    Need help creating an compoud inside ellipse shape surface
    27 Posts 5 Posters 826 Views 5 Watching
    • O Offline
      osage
      Hello. I am looking for a plug in or some method other than by hand, to create a suface similar to the inside of a bowl. I have two ellipses, one large, and a second in parallel planes, one, 16" higher than the lower, both centered on a common axis.
      I created the ellipses from a circle, which I hade divided into 100 segments, for smoothing sake. Here is what they look like.
      http://httpics.com/is.php?i=1825&img=Defining_Fabric.jpg
      http://httpics.com/is.php?i=1826&img=Ellipse_Fabric_.jpg
      http://httpics.com/is.php?i=1827&img=Fabric_Plane_Po.jpg
      I need this surface to represent a Fabric in a model of a very large ceiling fixture for a Recording Studio. I need this to check for various clearances and to illustrate the final intent for the Fabric installation company. Here is what the unit framing looks like, although it isn't finished by any means.
      http://httpics.com/is.php?i=1828&img=STYROFOAM_INSER.jpg
      The two ellipses are actually the two edges where the fabric stretches from and were taken from the actual framework pieces in the model.
      Any help would be appreciated as I'm sure there is some kind of plugin to do this. The "Follow me tool" is useless in this context as the curvature changes infinitely as you follow a path. I tried it. So, thanks for any insight.
      fitZ
      ps. I did search for any information but to no avail.
        There are many plugins - I made a quick (and low poly) example with Curviloft > Loft junctions.
          You could also do this quite simply with the native tools.
          Start with the ellipses in the same plane with face between them.
          Select one ellipse and move it vertically in the required direction making sure you invoke AutoFold with Alt on the PC or Command on the Mac.
          Type the offset distance and hit Enter.
          Ellipses.skp
            πŸ‘
            • O Offline
              osage
              Hey thanks guys.
              Yea, I did it already by hand ..triangles and such..100 endpoints...what a pita. Maybe you know a better/faster way. I'm certainly no SU expert so that's why I came here. To learn. Btw, after I drew this(concept) the overall height dimensions changed because of field dimensions...so whole new curve. Thanks, I'll try the plug. Mucho appreciated Gaieus.
              fitZ
              • O Offline
                osage
                OMG..I just thought of a way in one move. DUH! Man, hindsight sucks some times. πŸ’š Thanks again.
                  Beauty of the simplicity! 😎
                    @3ddetailer said:
                    Hey thanks guys.
                    So you didn't bother to read my instructions? πŸ˜’
                    My way is better and faster than your triangles.
                      @dave r said:
                      @3ddetailer said:
                      Hey thanks guys.
                      Read more, Dave...
                        I saw that. πŸ˜’
                        • O Offline
                          osage
                          😳 😳 😳 OMG...DOH! I apologize..somehow I missed them. Thank you...mine did NOT work anyway. Just tried it. Ok, I'll pay attention next time. I must have scrolled down too fast. Again...my apology.
                          note to self..Read EVERTHING..SLOWLY. πŸ˜†
                            No problem. πŸ‘
                            • O Offline
                              osage
                              Man, you guys are FAST! πŸ’š
                              Geezus...just read the instructions. Ok, that is exactly what I did...except for the "Autofold" part. Never heard of that. I use 8PRO...is that a standard tool? If so...
                              note to self..file under
                              "..DOH!"
                              Umm, could you please direct me to it? Thank you.
                              • O Offline
                                osage
                                Ok, just found a youtube tutorial on it. Thanks again.
                                rick
                                  AutoFold is a function of the Move tool. It is common to both the pro and free versions.
                                  Get the Move tool hold Alt on the PC (as I already said in my instructions) and move the selected edges.
                                  You might find it useful to look at the bottom edge of the SketchUp window when you choose a tool. There's all sorts of useful information displayed there.
                                    If you're going to ask questions, you could give folks a chance to answer them. πŸ˜„
                                    • O Offline
                                      osage
                                      Hello again guys. Well, I don't understand what I'm doing wrong with this Autofold tool. I did exactly what the tutorial said, but this is the result I get. Twice. I'm clueless why this is happening, so I could sure use one. πŸ’š Thanks
                                        Are you selecting just the inside edge and moving it up? Doesn't look like it.
                                        From my instructions earlier:
                                        Select one ellipse and move it vertically in the required direction making sure you invoke AutoFold...
                                        I made my example doing exactly what I wrote for instructions.
                                        • O Offline
                                          osage
                                          Hello Dave, sorry bout all this. Well, according to the tutorial, you select the "move tool", hover over the inside elipse face, press "ALT", select the face and move it vertically on the Blue axis..which is exactly what I did. Twice. Am I missing something here? I watched the video two times just to make sure. Don't understand it. Nor do I understand what you mean by selecting the "inside edge". They didn't show anything about that. This is what I watched. http://www.youtube.com/watch?v=l2LoHllugqE
                                          fitZ
                                            You write
                                            but read better πŸ˜„
                                            Dave write
                                            select the Ellipse not the face of the ellipse! πŸ˜‰
