    [Plugin] Coords Text Tag from Datum
    149 Posts 27 Posters 124.9k Views 27 Watching
    • P
      pmolsen
      Thanks for the prompt response.
      Does V2.0 include the option for the +/- decimal format of the lat/long please, which is the standard displayed on Google Earth and used in KML?
      Any chances on the heading/tilt/roll options please? If not are you able to offer any Ruby tips to allow me to implement something please? It would hugely simplify animation coding.
        Does V2.0 include the option for the decimal format of the lat/long please, which is the standard used in Google Earth and KML?
        Any chances on the heading/tilt/roll options please? If not are you able to offer any Ruby pointers to allow me to implement something please? It would hugely simplify animation coding.
        Is that the format used in your briefly edited version ?
        If so, and we can agree a correct way forward, I could probably include something in v2.1 'tomorrow'... ๐Ÿ˜•
        As for the pitch/roll/yaw camera issue perhaps this deserves a separate thread ?
        Feel free to PM me about it before we all jump into some frantic [re]coding... ๐Ÿค“
        • P
          pmolsen
          Yes, I fully coded and tested the +/- option which was in the one I submitted. KML requires that format.
            I'll look at it...
            PM me about the other ideas...
              Here's v2.1 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
              LatLong +/- option added [thanks @pmolsen] to match KML etc...
                Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                As well as the recent LatLong +/- option added [thanks @pmolsen] to match KML etc...
                There are now some minor [non-critical] code improvements [by him again] incorporated too...
                • H
                  hygicell
                  I have not read all questions and replies, so my questions could already have been answered
                  could it be possible to have these coordinates correspond with real earth coordinates?
                  could there be a possibility to switch between drawing (design)coordinates and their exact position on earth?
                  Frank
                    That's where Long/Lat comes in ??? ๐Ÿ˜•
                    • H
                      hygicell
                      exactly
                      Frank
                        @hygicell said:
                        exactly
                        Frank
                        Does this mean you now see how to do it?
                        You can set the datum in Long/Lat to whatever you like - typically replicated from the SKP's geo-location data.
                        You can then update any pre-exisitng tags to use the new schema: all new tags will have the latest settings too...
                        • jgbJ
                          jgb
                          Tig
                          Nice Job
                          I only played about 20 minutes with this, so I may seem naive (I am) to some of the capabilities of this Ruby. I've read the preamble several times, but some of it does not seem to jive with the dialog boxes.
                          All my drawings use the green axis as my "X" axis, red="Z" and blue="Y".
                          You, and I expect most everyone else, uses Red, Blue, Green as XYZ.
                          This puts the value I need most in the middle of the text string, rather than first as I am used to.
                          Short of turning ALL my drawings 90 deg, which will screw me up a lot (mainly with the comp axis orientations); is there any way of flipping the Red/Green orientation?
                          Is there a way to show ONLY the X axis (or Y) in the tag, and not the Y or Z values?
                          Is there a way to label each tag as it is created, perhaps by simply typing to the VCB the label? Your CofG Ruby picks up the component name. Perhaps you could label the coord tag with that comp name, IF a point on the comp is tagged.
                          There's more, but later. I need to play a lot more.
                          jgb
                            If you want just X&Y to be displayed then I suggest you set Z to 'None' ?
                            You need to mess around with the tool to find the settings that best suit your needs... ๐Ÿ˜„
                            • renderizaR
                              renderiza
                              Very useful plugin...thanks!
                              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                              • jgbJ
                                jgb
                                Bin messin aroun. ๐ŸŽ‰
                                I got the "none" to work (small yea) ๐Ÿ‘ but there seems to be a problem with "add coord tag by dialog" dialog.
                                When I select it, the d-box appears, but no matter what I change, it will not go away when I hit OK. It just comes back in default. Only CANCEL gets rid of it. ๐Ÿ˜ฎ
                                What am I doing wrong??
                                jgb
                                  It is meant to reappear after you press OK [and it has added the coord-tag that you have just specified], this 'auto-rerun' is to let you enter multiple coords without having to reactivate the tool each time.
                                  When you are done press Cancel it stops appearing...
                                  I haven't bothered rereading the instructions but I'm pretty sure this is explained in there ๐Ÿ˜•
                                  • jgbJ
                                    jgb
                                    But it doesn't seem to do anything in the model.
                                    Where's the tag going each time. I've tried to select a coord but nothing happens there as well.
                                    jgb
                                      It's being put at the XYZ you specify.
                                      I just tried it and it works.
                                      BUT remember that it is taking the units you have specified in the tool's settings - so if you have 'm' set as the units and you typed into the dialog 1231/1234/0 it'll appear over a kilometer away in the NE quadrant ! The current units are shown in the dialog's header...
                                      Try zoom-extents to see what you have done ๐Ÿ˜ฒ
                                      • jgbJ
                                        jgb
                                        Now it works. ๐Ÿ‘ I had X,Y & Z at 0.0 but the origin was not in view.
                                        What does Cpoint do? I saw no difference yes or no.
                                        jgb
                                          If you have 'guides' set to be displayed you should see a new cpoint [guide-point] added at the specified coord...
                                          It should add a cpoint even if you aren't currently seeing them... ๐Ÿ˜•
                                          • jgbJ
                                            jgb
                                            Now that I know what to look for, it is there.
                                            thanks.
                                            jgb
                                            • 5 / 8
