    Mapping texture to a curve
    8 Posts 4 Posters 597 Views 4 Watching
      pompeyfan
      Should be pretty straightforward. As seen in the attachment, I have a curved shape (it is flat but curved) and want to position the texture so that it follows the curved shape as opposed to the current rectangle. Any advice or do I need to divide the curve up and position it section by section?
        Hi Jay,
        There are a couple of plugins you will need but with them, it is not hard at all. Here is a tutorial on how to do it: http://forums.sketchucation.com/viewtopic.php?f=18&t=34072&p=299717
        (There I subdivided the going-to-be arch into as many segments as many bricks I had in the row but you need not deal with this part and FredoScale can also subdivide it for you - the more segments, the smoother it is at the end)
        Then, of course there is a cool UV Mapping plugin, too, see here: http://forums.sketchucation.com/viewtopic.php?t=44501
        • ely862meE Offline
          ely862me
          Hi !
          I would use this http://forums.sketchucation.com/viewtopic.php?t=18992 and this http://forums.sketchucation.com/viewtopic.php?t=17948 .
          First import the texture then divide it in small rectangles and hide the lines,then use the UVToolkit to remember the texture position,then use the Fredoscale to curve the surface then use the UVToolkit to restore the texture .
          Cheers !
          Edited
          [off:2bdkj3jj]To Gaieus : Ahh, why you have to be the first all the time ?? Actually I would have been the first but I had to get the picture too ! 😎[/off:2bdkj3jj]
          Elisei (sketchupper)
          Come and See EliseiDesign
            [off:39fq7pv6]Because I have already made the images (in that tutorial) so it was easier to simply link to it. [/off:39fq7pv6]
              pompeyfan
              Interesting, UVToolkit will not show up in my sketchup. It looks all good in the plugins folder, the required plugin (TTlib2) is there, but it won't show up in sketchup
              EDIT: Disregard. It is in the plugins window, not right-click. Need a break, I think. Will report back with results.
              • massimoM Offline
                massimo Moderator
                Or you can use this plugin.
                Follow the modeling steps as suggested by Gai & Elisei and then texture the surface with Fredo's "ThruPaint".
                  pompeyfan
                  Thanks everyone. Was still having trouble getting UVToolkit to remember and restore UV, but massimo posted the perfect plugin - 1 click and it worked. Was also probably benefited by the fact I already had the necessary shape. Thanks very much, as promised, the finished result
                  • massimoM Offline
                    massimo Moderator
                    πŸ‘
