    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    LIGHTUP Help
    extensions
    19 Posts 7 Posters 856 Views 7 Watching
    • iichiversiiI Offline
      iichiversii
      Im new to lightup and have being searching for a fix for this problem, its proberly something simple but i just cant figure out whats going on here, maybe someone could help me understand this and how to fix it.
      Here is an image export from sketchup of a very simple lowpoly tree with the texture used to the left. TREE_image.png
      And once rendered in lightup this is what i get ๐Ÿ˜ž
      I have tried searching the lightup forums for this issue but couldnt find anything so i said id try here instead ๐Ÿ˜ฒ
      Bring on the Rain...
        Maybe your PNG must have background "transparent" ?
          iichiversii
          Believe it or not but i taught it was just that png but it happened here too, no transparency on the png ๐Ÿ˜ฎ
            iichiversii
            everything in red is on the same texture, the cars are on a separate texture, this is really starting to bug me, i had high hopes for lightup, it never occured when i was using the trial version a couple of months back ๐Ÿ˜ข
            • beginnerB Offline
              beginner
              Hi iichiversii,
              Can you post your model.
              We have LU and maybe I could help.
              Regards, SU 'beginner'
              • AdamBA Offline
                AdamB
                [attachment=0:2seo0zfj]<!-- ia0 -->HOUSE_WIP_LP_lightup(no scene)_2012-11-07_2313.jpg<!-- ia0 -->[/attachment:2seo0zfj]
                If LightUp cannot read a texture for any reason, it creates a red texture with the pathname of the file it was unable to read written "into" the texture.
                LightUp reads most texture formats, but does not support "JPEG Progressive" which is a not widely used variant of the regular JPEG image format. I can see the file has a .png extension, but are you certain its not actually a jpeg?
                The solution is to convert it to a supported file format. PNG is well supported by LightUp, as are TGA, BMP,HDR,VTF formats.
                Adam
                  What's the colour channel of the images? I really do not know if it is relevant but when trouble shooting weird things,one tends to think of everything that comes into his mind. I have seen issues with images that are not RGB channel in SU (although I have no idea if it can cause problems in LU)
                  Edit: Adam beat me but since he's here, at least he can confirm if CMK colours can properly be read.
                    iichiversii
                    This I did not know, thanks Adam, ill check it this evening to be sure but normally I only use png format images in sketchup, ill post to see if that is or not the issue ๐Ÿ‘
                    Ill check that also Gaieus just to be sure ๐Ÿ‘
                      iichiversii
                      @beginner said:
                      Hi iichiversii,
                      Thanks for the offer, ill try out what Adam suggests and if it isn't the issue ill post ๐Ÿ‘
                        iichiversii
                        Ok the texture was a png and it never worked, to double check i exported the image and converted to png to be sure and had the same issue, but i then converted to a TGA image and it works just fine, still cant understand why the PNG image didnt work
                        • Chris FullmerC Offline
                          What software are you using to convert and make your images? Photoshop? GiMP?
                            iichiversii
                            Hi Chris, i use GIMP
                              Hmm, I'm not as familiar with that one. I know in photoshop for saving png it gives an option for Interlace - either none or interlaced. Typically none is what I always use. and probably make it an 8bit rgb mode png. That's all I've got. And I don't have lightup experience, just general png usage experience, so its just a guess.
                              • Rich O BrienR Online
                                Share the texture to remove the mystery
                                  iichiversii
                                    try this
                                      iichiversii
                                      Ok that worked Rich, so what was wrong with my PNG ? and what should i have done to make it work?
                                        I want to know how you went about saving....
                                        • AdamBA Offline
                                          AdamB
                                          Perhaps what you've done is export the texture and done "save as" a PNG. Which converts it to a PNG file.
                                          But the embedded Material texture you had before that went red (named "TREE(1).PNG") was actually a jpeg with a misleading extension.
                                          but glad you've resolve it!
                                          Adam
