that sit in code it can freeze.
                    So no official plugin yet.Still lots of things to improve.
                    Matt
                      MattC
                      [Solved] BUT ideas are appreciated I am busy with reworking the code , but I found a small problem.
                      First situation:
                      Rectangle in XY plane, with a normal vector shown.
                      Then this rectangle was split with a line into two triangles, again with shown normals.
                      https://lh6.googleusercontent.com/-wwcErWmEVv8/Tjuv1W0tHLI/AAAAAAAABEY/e0rGPukMTkQ/s600/a1.PNG
                      https://lh3.googleusercontent.com/-maBwUfPqGIU/Tjuv1osNksI/AAAAAAAABEg/utV0_szKZio/s600/a2.PNG
                      No problem.
                      Second situation, with rectangle not in XY plane:
                      https://lh4.googleusercontent.com/-QXNPYC3ju_U/Tjuv19ltcrI/AAAAAAAABEk/wxlfgPhDme4/s600/a3.PNG
                      https://lh5.googleusercontent.com/-7_n-e9E7vGs/Tjuv1ZbMONI/AAAAAAAABEc/bUFnmOqAdrA/s600/a4.PNG
                      As you can see, there are smaal differences in coordinates.
                      But when checking if faces are coplanar ( by comparing normals, of planes of faces) it gives a false result.
                      Is there a walkaround? is it possible to perform some kind of rounding of coordinates?
                      Thanks for help.
                      Matt
                      • G
                        Gade
                        Hello, i'm very interested into your plugin but it's not working on my computer... is it possible to use your plugin with mac ? i have sketchup 8? please help me to use your plugin i would like to make a model ...
                          MattC
                          Hi I will need some more informations to answer, I havn't used it in a long time, at least this version, but I see no reason why it should not work on Mac.
                          You can also take a look here:
                          http://www.papermodelers.com/forum/software/18100-spp-sketchup-paper-planes-tools-sketchup.html
                          Greets
                          Matt
