    Dividing an edge
    20 Posts 6 Posters 971 Views 6 Watching
    • massimoM Offline
      massimo Moderator
      You did not write in the image that I should take move tool
      Sorry rumcajs have you read the point nΒ°5 ❓
        rumcajs
        I think I will never understand it this way. It is too hard
          rumcajs
          I've succeed to do it. Thanks.
            Do you know how to make guidelines with the Tapemeasure tool?
            If so then steps 2 & 3 simply explain that and should be obvious to you. πŸ˜•
            You pick two points and a guideline is made passing through them - always provided that they are not vertices [ends] because then guide-points are anticipated...
            This is the 'general case'.
            In this particular case that was illustrated dragging away from the picked edge off and then back onto itself would have the same result, because the guideline is parallel to that edge anyway.
            However, you've missed the point entirely: it was about making a copy using the Move tool +Ctrl and converting that into an array where /n adds copies equally spaced between the original and first copy [or with *n that adds copies after the first copy at the same spacing] - which is a technique that you should already know... because I explained it to you in another thread a few days ago πŸ˜’
              rumcajs
              ??? Where did you speak about converting into array? I heard this first time.
              I used to use guidelines only when I need to make copy of some guideline, I did not have need to copy it onto itself ever. Therefor I did not see sense in it.
              • BoxB Offline
                  Perhaps if you stepped back, carefully considered what is being explained to you, and tried to understand it you might grasp it... [reading the Help files would also boost your chances of success...]
                  When you make a copy of any object using Move [or Rotate] by pressing the Ctrl key modifier, and then type /n or *n to make more copies, either between the original and the copy, or added on after the copy, the normal parlance is that what is made is called an 'array'... you make a 'linear array' with Move, or a 'radial array' with Rotate...
                  The possibility that the exact word 'array' was perhaps missing from some earlier explanations about making multiple copies does not detract from its efficacy in any way... πŸ˜’
                    rumcajs
                    I don't remember any description of you in the past. But if it would be there, I doubt I would be able to grasp it in the times of my very beginnings (too much information goes out of my head). I will watch the array tutorial if the right time will come.
                      Jean Lemire
                      Hi rumcajs, hi folks.
                      See this SU file for ideas.
                      Dividing a rectangle.skp
                      In your post, you mention that you will look at the video when the time will come.
                      IMHO, this time has come.
                      I strongly advise you to look at all the beginner videos on SketchUp site and that you take the time to read the help about the tools on which you have questions. For example, the Move tool with its copying capabilities.
                      Believe me, the few hours that you will spend doing that, will be much less than the many hours that you will spend here, asking questions and discussing the received answers.
                      Just ideas.
                        rumcajs
                        After some time, I'm back with the same problem. I was trying cca 60x and then came here... and now I tried the same as in the images and... does not work. Why? Maybe you could just add one more detail to the image (copy and CLICK). So when I tried just "move the copy and position and then type" or "copy, move and type and then click", it does not work. So now I understand that I must "move the copy, position, CLICK, and then type..."
                        BTW: Why did you decolored the icons of edit box? This looks so ugly and bad for orientation.
