    Need help creating an compoud inside ellipse shape surface
    27 Posts 5 Posters 1.5k Views 5 Watching
      You could also do this quite simply with the native tools.
      Start with the ellipses in the same plane with face between them.
      Select one ellipse and move it vertically in the required direction making sure you invoke AutoFold with Alt on the PC or Command on the Mac.
      Type the offset distance and hit Enter.
      Ellipses.skp
        πŸ‘
        • O Offline
          osage
          Hey thanks guys.
          Yea, I did it already by hand ..triangles and such..100 endpoints...what a pita. Maybe you know a better/faster way. I'm certainly no SU expert so that's why I came here. To learn. Btw, after I drew this(concept) the overall height dimensions changed because of field dimensions...so whole new curve. Thanks, I'll try the plug. Mucho appreciated Gaieus.
          fitZ
          • O Offline
            osage
            OMG..I just thought of a way in one move. DUH! Man, hindsight sucks some times. πŸ’š Thanks again.
              Beauty of the simplicity! 😎
                @3ddetailer said:
                Hey thanks guys.
                So you didn't bother to read my instructions? πŸ˜’
                My way is better and faster than your triangles.
                  @dave r said:
                  @3ddetailer said:
                  Hey thanks guys.
                  Read more, Dave...
                    I saw that. πŸ˜’
                    • O Offline
                      osage
                      😳 😳 😳 OMG...DOH! I apologize..somehow I missed them. Thank you...mine did NOT work anyway. Just tried it. Ok, I'll pay attention next time. I must have scrolled down too fast. Again...my apology.
                      note to self..Read EVERTHING..SLOWLY. πŸ˜†
                        No problem. πŸ‘
                        • O Offline
                          osage
                          Man, you guys are FAST! πŸ’š
                          Geezus...just read the instructions. Ok, that is exactly what I did...except for the "Autofold" part. Never heard of that. I use 8PRO...is that a standard tool? If so...
                          note to self..file under
                          "..DOH!"
                          Umm, could you please direct me to it? Thank you.
                          • O Offline
                            osage
                            Ok, just found a youtube tutorial on it. Thanks again.
                            rick
                              AutoFold is a function of the Move tool. It is common to both the pro and free versions.
                              Get the Move tool hold Alt on the PC (as I already said in my instructions) and move the selected edges.
                              You might find it useful to look at the bottom edge of the SketchUp window when you choose a tool. There's all sorts of useful information displayed there.
                                If you're going to ask questions, you could give folks a chance to answer them. πŸ˜„
                                • O Offline
                                  osage
                                  Hello again guys. Well, I don't understand what I'm doing wrong with this Autofold tool. I did exactly what the tutorial said, but this is the result I get. Twice. I'm clueless why this is happening, so I could sure use one. πŸ’š Thanks
                                    Are you selecting just the inside edge and moving it up? Doesn't look like it.
                                    From my instructions earlier:
                                    Select one ellipse and move it vertically in the required direction making sure you invoke AutoFold...
                                    I made my example doing exactly what I wrote for instructions.
                                    • O Offline
                                      osage
                                      Hello Dave, sorry bout all this. Well, according to the tutorial, you select the "move tool", hover over the inside elipse face, press "ALT", select the face and move it vertically on the Blue axis..which is exactly what I did. Twice. Am I missing something here? I watched the video two times just to make sure. Don't understand it. Nor do I understand what you mean by selecting the "inside edge". They didn't show anything about that. This is what I watched. http://www.youtube.com/watch?v=l2LoHllugqE
                                      fitZ
                                        You write
                                        but read better πŸ˜„
                                        Dave write
                                        select the Ellipse not the face of the ellipse! πŸ˜‰
                                          Pilou beat me to it.
                                          Try preselecting the inside edge before you get the Move tool.
                                          Again, do what I wrote.
                                          • O Offline
                                            osage
                                            Hi Guys. Ok, I've tried this over 10 times to no avail, using the same ellipse's, from which I originally drew circles, and then DIVIDED them into 100 segments, and then made them into an ellipse, and grouped each one separately, and then exploded as I needed to. These original ellipse parameters were defined by specific dimensions given by the designer as the outer edge of plywood plates. And these then define various parts, which I had to offset from these edges as some were either smaller or larger. After some experimentation, I discovered this process doesn't work on ellipse's that were formed in the sequence I described. Once you divide the circle, and then Scale them into ellipse's..the ellipse boundary, is no longer an entity. It is comprised of individual lines. I don't understand why, but it just doesn't "extrude" or move, correctly. It always has the flat planes at the ends.
                                            Which brings me to a question. Not understanding various SU technical aspects, can you explain something for me. For instance, if I draw a circle, by default(I believe) it is comprised of 12 or 24 segments, I don't remember. But it is a whole entity. That is, unless you explode it. By default, is this entity a POLYLINE?
                                            The reason I ask, since my original ellipses were composed of 100 separate lines, if I make them into a Polyline, the "extrusion" thing still doesn't work. Where as, if I don't divide the circle first, and then Scale them into ellipse's, and then "extrude/move" them, it does work. What I'm trying to find out is, how can you make the ellipse into many more segments, without it getting , well, for the lack of a better term...exploded. If I do not divide the circle first, the divide command(or tool) does not work on an ellipse. Any insight is appreciated.
                                            I haven't had time to try the plugin yet. I wanted to solve this puzzle first, as this was something new for me, and I see lots of other uses. Thanks for the patience and the help.
                                            fitZ
