    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Axis orientation always in view
    10 Posts 5 Posters 1.2k Views 5 Watching
    • jgbJ Offline
      jgb
      Here's a wish for next version.
      I often have large objects with a lot of small detail. If I zoom into a detail bit, say a small line, to copy or move it (or any other operation) I lose sight of the RGB axis reference, either the main or local comp/group axis. Then when I want to move/copy/draw etc. in that close in view along an axis, the visual reference is gone. I need to zoom out to see where the axis of choice is, then zoom back in. That can be counter productive with a large model, especially if the tool on object has been selected.
      ๐Ÿ’ญ ๐Ÿ’ญ How's about putting a small 3-axis reference icon on screen somewhere? ๐Ÿ’ญ ๐Ÿ’ญ
      Autocad (with all its' ills) does that in a halfassed way. ๐Ÿ˜’
      It can be dynamic and only appear when no axis reference is visible, or always there, or hot-key toggled, whatever. Even a plug-in! ๐Ÿ˜‰
      jgb
      • gillesG Offline
        gilles
        Sketchup/Preferences/Drawing/Display Crosshairs could be a start.
        • cottyC Offline
          cotty
          DUH!
          Never noticed this and assigned a shortcut to it immediately... Thanks!
          my SketchUp gallery
            One can assign a shortcut to Preferences properties??
            • cottyC Offline
              cotty
              I've searched for it and there it was...
              my SketchUp gallery
                ๐Ÿ˜ฒ
                That's not part of any menu or toolbar is it? Seem to be a special item. hmm... wonder what else there is...
                • cottyC Offline
                  cotty
                  @thomthom said:
                  :shock:
                  Right, seems that it is possible since SU5 ...
                  my SketchUp gallery
                  • TIGT Online
                    It's set in Preferences Capture.PNG It's one of those items you can shortcut to, but that has no menu entry otherwise...
                    It's supposedly also available on a PC as a toggle Sketchup.send_action(21415) but that doesn't work for me...
                    So as far as I know it can't be accessed via the API and Ruby...
                    • jgbJ Offline
                      jgb
                      Neato. Long time ago I tried crosshairs, but found them a bit distracting, so I never used them.
                      And, Cotty, Thank YOU too. ๐Ÿ˜ Setting a hotkey (F2 for me) did the trick. Now crosshairs are useful to me.
                      It even flummoxed ThomThom. ๐Ÿ˜ฎ How rare is that โ“ โ“ ๐Ÿคฃ
                      In that light, consider this "Wish" as granted. โ˜€
                      jgb
                      • cottyC Offline
                        cotty
                        Exactly my first thought ๐Ÿ˜‰
                        my SketchUp gallery
