    Getting the circle midpoint inference
    20 Posts 6 Posters 4.0k Views 6 Watching
    • massimoM Offline
      massimo Moderator
      Do you say, that I should select circle, take move tool and hover above edge, but no center point appears to me.
      Hover for a couple of seconds on the circumference than move the tool on the surface towards the centre and a snap will appear.
        rumcajs
        Over surface and towards center. I C. It works.
          rumcajs
          @pbacot said:
          To get the center point of a circle: hover with cursor over the edge (on the circle) then move to hover where center should be and a point will appear. To move first select the circle, then select
          It's too much information at once, I am not able to proceed it to my brain. I fail with first sentence. Do you say, that I should select circle, take move tool and hover above edge, but no center point appears to me.
          Edit:
          I originally understood
          that I should move the circle
            rumcajs
            I succeed to copy the circles with the array. Thanks guys.
            When you move/drag entity somewhere out of your actual screen, is it possible to make the mouse cursor to navigate aside, when I move on the screen edge? I have seen now that when I moved to right edge of screen, so it started to move/navigate me right (to the area which was out of my screen). But I cannot repeat this action. I usually navigate with mouse scroll and press and hold scroll button+shift (cursor hand to move screen). Which is a bit complicated, but if SU has simpler technique, that you just wait till the screen move itself, that would be good to know how to do it.
              rumcajs
              Does the circle midpoint interference work if I have made a component of the pylon? I cannot find the center point no, after I made component of the pylon. And now I want to copy the pylon same way as I did before, but I have selected component, not pylon in component... I hove over the edge of circle outside and then try to find center point.
                No, it only works on circle entities and now you are trying to infer on a component entity.
                There's another way. Under your Window > preferences > Extensions tab, activate "Extensions" (if I remember correctly - but to make sure, activate also "Utilities").
                Restart SU. Now if you right click on the circumference of a circle (that is not in a component again), there is a context menu item: "Point at center" which will insert a guide point into the midle. If you include this into the component too (or do this while editing the component), the guide point will also be part of that component so you can always move it with it.
                  rumcajs
                  I cannot find Extenstions extension but Utilities. When I enabled Utilities and clicked the edge of circle, did not find the item. I exploded the component before.
                    Rumcajs, the other day you could not find Sandbox there either. Have you reinstalled SketchUp as I advised back then?
                    Another question: is this still a circle? What does the Entity info (open from the Window menu) says about it when you select the perimeter (only)?
                      rumcajs
                      Sure. I use sandbox.
                      Arc - Radius 0,20m ; segments 24
                      I have the Utilities on.
                      • pbacotP Offline
                        Then it got cut and you have an arc or arcs instead. Still if you get the move tool and run the cursor on the arc edge without clicking (hover) then go towards the center you will get a point.
                        Gai-- I don't have a circle center tool in MY utilities. The "Query tool" there does like to find circle centers quickly though. Funny how some tools are "better" at it?
                        So now that you can find the center put a guide point there. Tape measure tool, hoover on circle or arc edge move to center, draw out from point that appears--on the blue axis a little ways. The "point" cross will not be right on the center (it will be directly above or below) but the other end of the short guideline will. Include the guide in the component.
                        I imagine you are then going to copy the component by alt-moving from the center to somewhere on a grid. If you set the component axis on that center you can load new components from the component browser to those grid points instead, using the axis insertion point. (Or just do an array as mentioned before.)
                          rumcajs
                          How does the Query work? Should I select circle and then run Query? And then make component?
                          • pbacotP Offline
                            No, that was just a comment regarding Utilities Extension that Gaieus mentioned. Query gives some information about objects. BTW to use the Utilities look for it under the Tool Menu. Sorry if that was confusing.
                            For marking the circle or arc center do as I note with the guide point (one way). Activating the Tape Measure tool to make the guide point, allows you to find the center point. Then make your component with the guide point in it. Myself, I would probably just set the component axis at the circle center instead, but it depends how you want to use it later.
                              rumcajs
                              So the only thing I should do is to insert guide point and then to make component?
                              So you also don't have the feature about which Gayieus spoke? Maybe it is part of SU Pro only?
                              • Jean LemireJ Offline
                                Jean Lemire
                                Hi rumcajs, hi folks.
                                The Point at centertool is available in SketchUp (SU) free as well as Pro.
                                To activate it, do this:
                                1 - Use Window menu --> Preferences --> Extensions. You will see many checkboxes in the rigth part of the dialog window. One of them in labeled Ruby Script Example. Click the check box to activate it. If it is activated, an X shows in the box. While at it, check all boxes to get all the tools.
                                2 - Exit the preferences.
                                3 - Close SU.
                                4 - Restart SU.
                                5 - Draw a circle.
                                6 - Right click the circumference of this circle to get a contextual menu.
                                7 - The last choice in this contextual menu reads Point at center. Choose it to get a guide point at the center of the circle.
                                This also works with polygons and arcs.
                                Just ideas.
                                  Actually isn't it...
                                  Preferences > Extension > 'Ruby Script Examples'
                                  To activate the Arc-Center-Tool...
                                    rumcajs
                                    RE:
                                    Jean Lemire
                                    after I drawn the circle? Do you mean click on surface? No such menu item there.
                                    To all:
                                    I'm having break from SU for few weeks or months. For that reason cannot to test it now.
                                    • pbacotP Offline
                                      @rumcajs said:
                                      RE:
                                      Jean Lemire
                                      To all:
                                      Thanks for letting us know.
                                      To reiterate what (some of us) found out for the first time: You need to go into Preferences/ Extensions and activate "Ruby Script Examples". Then when you right click on a circle or arc, the context menu has the item: "Point at Center". Clicking that you will give a guide point at center.
                                      Don't click on the surface, click on the circle shape.
                                      See also ThomThom's Guide Tools: http://forums.sketchucation.com/viewtopic.php?t=30506#p267835
                                      Enjoy your time away.
                                      [flash=560,315:i2vd4gq0]http://www.youtube.com/v/UPw-3e_pzqU[/flash:i2vd4gq0]
                                        Jean Lemire
                                        Hi Tig, hi folks.
                                        Sorry for the error, I edited my previous post.
                                        Thanks and best regards.
