    Capturing different views of same model.
    layout
    27 Posts 9 Posters 6.9k Views 9 Watching
    • T
      Tasman
      G'day Bert
      Thanks for your tip, this is really a very smart way of hiding the dimensions in LO, much better than my method of creating Layers. Works like a charm.
      Regards
      Tasman
      • G
        Gidon Yuval
        Thank you so much guys!
        I used a little of each tip and I am very happy with the results.
        There are a couple of issues that came up while I was playing around with all your suggestions.
        1.I found that making a template for myself is easy enough but LO only brings it up for the cover page. Inside pages start off completely blank. I found a work-around whereby I duplicate the cover page a number of times and then insert the appropriate scene or scenes on each page.
        I imagine there's a way of making LO use the template for ALL the pages but I haven't found it.
        2.For new page I have to go to File>insert>the model in question. Then I go to the scenes box and choose the one I want. I have to go through this every time I want to add a scene. Is there a tool that I'm missing that'll shorten the process?
        3.How do I control the size of the printed area? After I put several items on a page I wanted to see what it would look like if printed. To my surprise the print preview showed that not all of the LO page fits on the printed page. I chose an A4 paper size but some of the ellements close to the edges don't show up in the preview. How do I overcome this?
        Is there a difference between a LO A4 and an actual A4? This problem is even more acute when trying to use A3.
        Sorry for the long post but LO looks like it's going to be an important tool for me so I'd like to make the most of it.
        If you don't know where you're going, you're never going to get there.
          Gidon, I sent you a PM regarding your questions.
          • GaieusG
            Hi Gidon,
            1. As for templates with cover and inside pages, start a pre-made template to explore first; how it is built up, what layers and kind of pages it has. To create your own template actually an existing one is the best and easiest to use as well. If you have a look at the screenshot attached, notice the Layers in the Tray; how there are layers which appear on every page (these are generally locked by default so you won't accidentally modify them on any page).
            2. As for adding scenes; once you inserted your model (which has scenes), you can easily copy the inserted "Model window" and paste it into several pages in LO. Now if you click on any of these model instances on a page, at the SketchUp model in the tray, you can select which scene to show o0n that particular page.
            Well, maybe there is (should be) and option, when sending a model to LO from SU to create pages from the SU scenes automatically so that you don't need to do this manually. But even this way it's not that big deal actually.
            1. Note that in a LO model, there are two settings under the Files menu; Document setup > Paper... and Page setup. If you want to use an A4 paper for printing, make sure both are set accordingly and properly.
            And yes, from what Dave is using LO for instance, it is perfect for Woodworking drawings. Architects may be tied to certain conventions LO doesn't properly provide but thank God woodworkers (and archaeologists πŸ˜’ ) are more flexible
            • GaieusG
              Oh, Come on, Dave, this is not fair. We also wish to suckle on your wisdom!
                😳 πŸ˜† wisdom? me? 🀣
                I showed him with a "live" demo. Figured it was easier than writing about it but I basically showed him the same stuff you wrote about. πŸ‘
                • G
                  Gidon Yuval
                  Dave hi,
                  I can't thank you enough for helping me with getting started in Layout.
                  That on-line lesson you gave me via Skype was amazing.
                  Thank you so much.
                    Gidon,
                    It was certainly my pleasure. I'm glad it helped.
                    Cheers,
                    Dave
                    • pbacotP
                      On the print preview issue. LO sets a print size based on the template you chose. The printable area for this template may not be supported by your printer, or you may need to choose an option such as "borderless printing".
                      I find by default with a new setup, the paper chosen by LO (in Mac) is not associated with a printer in the Page Setup. The page size IS specified. It could be standard printer size but you have to check it with your printer and the supported print area available. I'd save a template that works best with your printer, once you get it working.
                        Wow, Peter, this is an old one you've dredged up. πŸ˜„
                        • pbacotP
                          How the.....???? 😲
                          Never too late to be helpful πŸ˜› or is it?
                          I have NO idea where I came across this.
                            Nope. It's never too late. πŸ˜‰
                              mwm5053
                              Well it had some good pointers though.
                              2011 iMac
                              SU 2015 Pro, 2017 Make
                              V2 Twilight
                              macOS Sierra 10.12.5
                              • GaieusG
                                @pbacot said:
                                ...Never too late to be helpful πŸ˜› or is it?...
                                Never. πŸ‘
                                πŸ˜„
                                • 2 / 2
