    Fiat Punto MK2a (picture heavy)
    24 Posts 14 Posters 6.2k Views 14 Watching
    • sh00ksS
      sh00ks
      Had some time off the last couple of days and spent them fully on the model.
      Finished nearly all the detailed stuff what you can see from the outside.
      http://farm9.staticflickr.com/8163/7513598412_a28170130c_b.jpg
      sh00ks HGT 01_16 by sh00ks, on Flickr
      http://farm9.staticflickr.com/8143/7513598968_0c7d9aa68d_b.jpg
      sh00ks HGT 01_11 by sh00ks, on Flickr
      http://farm9.staticflickr.com/8024/7513598718_7d3856cb4e_b.jpg
      sh00ks HGT 01_13 by sh00ks, on Flickr
      And then, setting up the rendermodel ๐Ÿ˜Ž
      I thought building the car was a tough job, well, getting all the materials and lighting the way you want it (and I'm still a noob in rendering, so most of the time I don't even now what I want ๐Ÿ˜ณ )
      But here we go, My Punto HGT digitalized
      http://farm8.staticflickr.com/7127/7513574268_3b88186635_b.jpg
      Loadingdock 01_1.0 by sh00ks, on Flickr
      http://farm9.staticflickr.com/8152/7513573260_bf94363666_b.jpg
      Loadingdock 02_2.0 by sh00ks, on Flickr
      http://farm9.staticflickr.com/8282/7513571880_f74aff8900_b.jpg
      Parking Garage 01_1.1 by sh00ks, on Flickr
      http://farm8.staticflickr.com/7137/7513575674_418c1914d4_b.jpg
      Industrial Hall 01_1.0 by sh00ks, on Flickr
      [url=http://www.flickr.com/photos/sh00ks/7513572190/:3sxnnuco]
      http://farm8.staticflickr.com/7269/7513572190_2e1fc7829d_b.jpg
      [/url:3sxnnuco]
      [url=http://www.flickr.com/photos/sh00ks/7513572190/:3sxnnuco]Logo 01_1.0[/url:3sxnnuco] by sh00ks, on Flickr
      What say yee?
      • Bryan KB
        Wow! Well done!
        Would you explain more about the plug-ins, please. I'm already considering buying Artisan, but you also mentioned Tools on Surface?
        • soloS
          Great stuff, Thea render?
          • sh00ksS
            sh00ks
            @bryan k said:
            Wow! Well done!
            Thx!
            Tools on Surface is a free plugin and makes you draw lines on connected curved faces, wich makes it way more easy the the standard SU linetools. Check the topic, give it a quick search ๐Ÿ˜‰
            When did I used it in my model?
            To make detailed components on an object. E.g.: When I completed the general outline and shapes of the door, I used Tools on Surface the put in the doorhandle and -lock.
            I would also strongly recommend to get the modelingbooks from Elisei, if you're thinking about picking up carmodeling ๐Ÿ˜‰
            It has a nice promo on it right now Click Me!
            • sh00ksS
              sh00ks
              Thea all the way, yes ๐Ÿ˜„
              • sh00ksS
                sh00ks
                512 views, 12 posts....don't be shy ๐Ÿ˜†
                Let this project rest for a while, but tend to start soon on the interior as the standard interior is and then a race interior (rollcage, stripped, etc.).
                Little render on a dreamed of colour
                http://farm8.staticflickr.com/7135/7544519938_40daaac3d0_b.jpg
                Testroom 01_2.0 by sh00ks, on Flickr
                • hellnbakH
                  hellnbak
                  Wow, another car modeler!!
                  Incredible work, well beyond my capabilities. I have a lot of problem getting the surfaces smooth enuf. I spend way too much time on that, and at best the results are only barely acceptable.
                  A question about Artisan -- you seem to go from about a zillion polys to a much more reasonable number, how do you do that? I have tried Artisan (without success) a number of times. If I could get it to work (without getting such a huge number of polys) it would help me enormously. The only thing I use it for nowadays is the Select Brush, which by itself is well worth the purchase price.
                  Also, on the same subject, how the heck do you get it to work on an object without affecting the edges of it, shrinking it all out of shape?
                  Please edumacate me, my mind is a void, fill it with knowledge ๐Ÿ˜’
                  Again, very nice work ๐Ÿ‘
                  • sh00ksS
                    sh00ks
                    Thx ๐Ÿ‘
                    Your problems with smoothing the surface/lines is not unknown to me. The only thing I can say on that subject: don't give up and try, try and try again. A 'bit' of patience is the only must have ๐Ÿ˜„
                    Did you tried the e-books from Elisei?
                    They help a great deal and brings alot of light in de darkened world of car-/organic modeling ๐Ÿ’ญ
                    Do you mean from this
                    http://farm8.staticflickr.com/7099/7358497392_311286e4ef_b.jpg
                    to this
                    http://farm8.staticflickr.com/7098/7358497214_c144edd879_b.jpg
                    If so: I don't ๐Ÿ˜„
                    I build it all in the 'simple' style and SS it from time to time to check the progress and results and then undo (ctrl-z is your best friend ๐Ÿ˜„ )it.
                    Before EVERY SS action I save my file (save copy as...), cause you never now if SU may crash or not ๐Ÿ˜ฎ
                    I also make a variety of files with different functions, so they don't bite eachother. I.e. a file for building in simple meshes, a file for the SS'd parts and a file for the SS'd parts wich need altering like lowering/tilting/painting.
                    Every line you want to become/stay an edge after SS, you dubbelline it ๐Ÿ˜‰
                    See pic below and look carefully at the edge from the cover and you'll see it's dubbellined.
                    The closer the two lines are together, the sharper the edge will be.
                    Hope this filled a bit of void in that great thinking machine of yours ๐Ÿ˜„ and keeps you challenging using Artisan and become a great carmodeler โ—
                    • emerald15E
                      emerald15
                      You want more posts? I think we're just in awe! I don't know whether to be inspired or demoralised. ๐Ÿ˜† I keep trying to understand car modeling as I have a client in the automobile industry, but I never get very far. If I could model to even half this standard it would be helpful in my work. It's not actually that I don't understand the tutorials, it's that it gets so complicated that I lose my way. Its such a pleasure scrolling through your images of the process seeing how you tackle each part. You mention Elisei's book - did it help? Perhaps I should start reading. I ask pretty much the same questions as hellnbak, (particularly regarding getting a smooth finish). Incidently, hellnbak - fan of your work too... can't beleive you manage it without Artisan!
                      • sh00ksS
                        sh00ks
                        ๐Ÿ˜ณ ๐Ÿ‘
                        The main reason why I'm posting my WIP is to inspire others!
                        If I, a 'simple' ICT-guy, can do this, imagine what you as a designer can do!!
                        As is said before, the only ingredient needed is patience ๐Ÿ˜„
                        And if I can help in any way, please let me know ๐Ÿ˜‰
                        I highly recommend them! Elisei has a good/clean way of explaing by word and picture. It also comes with a video of the work, so you can see him doing it.
                        When you work and study by his tutorial, you will see you'll get grip of techniques en alter/improve them to your own style.
                        Imho this is the best way to learn.
                        Do give it a try ๐Ÿ˜„
                        +1!
                        • olisheaO
                          olishea
                          spectacular work! the details really shine in the renders ๐Ÿ‘
                          oli
                          • sh00ksS
                            sh00ks
                            Thx Olishea!
                            • CarlohC
                              Carloh
                              i really love this model!! ๐ŸŽ‰ i just bought elisei's book about car-modelling and i hope that i will be able to do such beautifull modelling some day soon (i'm estimating somewhere between five and ten years ๐Ÿ˜„ )
                              • sh00ksS
                                sh00ks
                                Real good move on buying Elisei's e-books ๐Ÿ‘
                                And thx for the compliment!
                                • L
                                  liam887
                                  Great
                                  Now make a spaceship or robot ๐Ÿ˜‰
                                  VISIT MY ONLINE GALLERY
                                    jpalm32
                                    Real nice work.
                                    Hopefully this will inspire hellnbak to start some great renders SOON!
