    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 15.4k Views 6 Watching
      Returned false πŸ˜•
        How about:
        fontList=system("#!/bin/bash/usr/bin\n/fc-list : file family | grep /Library")
          false
            In normal Console:
            /usr/bin/fc-list : file family | grep \/Library
            Return:
            -bash: /usr/bin/fc-list: No such file or directory
            cd /usr/bin/ fc-list : family
            Return:
            List of just font names.
            Returns:
            Nothing
            But getting the result of system call under SketchUp, with the system method - all I get is false.
              http://stackoverflow.com/a/3159997/486990
              Either:
              system('foobarCommand')
              foobarCommand``
              The latter will return the output - the former will output to standard output but return true/false.
              ` >> system('echo hi')
              hi
              => true
              echo hi
              => "hi\n"`
              fc-list : family`` returns a list of font names.
              (This was using IRB from a system console)
              However, using Ruby Console:
              echo hi`` returns "hi\n"
              but fc-list : family`` returns "" πŸ˜•
                System IRB console:
                >> system 'echo hi' hi => true
                SketchUp Console:
                ` > system 'echo hi'
                true
                system 'fc-list'
                false`
                What gives?
                  How about something like...
                  fontList = system(fc-list : family)
                  Do you need to specify the 'shell-type' in the line like ?
                  fontList=system(#!/bin/bash usr/bin/fc-list : family)
                  When it works, then is it fast enough ?
                    See my previous post - the commands work in native consoles, but not in in SketchUp console - it doesn't appear to capture the output.
                      But the surely surrounding ` ``` '' "" etc can produce different results ??
                      So... are they all foobar?
                      My other example tried to force it to run as a 'bash' shell... Is that possible?
                      Not having a MAC available does somewhat curtail my help in this area πŸ˜’
                        Jim
                        Maybe they are using stderr instead of stdout? You could test on the command line:
                        fc-list : family > out fc-list : family 2> err
                          They all return false.
                            nada 😞
                              Tried to output to file:
                              fc-list : family >> ~/Desktop/fonts.txt
                              Empty when run from within SketchUp, populated when run in a native console.
                              Something is messed up with the messaging system! 😞
                                system(fc-list : family | out) ?
                                running out of permutations...
                                  Won't that just list fonts with "out" in them?
                                    The 'grep' is for pattern matching...
                                    The | pipes/passes the output to something else ['out'].
                                    What do you call the 'output' on a MAC ??
                                    The > puts the output into a file.
                                    The >> appends the output to a file.
                                    How do you 'pass/send' something ?
                                      driven
                                      TT
                                      what osx are you running.
                                      'shell' change to AT&T version with 10.5 , so the syntax needs to be checked
                                      FontBook has had lots of revisions/additions
                                      and those osascripts run it in the background, take miliseconds on my mac.
                                      the nice thing is people could set a 'SU 3D Font Collection in fontbook and you can allow them to use just those
                                        10.5
                                        But it works in the system console, and it works from IRB calling system command - but not from SketchUp calling system command.
                                        Mine took a noticeable lag the first time I ran it, but quick the next runs. And Font Book's icon appeared in the dock.
                                          driven
                                          it is possible to get an output to Ruby Console using echo <dev/nul, but I need to dig thru for a working example..
                                          I think I would run only once, hold the list in the plugin, but add an update function/item for people who add fonts to FontBook [very few]...
                                          added to the end of the osascript should close it after use -e 'tell application "Font Book" to quit' -e 'end'
                                            driven
                                            I've been trying loads of different ways to get the exact font list that SU shows under 'Window' >> 'Show Fonts' all 297 on my mac, this is by far the easiest
                                            macFonts=[]
                                            macFonts=(`osascript -e 'tell application "Font Book" to set macFonts to name of every font family'`).split(",").uniq.each {|a| a.strip! if a.respond_to? ;strip! }.sort
                                            quitFontBook=(`osascript -e 'tell application "Font Book" to quit'`)
                                             if macFonts.length > 1
                                             then quitFontBook
                                            macFonts.length
                                            • 3 / 6
