    How to model this?
    18 Posts 7 Posters 920 Views 7 Watching
      I have made some therapies against use of plugins! πŸ’š
      I don't see any Bulge, it's only inclined segments between arcs πŸ˜‰
      Scale tool is the key! πŸ˜‰
      • HieruH Offline
        Hieru
        Not with the barrel bulge i.e. the curve from front to back........unless I'm missing something? I could be over thinking things as usual πŸ˜‰
        www.davidhier.co.uk
          Now remove SU6 from that old PC and go va-va-voom to v8
          • HieruH Offline
            Hieru
            To me it looks like two intersecting eggs with ribs running through them, so there is curvature inbetween each rib.
            Using native tools you could create the two 'egg' shapes, add the thickness of the ribs with the shell plugin and then intersect a series of rectangular boxes to create the ribs.
            www.davidhier.co.uk
              I don't believe that!
              It's just tensile structure between each rib πŸ˜„
              And yes after all structures draw an egg curve β˜€
              • HieruH Offline
                Hieru
                That's how I interpret it........chances are I could be wrong though πŸ˜„
                www.davidhier.co.uk
                  We're making progress!
                  Now, as Rich says, lets clear that V6 off your old computer and get you up to V8.
                  Maybe you need a virus on your old computer. This one ought to do the trick. 🀣
                  Ve haf yust sent you da "AMISH VIRUS". Since ve do not haf any computers and do not know how to actually damage your computer, dis Virus verks on da honor system.
                  Please forward dis Virus to eferyvone on your mailing list and den manually delete all of da files.
                  • mitcorbM Offline
                    mitcorb
                    Weren't there some legacy capabilities in v6 and v7 that you don't have in v8? Free or Pro?
                      Despite the fact that I want not install the V8 free on my old comput and no need
                      V6 free has some advantages with files formats that V8 free has not more! πŸ˜‰
                        You're right, Tim.
                        Pilou, you should have both.
                        • mitcorbM Offline
                          mitcorb
                          I wasn't trying to stir up any trouble, nor give Pilou any excuses.
                          Now, as for the shelter structure. I would most definitely try it with native tools first. What I see is progressive extrusion, scaling and either, pushpull or followme ribs by copied loops. Otherwise, Curviloft for the volumes, intersect them and so on. Those fundamentals die hard with me.
                          After all, I am only a little bit swifter than a brick.
                            But I have both but not on the computer linked to the Net! πŸ˜’
                            97% of the files posted here has no need of the V8 for read them! πŸ’š
                            • leedeeteeL Offline
                              leedeetee
                              Thanks chaps! πŸ‘
