    [WIP] '69 Dodge Charger
    102 Posts 17 Posters 32.3k Views 17 Watching
      If you shared the plans we could all have a go
        The only plans I have is the low res scan from the model kit in the first sample model I posted. But that doesn't give that much insight to the shape of that door. The perspective photo of the silver car shows the detail lines the clearest.
        • andybotA Offline
          andybot
          It's a good thing my son and an uncle love car shows. I looked through some of my photos, and there is a dodge charger that shows up at a local show pretty regularly. Here are two pics I could find of it.
          Andy
            πŸ‘ πŸ‘
            That's great Andy! That's some nice photos that shows this particular door. Looks to be the same or very similar model.
            I tried to contact the AMCAR club in Trondheim - asking if there was any '69 Dodge charger owners around. But no reply as of yet. 😞
            Might have a look in the car ads - and if I find one go and sample some photos. I really want to grab more references for the engine bay and chassis and interior. (yea... I always go all in when I start a project... 😳 πŸ˜’ )
              rv1974
              there's 2 gb max Max model of Charger already on the web. Unfortunately it's not '69.
              http://i40.tinypic.com/24xj98l.jpg
              • panixiaP Offline
                panixia
                i found this:
                http://area.autodesk.com/userdata/forum/6/69charger.jpg
                but i'm realizing i'm not good at all.. damn car! 😑
                  @panixia said:
                  i found this:
                  Hey! That's the same drawings I got - just a whole lot higher resolution!
                    I'm seeing the door as three surfaces.
                    The red lines are the loops that separate the surfaces.
                    The blue lines are the crease lines.
                    I'll start with the red loops, then build the crease lines and finish off with the "scoops". At least - that's my plan of attack now.
                    • panixiaP Offline
                      panixia
                      i see only crappiness at the horizon.
                      if only there was an international crappiness contest i would have been the champ..
                      because ever attempt i do is crappier than the crappiest one achieved before. 😐
                        Bit of clean up to do but an interesting challenge. No creases added all controlled by loops and whatnot.
                        [xxl-img:1lhc91mo]http://i.minus.com/iBpzj8HmgIqBr.png[/xxl-img:1lhc91mo]
                        • panixiaP Offline
                          panixia
                          how did you achieve the middle version (smoothed+quads) in sketchup?
                            QuadFace Tools > Smooth Quads
                            • panixiaP Offline
                              panixia
                              maybe you would say "unsmooth quads", ok, but i didn't mind that..
                              i'm guessing how do you manage to have a so clean quad mesh after subdivision in sketchup .. 😲
                                Luck πŸ˜‰
                                • panixiaP Offline
                                  panixia
                                  ah ok, i was wondering if you exported to blender or used some modeling trick or cleaned it by hand or something like this.
                                  so.. luck.. πŸ’š
                                    69 Dodge Charger.skp
                                    Here my version
                                      That's a two iteration subdivision you did there, right?
                                      That seem to generally produce a smooth enough result for most cases - certainly enough polys.
                                      • ely862meE Offline
                                        ely862me
                                        I tried a bit the shape, if you know well the real shape it shouldn't be hard, at least not how I work.
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                        • ely862meE Offline
                                          ely862me
                                          Better one ..
                                            1 😲
                                            • 4 / 6
