    White line appearing around png render
    renderpluginsextensions
    16 Posts 6 Posters 7.7k Views 6 Watching
      ampersand
      hey guys. im getting an issue with my png renders of models that i didnt used to get previously on an earlier version of vray/sketchup.
      but when i render im getting a faint white line, about 1 or 2 pixels in thickness appear around the edges of my renders. i can fix this in photoshop. but I never used to have this problem before.
      is this an issue or is there some obscure setting i may be missing that is causing this to happen?
      thanks in advance πŸ˜„
      • olisheaO Offline
        olishea
        Your actual render has a white line? Or a PNG image you have rendered has a white line?
        SU will add a white edge to the edge of all PNG images. I have no idea why. Normally if you just offset the image or drop the line beyond the white line, it solves the problem.
        oli
          ampersand
          yes its adding it to the final output (and isnt there previously)
          this never used to happen before im fairly certain of that. or did i dream that one up? lol.
          i was thinking because i am saving as png that it leaves the none model covered area as a transparent thus centrering the edge on the focus of the model.
          so there is no way of removing this white line?
          • olisheaO Offline
            olishea
            Is the saved PNG actually showing a transparent background though?
            I've only noticed the white line around say a PNG tree right on the edge of the texture. I've not seen it on saved render before, but then again I never normally have any transparent space. It's really annoying!!! It's like edge of a PNG has a fringe in SU.
            oli
              ampersand
              yup exactly that is happening.
              im fairly certain this didnt happen on older versions.
              im taking it is an issue then?
              i cant seem to find any information regarding it anywhere
              • olisheaO Offline
                olishea
                Save in a different format for the time being if you are in a rush. Or do you really need the transparent part? Use a mask preset if so.
                I dunno if it's just a native characteristic of PNGs or the way SU deals with them.
                oli
                • V Offline
                  valerostudio
                  I use PNG all the time and have never had this issue while saving from VR 1.49.01. Which version are you using?
                  • andybotA Offline
                    andybot
                    if your background is very bright/ white - then anti-aliasing will combine the edge pixels of your model and your background. try to make your background darker and see if it helps. otherwise, you can try turning off AA
                      Can we see a sample output please?
                        ampersand
                        im using version 1.49.02
                        and it does appear to reduce if i darken the background i am working on. but i see that more as a quick fix if nothing else lasting works.
                        all i want is a crisp sharp image when i save my png. the transparency is important firsnt and foremost as the images i render are to be singular entities for an isometric map.
                        ive added a screen shot of a png render, but ive put it onto a black background to just help show up the edges better
                        • andybotA Offline
                          andybot
                          looks to me like an issue with a dark material on a light background. Did you try turning off anti-aliasing (in the image sampler tab)?
                            ampersand
                            when i turned off anti aliasing...it looked about 5 times worse 😞
                            • andybotA Offline
                              andybot
                              Well, you would have to increase your resolution if AA is off, but anyhow, sounds like that may not be the issue. Is there a model or part of a model that you can post?
                              • chonC Offline
                                chon
                                Hello,
                                in your vray bitmap material render panel, try to set the "filter type" in "bitmap buffer" on "No filter". I had good results with that setting.
                                  ampersand
                                  thanks chon ill give that a try tonight. if all else fails ill post up a model..but i dont see why it would be a model. this happens even on a simple square block,
                                  i was figuring it was something to do with the rendering itself more than the model
                                  • andybotA Offline
                                    andybot
                                    the idea is that with a model, we can look at your vray settings and see if there's a solution.
