    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 61.8k Views 12 Watching
    • bagateloB
      bagatelo
      There should be an option to enter the date and time automatically in the file name.
      Thanks for this great tool.
      • G
        glro
        @aerilius said:
        @driven said:
        Works on mac
        Great! I think there was once a discussion about integrate better thumbnails on OS X, as far as I remember that would require XCode and Objective C (?). I couldn't do it and can't test it.
        If GraphicsConverter has a command line interface, that would make it much easier!
        @glro said:
        C, or java programming would be needed, yes; to create a special file browser hat would add a meta data (the link to the skp file)
        That would be almost reinventing the wheel 😉 . I would prefer using the system's thumbnailing (Windows Vista+ uses a thumbnail folder and a database). We would need to register a thumbnail to the database. As far as I know, there are only APIs for C(++, # ...) and I have not enough experience. I will see if someone else can help me, or if we can get equivalent improvements into SketchUp.
        @glro said:
        is it possible to create a shortcut to a file using ruby?
        That might be a the easiest solution! I'll try it!
        There is a simple way: creating a batch file, for example:
        "@ECHO OFF
        call F:\000_experience.sauvb\programmation\ruby\essai_plateforme.skp
        end"
        this opens the console
        to avoid opening the console, write a second file
        "var WindowStyle_Hidden = 0
        var objShell = WScript.CreateObject("WScript.Shell")
        var result = objShell.Run("cmd.exe /c shortcut.bat", WindowStyle_Hidden)"
        both are text files, easy to write in ruby...
        • simon le bonS
          simon le bon
          @aerilius said:
          It now works also in SketchUp 7
          That's great 👍 👍
          @aerilius said:
          @simon le bon said:
          The "save the name-1" is less evident. Previously I thought it was adding at the end of the file name a decrementation -1 -2 -3 etc..
          Sorry, I had understood it would decrease the number (to redo older images). So instead of a minus button, you would prefer something like "increase primary version number" and "secondary version number"?
          It seems to me that "save the name+1" already "increase secondary version number" 😒
          nameFile_000.skp
          when it is saved gives: (autosave checked)
          "save the name+1" become:
          nameFile_001.skp
          & "save the name+1" become:
          That's not bad to consider snapshots incrementation.
          Redo older image is not (IMO) a very necessary option. And in facts don't work pretty good.
          If you have a png set made with "save the name+1"
          Then you want to redo basically the last one: nameFile_0003.png , if you use "save the name-1" It is nameFile_0002.png that is overwrited !!
          May be only one button would be necessary which would make a clear proper incrementation:
          nameFile_001.skp
          when saved gives:
          & "save the name + increment"
          Just idea (as Jean Lemire always says 😉 )
          Simon
          PS:
          _ Sorry that "save a copy as" can't autosave a snapshot. We can take few seconds to save the snapshot name manually after all.
          _ "The foxy method" is lost for me. I have tried with the search engine in vain. May be Gaieus knows something about it! 😉
          • G
            glro
            @aerilius said:
            i added some code to yours at the end of "self.save_as(filepath)" method
            filepath2 = (filepath.split("/")[0..-2]).join("/")
            nom_model = m.title
            # name of the text file to put the shortcut in
            nom_bat = filepath2 + "/" + nom_model + ".bat"
            #open this file
            aFile = File.new(nom_bat,"w")
            pathmodel = m.path
            #write the file shortcut
            aFile.puts("call "+pathmodel)
            aFile.puts("end")
            aFile.close
            a black cmd window is opened... must be closed manually, unless you embed the .bat file in a .js file...
            it is basic but it works...
            • simon le bonS
              simon le bon
              Sorry to disturb the coding discussion 😕
              Ae_Snapshot tested with Su7 : love this plug 👍 👍
              (Png transparent background option still don't work - - )
              simonlebon
                Aerilius
                I forgot to mention: the transparent png option has only been added to SketchUp 8.
                I'm working on a new version!
                • G
                  glro
                  > nom_model = m.title
                  > #open this file
                  > pathmodel = m.path
                  > aFile.puts("end")
                  > aFile.close
                  Doesn't work if there is a white space in the file address
                  additional code is needed
                  nom_bat2 = nom_bat.to_s
                  if nom_bat2.count(nom_bat2, " ") != 0
                  UI.messagebox("no white space in the file address")
                  fail
                    Aerilius
                    I updated the plugin. I think it will now fit all your needs because you can now make your own buttons 😉
                    @glro, can you test if the shortcuts work as expected?
                    • G
                      glro
                      i tested, but there might be a problem
                      no box is opened on my scree when i check "ae snapshot" in the menu
                      it might come from the html file
                      in the pop up windows you show in the first message of this thread, i read "create a shortcut"
                      but when i click on the html file in "ae_snapshot" folder, i don't see the same things
                      html settings differences
                        Aerilius
                        I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
                        You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
                        Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
                        • G
                          glro
                          yes, the setting dialog does not appear;
                          the gear icon does'nt appear either...
                          just a small reactangle where i cannot click ...
                          how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
                          my guess is that it is linked to the problem
                          snapshot icon
                          • srxS
                            srx
                            Very useful! Thank you very much.
                            www.saurus.rs
                              Aerilius
                              @glro: Does " Sketchup.write_default("Plugins_ae", "Snapshot", "{}")" on the Ruby Console and restarting help?
                              (There are no relevant differences in the htm file.)
                              (By the way, you don't need quote the message, I know it's on the same page one above 😉 )
                              • G
                                glro
                                OK
                                yes it helps
                                when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
                                but i cannot save the parameters (clicking on "OK" doesnt change anything)
                                i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
                                thank you
                                  Aerilius
                                  @glro said:
                                  yes it helps
                                  That is good!
                                  Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
                                  • G
                                    glro
                                    when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
                                    The plugin does take a shot when i click on the button
                                    but i cannot get the snapshot settings windows on the screen anymore
                                    it may be because of my computer, if i am the only one to have this problem...
                                      Aerilius
                                      I am very sure it's not your computer. I couldn't find anything on my own.
                                      This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
                                      • G
                                        glro
                                        no, nothing in the ruby console
                                        it is an error message when sketchup loads all the plugins
                                        no numbers
                                        erreur chargement
                                          Aerilius
                                          Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                                          load "ae_Snapshot/Snapshot.rb"
                                          • G
                                            glro
                                            Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                                            Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                                            • 1 / 4
