    [Plugin] UV Toolkit
    377 Posts 86 Posters 382.2k Views 86 Watching
      sepo
      ENV.each { |k,v| puts "#{k.inspect} : #{v.inspect}" }; nil
      "PATH" : "/usr/bin:/bin:/usr/sbin:/sbin"
      "DISPLAY" : "/tmp/launch-MHvctR/org.x:0"
      "SSH_AUTH_SOCK" : "/tmp/launch-Vm9A84/Listeners"
      "Apple_Ubiquity_Message" : "/tmp/launch-bpbd2b/Apple_Ubiquity_Message"
      "Apple_PubSub_Socket_Render" : "/tmp/launch-33EI0M/Render"
      "COMMAND_MODE" : "unix2003"
      "IG_ROOT" : "/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"
      nil
        My suspicion is confirmed.
        But I don't understand - it gives no info about where the system temp path should be. ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜•
        Exactly what OS do you have?
          sepo
          Lion 10.7.4
            sepo
            Could it be because it is installed in the root? just guess.
              When you installed Sketchup did you accept the default folder location ?
              The ENV variable should contain lots of data - like your user-paths, temp/tmp folders etc...
                I have no idea. I'm not that familiar with OSX - but this is the first time anyone ever reported an issue like this. I've also never seen a complete lack of environment variables... ๐Ÿ˜•
                  sepo
                  Yes
                    sepo
                    OK, I solved problem now. I created the account and moved all software to that account and now everything loads fine so far. So it looks like Mac does not like when some stuff is installed on root. It seems to me it requires creating account.
                    Thanks for your help Thomas.
                      Well, I didn't manage to provide too much of a solution. I'm glad you worked it out in the end, because I was at a complete loss. Thanks for reporting back. I'm making a note of this that environment variables might be completely missing.
                      On a sidenote - I do generally think that running as root is not recommended out of security concerns.
                        sepo
                        Yes you are correct...lesson learned. I was just messing about as you can do more stuff from the root than from the admin account. It is interesting that all licenses did not transferred automatically I had to reinstall for Thea and license for Twilight was not recognised so I need another one. MS and Adobe went without hitch.
                        On the windows side I did not have any problems.
                        In any case you tried to help and that is appreciated. ๐Ÿ‘
                        • V Offline
                          vanman
                          I used the plugin to use the "Frontface Material to Backface", and it worked fine, but when I check for errors in SU, it says: "The front or back texture coordinates for CFaceTextureCoords (48) is not valid" for every face and when I click fix, it reverts to the way it was before using the plugin (no textures on the backfaces).
                          Any ideas? Or is this normal?
                          Thanks.
                            @vanman said:
                            Thanks.
                            I don't know without seeing the SKP file in question...
                            My FixReversedFaceMaterials flips faces and reuses the back-material that was incorrectly 'looking out' so it's now on the front-face that's now changed to be correctly 'looking outwards'... if you get my drift... try that and see if there are errors... ๐Ÿ˜•
                            • V Offline
                              vanman
                              Cool thanks. I'll give it a try.
                                Can you post a sample model please?
                                • V Offline
                                  vanman
                                  I've PM'd you.
                                  Thanks for the help.
                                    @vanman said:
                                    Thanks.
                                    Huh! That's odd. Don't know what's going on here. ๐Ÿ˜• Never seen that before - and the model looks to be fine. I'll have to investigate.
                                      Is there a very tiny facet that returns invalid coordinates, that are regarded as the same because of the 'rounding' of its very close vertex-points ?
                                      I just had a perhaps somewhat similar issue with my Octane Exporter [on their forum]... Someone has made a very small object that would have had overly tiny facets when created, if they hadn't scaled it up to process and then back down when done - the small facets can exists, it's just making them that's the issue. So far so good... now they exported it to OBJ format for use in Octane and there were tiny holes in the object when it rendered. Octane requires the OBJ to be in 'm' and have triangulated faces. In processing the meshes my tool uses the API methods to triangulate the mesh's faces. I now think that what was happening was that the triangulation of some tiny quad faces resulted in two triangulated facets that are so small that they have two vertices that 'round' to be at the 'same point' [the OBJ format is set to 'm' 6 d.p.] - therefore that new facet can't exist as its only a 'line' at best, and the two parts can then be missed, out leaving a small quad shaped hole when the object is reformed from the OBJ data...
                                      This could of course also mess with the tiny face's texture mapping ?
                                        It's a 1:1 scale building with textures...
                                          BUT might it still not have a very tiny textured facet somewhere that is thereby tripping things up ?
                                            I'm not finding any small faces...
                                            Sketchup.active_model.selection.each { |f| puts f.area }
                                            90921.1990251775
                                            8884.83094815197
                                            89096.7297450352
                                            8797.85733797857
                                            73856.383925685
                                            141994.698396594
                                            9102.23521971269
                                            12145.8874379084
                                            24291.7748758168
                                            72875.3920821179
                                            44959.9790473181
                                            14734.602162027
                                            17691.3311847609
                                            24392.7484579021
                                            30011.1066867323
                                            5913.42252781615
                                            106356.388178604
                                            34341.9813095441
                                            3545905.862747
                                            4551.09075463125
                                            141994.698396594
                                            50062.2342056662
                                            104443.19428945
                                            427926.997414128
                                            498.944000443444
                                            1387.04002680257
                                            555.234138673402
                                            1387.04002680257
                                            498.938868995756
                                            1387.04002680257
                                            555.228428303232
                                            1387.04002680257
                                            498.945026732981
                                            1387.04002680257
                                            555.235280747436
                                            1387.04002680257
                                            498.945026732981
                                            1387.04002680257
                                            555.235280747436
                                            1387.04002680257
                                            13652.9721252099
                                            153511.061835866
                                            543.299207966775
                                            1387.04002680257
                                            604.593436356126
                                            1387.03753654542
                                            27697.347044386
                                            4359.49237901717
                                            4451.34639743716
                                            4451.35947758332
                                            4451.35424552485
                                            4451.35424552485
                                            4451.36013159063
                                            4451.3599680888
                                            36670.6765526049
                                            4451.35362924216
                                            4451.35379274376
                                            4451.34790668637
                                            4451.34790668637
                                            4451.35313873738
                                            4451.34005860984
                                            4359.49925111979
                                            30024.5993279971
                                            67236.1596991253
                                            17251.2833128222
                                            21472.4971347198
                                            25566.7510791362
                                            128807.275064796
                                            493528.467044927
                                            23028.3607461373
                                            18401.0262709489
                                            130944.016437284
                                            511510.510285885
                                            22920.9833744596
                                            20675.3865149603
                                            125516.784053139
                                            9609.28530909866
                                            7391.72898352146
                                            7391.72898352146
                                            182.619508624077
                                            213.451079707593
                                            5652.52077005804
                                            5652.52077005804
                                            613232.018621877
                                            18262.0502714831
                                            9102.22363510579
                                            362053.963948095
                                            13639.6107236221
                                            23326.5092276735
                                            263054.266003366
                                            661.054059026763
                                            44600.8861230744
                                            75814.7493808884
                                            12669.2358815777
                                            35555.4855367881
                                            12669.2358815777
                                            8522.23635725677
                                            8522.23635725677
                                            668996.234413132
                                            543.287712531164
                                            1387.03753654542
                                            604.58207642406
                                            498.938121928659
                                            1387.03753654542
                                            555.228912425377
                                            1387.03753654542
                                            498.93825021456
                                            1387.03753654542
                                            555.229055184646
                                            1387.03753654542
                                            498.937737070955
                                            1387.03753654542
                                            555.228484147571
                                            498.942868507002
                                            1387.03753654542
                                            555.234194518316
                                            1387.03753654542
                                            498.937737070955
                                            1387.03753654542
                                            555.228484147571
                                            1387.03753654542
                                            498.943894794211
                                            1387.03753654542
                                            555.235336592465
                                            1387.03753654542
                                            498.943894794211
                                            1387.03753654542
                                            555.235336592465
                                            1387.03753654542
                                            261012.344038505
                                            13652.9721252099
                                            1387.03753654542
                                            498.939253854332
                                            1387.04002680257
                                            555.228856580994
                                            1387.04002680257
                                            498.939382140525
                                            1387.04002680257
                                            555.228999340249
                                            1387.04002680257
                                            498.938868995756
                                            1387.04002680257
                                            555.228428303232
                                            1387.04002680257
                                            6522.12890144438
                                            11305.0324846641
                                            16957.5094865821
                                            11305.0324846641
                                            16957.5094865821
                                            18109.752711948
                                            201171.422032186
                                            165547.943793187
                                            Btw vanman - your SketchUp file is 8 MB because the texture you used is 8MB JPG - 4096x4096 pixels. The very max SketchUp will display is 2048x2048 if you enable large textures.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 16 / 19
