    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
    • gullfoG Offline
      gullfo
      grab TIG's "undc" script and run that before doing the bend.
      Glenn
      http://www.runnel.com
      • TIGT Online
        I'd forgotten I made that πŸ˜’
        http://forums.sketchucation.com/viewtopic.php?p=382224#p382224
          tonkolan
          it was awesome plugin tools
          thanks for sharing
          • gullfoG Offline
            gullfo
            it's one of my most important tools now β˜€ - i can use a huge number of DC in my models then "un-DC" them and ship the model out without worrying that my DC will be distributed...
            Glenn
            • TIGT Online
              It's not even a 'tool'... just a 'code snippet'...
              Glad it was useful πŸ˜„
                maladzien
                Hey everyone? How do I run this script? I have no idea how to get this "tool" to show up in Sketchup to use it 😞
                  See if this article helps you: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                    Geveltje
                    Hello all,
                    First I want to say that my english writing is not very good, so sorry for the mistakes.
                    I have a little help from google πŸ‘
                    I am very excited about the plugin, I just can not get it working properly.
                    I select my component.
                    Select the straight line
                    Select the curve line
                    I see that both lines a start and an end appears
                    but that's all, nothing further happened. I can use the up and down arrow keys to change the start and end.
                    Also when I press enter then nothing happens.
                    the straight line is equal to the red axis, the curved line i tried on all axes.
                    I really do not know what I'm doing wrong
                    I hope I have explained clearly
                    Thanks for the response
                    • TIGT Online
                      Roy
                      Have you installed the additional helper script progressbar.rb, which is download-able free from Smustard.com.
                      It's a common issue with less experienced members forgetting about addition helpers like this for the more complex tools - although it is clearly mentioned and linked in the tool's download page.
                      Also make sure that the 'line' is parallel to the X[red] axis and that it touches no other geometry, also note that the 'curve' must not touch other geometry either.
                      Also don't try to bend tiny or enormous objects [most day-to-day sized things should be OK, but tiny parts for swiss-watches or entire cities will create issues]...
                      If you are still getting issues then try running the tool after you've opened the Ruby Console. Post any error messages you get in it, this might give us a better clue as to what you have inadvertently done wrong πŸ˜’
                        Geveltje
                        Hello TIG,
                        Sometimes is the solution so simple that you overlook them
                        I have the plugin and the progressbar removed and reinstalled and now it works perfectly πŸ˜„
                        Thanks you for your answer
                          pustko
                          Hello everybody!first time posting.
                          Yesterday I installed some ruby plugins for sketchup (8)and tried out the Chris Fullmer Shape Bender. After a while, I managed to make it work succesfully, bending the rqmp Im working at (architecture digital model). Everything fine and happy as hell.
                          Then, this morning, same file, same computer, doing exactly the same steps, the bender tool doest work:
                          I draw the figure, group it up, draw the line along red axis, same length, and the single curve. select group, open the tool,select the line,select the curve. the signs "start" "end" appear, I can change their position, but thats it! no green shape, no final bended figure.
                          Maybe the answer is alreqdy somewhere in the forum, but theres a lot of posts, and i have so little time, i got a delivery today and have to finish the model as soon as possible.
                          thanx in advance
                            pustko
                            I got the progressbar installed, etc
                            Yesterday it was working neatly!! that's what buggin me the most.
                            found this:
                            n draw' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in `draw'
                            • TIGT Online
                              Pustko.
                              The important part of any error message is the beginning...
                              Please don't trim them.
                              OK let's assume that the progressbar.rb is installed and called by this tool.
                              After which step does this error appear?
                              After picking the line, the curve or other ?
                              Are you doing the other steps correctly ?
                              axis?
                              Is it freestanding and not touching any other geometry - faces, edges, curves etc?
                              Is the 'curve' freestanding and not touching any other geometry - faces, edges, curves etc?
                              If you still have issues try attaching a simple SKP you are having issues with...
                              Or even some images...
                              A picture paints a thousand words.
                                pustko
                                Hello TIG, thanx for the feed back:
                                The error appears after selecting the curve. The process bar freezes at 2% or 5%
                                The object is a "group", the line is in the red axis and doesnt touche anything, the curve doesn't either
                                first time it worked perfectly πŸ‘ next dqy stopped working πŸ‘Ž
                                the model is the simplest possible; I attach it.
                                Yesterday I read the first 20 pages in this forum 😲 I think it might be a problem with compspray.rb or maybe SketchyFFD. At the office I have no "administrator acces" to remove them, but I will ask and try to remove them as soon as possible.
                                Thank you.
                                here' the beggining of the error message:
                                Error: #<ArgumentError: comparison of Float with nil failed>
                                (eval):44:in >' (eval):44:in update'
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:533:in exploder' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in each'
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in exploder' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:244:in onLButtonUp'
                                Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                                (eval):44
                                Sans titre.skp
                                • TIGT Online
                                  I have no issues except the 'bent object' is somewhat weird because of the chosen line and curve's relationship to the original, but it's a bit better if I toggle the shape 'direction'...
                                  However, I recommend that "everything" - i.e. the group, line and curve - is relocated in the 'positive' quadrant - i.e. where red/green/blue [x/y/z] are all 'positive values' [== solid axes lines]...
                                  It might be that your progressbar is not installed properly too ?
                                  Please double-check that its .rb file is definitely in the Plugins folder, as directed... and that you don't have any 'Compatibility Files' issues [link button showing in the Explorer Window's top bars...]. This can happen if you don't have FULL security permissions to folders like Plugins - Windows protects you from yourself by not fully installing items... To fix right-click context-menu on the Plugins folder icon and Properties > Security > Edit - even being an 'Admin' is not always sufficient to automatically get the right permissions... See thomthom's new helper too ... http://sketchucation.com/forums/viewtopic.php?p=434453#p434453 this checks if everything is installed OK...
                                    pustko
                                    Eureka! πŸ˜†
                                    It works again. Finally I got one of the admin's to erase the compspray.rb plugin and shape bender works neatly again!
                                    Couldnt figure it out earlier; as I don't have access to make any change in the plugin folder...
                                    Thanks again for the help. This plugin is great!!! Its helping me so much with my architecture models!
                                    Thanks Chris!! thanks TIG!!
                                    • thum8sT Offline
                                      thum8s
                                      OMG, Amazing work, like magic!!! πŸ˜„
                                        Scottish
                                        Great ruby! but problems with install? doing this the standard way but comes up with
                                        Error Loading File clf_shape_bender_loader.rb
                                        no such file to load -- progressbar.rb
                                        any help out there??
                                        Scottih
                                        • Chris FullmerC Offline
                                          yup, it requires an additional script called progressbar. There is a link to it on the first page, where you downloaded shape bender. Here's the link again:
                                          File Not Found
                                          (www.smustard.com)
                                            Scottish
                                            File Not Found
                                            (www.smustard.com)
                                            Thanks Chris, im a dummy sometimes...should have payed more Attention!, great work!
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 63
                                            • 64
                                            • 53 / 64
