    Woodwork through the roof
    14 Posts 5 Posters 410 Views 5 Watching
      scandale
      I would like to know if my problem is known and if there is a solution.
      I can see the woodwork through the roof if I step back the view.
      With a closer view, I can't see it (normal behavior).
      It happens even with a tickness on the roof.
      I can add screenshots if it's not clear.
      Thank you for your help.
        Perfectly normal. It's an OpenGL display quirk.
        Export a 2D image and you'll see it doesn't appear
          scandale
          I though it was an OpenGL issue but it happens even with OpenGL disabled.
          Good idea for a 2D export, I just tried, it's a bit less visible, but present.
            scandale
            Thank you for you answer. It still present with OpenGL disabled and it also appear on 2D PNG export, just a little bit less visible.
              What happens if you export at a higher resolution? (Check the export Options at the bottom right).
                scandale
                As the resolution increase, it disappears. There are still some traces with a x2 factor, almost ok. With a x4 factor, no more traces.
                  This is (so to speak), "normal". Edges are always 1 px thick on screen (and in exported images). When you have a certain thickness of your roof (tiles for instance) and you are close enough, this thickness will be bigger than 1px on screen but as you zoom out, it will become thinner and thinner with the distance and eventually edges below will "bleed through".
                  You can work this around by exporting at higher resolution, hiding those roof structure woodwork in scenes where you are looking at the full building from outside, hiding the top edges of the beams etc. But all these are just workarounds as (like it was said above), the OpenGL display has its features and limitations.
                    If you don't want to see the structure under the roof on screen, put the structure components/groups on a layer separate from the roofing tiles, shingles or whatever. Then just turn that layer off when you're looking at the roof from the outside.
                      scandale
                      Thank you for your answers, i'll do that !
                      It's already a component, i'll hide it until I need it and until that glitch has been fixed.
                        There's no glitch to fix.
                          scandale
                          It not an expected behavior, so it's a bug if you prefer. πŸ˜’
                            It's not a bug or a glitch or some weird SketchUp-esque anomally. It's just the way OpenGL works within SU's rendering engine.
                            You can't fix what is not broken.
                              It isn't a bug just because you didn't expect the behavior. πŸ˜’
                                tim
                                Y'what! If it doesn't work exactly the way I want it to, that's a bug.
                                Why yes, I am the centre of the 'verse, thank you.
