    Changing UI / Toolbar colours
    20 Posts 12 Posters 8.5k Views 12 Watching
    • philemP Offline
      philem
      Hi Guys
      Is there a way or a plugin that would allow me to change the colour of the UI and toolbars, I would prefer a gray or darker colour as opposed to the stark white?
      Thanks in advance
      Just do it, it might be fun.
        Can you update your profile to display the OS , SU version?
        To answer your question from a WIN7 user you can play with your theme of Windows itself. But no way to change to just the colour of SU on its own AFAIK.
          Aerilius
          There are two ways:
          The easy way is to use the Windows classic theme (which is vector-based, and in advanced appearance settings you can redefine background/border colors).
          The alternative is to jailbreak Windows, install a system file (uxtheme.dll) that allows unsigned themes and install a theme from here (Win7 | XP).
          This is system-wide and not application-specific (I don't know whether/how that would be possible, maybe Dan knows how).
          For OS X, maybe driven knows how.
          • Dan RathbunD Offline
            Dan Rathbun
            UI interface elements are supposed to be styled on a system-wide basis.
            Applications are supposed to rely upon the system to style the UI elements.
            Why would application developers want to waste the time and money programming custom UI styling per user settings into their applications, when this is already a feature of most operating systems?
            Why would users in general want to be forced to setup UI styling for each application?
            The issues the original poster is dealing with are due to the Windows 6+ default UI theme (which tries to make the native system look like it's all webpages. I hate this myself. This is how malware fools people into doing bad things. I want to know when I'm on the web, and when I'm seeing a native interface window.)
            I suggest the OP make complaints somewhere on a Microsoft site, and perhaps MS will get the message.
            I'm not here much anymore.
              Aerilius
              I absolutely agree with that. Applications should not mess around or fight against the user-prefered system theme. Applications that try to "look good" by overriding the system theme make the overall appearance kludgy, cheapish and confusing.
              Some people prefer for some reasons (?) darker colors in photo-editing or multimedia programs. Some operating systems offer a switch so that an application can request a dark/bright variant of the system theme. But that all won't help for SketchUp here...
              • wenclavW Offline
                wenclav
                Hello,
                I would like to share my settings for GUI for Windows7/Sketchup/Vray/Ps. I feel what you mean and maybe you will find them useful.
                As an architect, I'm recently responsible for modeling, rendering and post processing and those are settings born during my practice. First of all my main goal was to eliminate white stark skp glow from two panoramic screens I'm working with. I'm a big fan of dark themes almost in all cases. I wanted to create a perfect combination for OS and those three applications to make my pipeline harmonious and teardrop free.
                Start with switching to windows classic theme as was said above. Go to window color panel and change almost everything to dark grey (in my opinion the best option is to take the exact dark grey color from dark photoshop theme). Leave active/inactive window option to black (no irritating gradient), all fonts and hyperlinks to whites or creamy whites, selections to oranges (somehow modo inspired). Tips set to white on black. You may also want to experiment with font sizes and types, I left them default. The only flaw I found is in vray frame buffers color panel. Grid for curves is invisible, they are set to dark grey by default and is not OS variable. But you can live with that once you learn them.
                Second step is working on dark styles in Sketchup. I recommend  slightly modified Generic Cad style built in skp. Switch off the ground and make background dark grey (slightly brighter than toolbars), change the front color of faces to white and back color to any bright color you like (I use light blue). Change the lines for all model to black (white is sometimes disturbing imho) I also changed locked object styles to red. Grids for oranges. Thats all, everything works really great for me. You feel like working on one big application :smile: Hope you will like it.
                Cheers
                example
                • N Offline
                  noro
                  @wenclav said:
                  Hello,
                  Cheers
                  Very nice, but I have no idea where to change it 😞. Could u explain it step by step plz?
                  • N Offline
                    noro
                    Could u share your settings? πŸ˜„
                    • N Offline
                      noro
                      Ok, I got it - sorry, I thought it's somewhere inside SU code πŸ˜„
                      • Bob JamesB Offline
                        Bob James
                        How did you get the SU toolbars to change?
                        • jenujacobJ Offline
                          jenujacob
                          yea... how u do that????? 😲
                          • BoxB Offline
                            You have to change the style of your Operating System, it can't be done in Sketchup.
                            • V Offline
                              Vicspa
                              Can you guide us through it? let's say Windows 7
                              • BoxB Offline
                                Wenclav's post above explains how to do it.
                                You are simply changing the settings in a windows theme.
                                Right click on your screen and select personalize to get to the themes settings.
                                You can create a specific SU theme that you can save and switch to when you want it.
                                • V Offline
                                  Vicspa
                                  OK, I got it, thanks.
                                    Bob James
                                    I did that, but nothing I did changed the toolbars. What did I miss?
                                      Bob, the toolbar buttons won't change with the themes because they are PNG files. They are like any other PNG file you might have on your computer and would be unaffected by the change to the background. If you want the buttons to match your chosen background color, you'll have to edit them.
                                        Bob James
                                        Thanks, Dave: Not worth the effort πŸ˜„
                                          I don't think so, either. πŸ˜‰
                                          Don't you ever sleep?
                                          • E Offline
                                            Einstein
                                            I know, the thread is oldish but maybe someone will find my little research helpful. I found a theme based on Windows Aero which looks neat and it's quite dark. So dark that you may even find some icons hard to see. But anyways I prefer low contrast brought by this theme. A lot more comfort to the eyes. If you share my love for dark GUIs, check this out and follow their instructions:
                                            ERROR: The request could not be satisfied
                                            (www.deviantart.com)
