    LIGHTUP Help
    extensions
    19 Posts 7 Posters 1.2k Views 7 Watching
    • iichiversiiI Offline
      iichiversii
      Ok the texture was a png and it never worked, to double check i exported the image and converted to png to be sure and had the same issue, but i then converted to a TGA image and it works just fine, still cant understand why the PNG image didnt work
      Bring on the Rain...
      • Chris FullmerC Offline
        What software are you using to convert and make your images? Photoshop? GiMP?
          iichiversii
          Hi Chris, i use GIMP
            Hmm, I'm not as familiar with that one. I know in photoshop for saving png it gives an option for Interlace - either none or interlaced. Typically none is what I always use. and probably make it an 8bit rgb mode png. That's all I've got. And I don't have lightup experience, just general png usage experience, so its just a guess.
              Share the texture to remove the mystery
                iichiversii
                  try this
                    iichiversii
                    Ok that worked Rich, so what was wrong with my PNG ? and what should i have done to make it work?
                      I want to know how you went about saving....
                      • AdamBA Offline
                        AdamB
                        Perhaps what you've done is export the texture and done "save as" a PNG. Which converts it to a PNG file.
                        But the embedded Material texture you had before that went red (named "TREE(1).PNG") was actually a jpeg with a misleading extension.
                        but glad you've resolve it!
                        Adam
