    Simple country barn
    45 Posts 21 Posters 3.4k Views 21 Watching
    • pbacotP Offline
      Video may be useful for quickly explaining some operations. Probably videos are more essential for modelling tool manipulations than workflow. Pdfs are quicker to go through for reviewing the steps and settings. Images are needed in any case to show "this is what you should see if you're doing it right."
      • boofredlayB Offline
        boofredlay
        I prefer video tutorials over pdf. The explanation is quicker and seeing it actually done explains things that are difficult to put into words some times. Also when I create tutorials myself it takes 10x longer to spell out the steps than it does for a video.
        I have been so far removed from Thea or any rendering program for so long I am looking forward to what you are going to present.
        • soloS Offline
          I created a VPN and looks like I can attach images now, please confirm.
          I also think video would be easier and if they are done in shorter one topic format they can be referenced and watched as needed, like the way Lynda.com does it. However if folks prefer pdf's what can I say, I aim to please.
          • cottyC Offline
            cotty
            πŸ‘
            my SketchUp gallery
            • StinkieS Offline
              Stinkie
              Just go with what works best for you -if it's good, and I'm reasonably confident it will be, people will buy it, whether it's a pdf or a video. I for one look forward to it.
              • Bryan KB Offline
                Excellent render and great "quick tips."
                Get with TW ASAP as they should not be blocking sites.
                • pbacotP Offline
                  Hey, I like videos too. You can sit back, crack one open, and just watch for a while.
                  I know I spend a lot of time editing a little video, but if you got it down, I can see how it can be faster than editing text and pictures. You can do weekly episodes. Go for it!
                  And thanks in advance!
                  • leedeeteeL Offline
                    leedeetee
                    @solo said:
                    As you can see there is a lot going on in scene that for those who have never used proxy's might look very strange, not to worry I can explain that very quick and easily.
                    Hi Solo,
                    This is looking great, if you get a spare moment, could you explain the use of proxies? Think it would be very useful. πŸ˜„
                    Cheers.
                    • soloS Offline
                      @leedeetee said:
                      Hi Solo,
                      Cheers.
                      Lee,
                      The best and possibly easiest way to explain without video or images is a Proxy is a component that you can use in Sketchup without using in Sketchup, in other words it is real geometry that will only be recognized and seen in a render and does not effect Sketchup (depending on the geometry you use to represent it) Like my images on first page, an entire tree that is way too heavy (polygon speaking) to even be opened alone in SU can be populated to your hearts content as each tree weighs the equivalent of 12 lines and not hundreds or thousand polygons, so take the scene I posted, in total it's over 2 billion polygons, something SU could never ever even dream of opening, But SU is not handling the geometry as Thea is.
                      So you may be limited by SU, Thea now gives you a way to overcome SU's limitations as far as polygons go.
                      So in a nutshell a proxy represents full geometry without having to use it in the SU model.
                      I think doing a video tutorial will be better as typing this and reading it confused me, I make more sense just saying and showing, once you get past my accent.
                      • renderizaR Offline
                        renderiza
                        This blows my mind how you were able to set this up...Beautiful Indeed!
                        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                        • srxS Offline
                          srx
                          πŸ˜„ Video.
                          www.saurus.rs
                            leedeetee
                            Thanks Solo, it's a great explanation. πŸ˜„
                            Can the proxies be used in SU in general, or, is it a Thea specific tool?
                              PDF over video every time, much less obfuscation in a pdf.
                                boofredlay
                                πŸ˜† My point exactly. I just finished a tutorial for Catchup that took many hours to complete. Had I done it with a video it would have been about 10 min. long. Then maybe 30 min. of editing the video with tool tips.
                                • daleD Offline
                                  dale
                                  Pete, I don't care which you choose, I'm just looking forward to it.
                                  • pbacotP Offline
                                    I'm with the monkey!
                                    • soloS Offline
                                      Thanks guys.
                                      I need to wait until Tomasz (the author) releases his final beta version with any new changes, feature or UI improvements before starting, there is no point doing a tutorial if my version is different to the released version, so as soon as I get that i'll get going with it.
                                      I like the idea of doing it in short sessions, covering topics like Interface, using proxy's, making proxy's, render settings, animation, lighting, crf's, DOF, etc, that way you can watch the parts you need without having to sit through hours to find the bits you need.
                                      • StinkieS Offline
                                        Stinkie
                                        That would work for me. πŸ‘
                                          jpalm32
                                          Solo,
                                          Do you have problems with precise alignment with the proxy. Do you find yourself going back & forth after quick renders to correct?
                                          As example: A tree or bush placement next to another item.
                                          Or are proxy best for general palcement?
                                          • soloS Offline
                                            @jpalm32 said:
                                            Solo,
                                            The only adjustments I did in image was the tree behind camera in order to get correct shadow cast, remember in Thea4SU you have all render option so you can use interactive rendering (realtime) to see how it is while you are doing it. πŸ˜„
                                            • 1 / 3
