    [Plugin] UV Toolkit
    377 Posts 86 Posters 376.4k Views 86 Watching
      Assuming you do have a case-sensitive OS...
      A 'patch' means writing a [Ruby] tool that searches through all of the .rb files in the Plugins and Tools folders [and all subfolders] and finding if there is any capitalization of 'required/loaded' files - for example 'Sketchup.rb' and making it 'sketchup.rb' as the file is actually named. That's a lot of work... AND you can't redo any .rbs files as they are compiled and any capitalization issues are thereby 'hardcoded'.
      Alternatively find what the problem files are and make suitably capitalized versions in the same folders, so for example if a script says 'Sketchup.rb' make a duplicate copy of the Tools folder's 'sketchup.rb' named in the alternative way with a capital 'S', in the same folder - your OS being case-sensitive will allow this.
      This means duplicating a relatively few .rb files [most of these are Sketchup's installed system ones]. The downside of this is when you next install a Sketchup update some of its system files might be updated and then your 'capitalized' one are them out of date, and might cause other unexpected issues - this is unlikely within a version, but beyond a simple Maintenance release might change some files subtly... If you do this then keep a record of what you've duplicated with different capitalization and after an update check for changes and repeat as necessary...
      Examples might be:
      sketchup.rb >> Sketchup.rb
      gettingstarted.strings >> GettingStarted.strings
      etc
      The folders to look in are Tools, and perhaps Plugins...
      Any remaining error messages should give clues...
      I'm unsure what's 'broken' in my Extrusion tools perhaps post the errors in the tools thread to keep this under control...
      IF you don't have a case-sensitive OS - be thankful!
      Post screen-shots showing what's in the Plugins folder etc - I still suspect you haven't got some files inside the right folders - this can throw out the loading of other scripts too... so let's address each error as it arises, because it might fix other 'innocent' things...
        sepo
        OK I will post the error from the extrude tools in the right thread.
          sepo
          load 'tt_uv_toolkit_2.rb'
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:46: warning: already initialized constant VERSION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:47: warning: already initialized constant PREF_KEY
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:48: warning: already initialized constant TITLE
          true
            This suggests to me that you have some duplicate files loading...
            One file where it ought to be and one already inside Plugins - where you have messed up an install earlier on...
            Please refer to the original tools' pages about 'what goes where'...
            Also check that nothing inside one of these tool's subfolders is also now inside the Plugins folder, e.g. if [on the of chance ๐Ÿ˜’ ] you have mis-installed files in the incorrect places earlier and you have failed to think about trying to rectifying your balls-up before restarting !
              No - I asked him to do that after SU had started. Those warning are there because the constants where defined when SU started. I was hoping that manually reloading would give me a full call stack trace... alas...
                Alack!
                I'm sure there's a simple explanation to how he's balls-up this all up...
                I'm sure its PEBKAC...
                  sepo
                  If I remove UV tools and lib.. I do not have problem.
                    sepo
                    I have reinstalled the tools and lib....and same error appears.
                      If you install it via this utility?
                      http://forums.sketchucation.com/viewtopic.php?t=42315#p375454
                        @sepo said:
                        Hi Thomas
                        I am trying to install your plugin on my Imac and it is posting this error.
                        Plugins/TT_UV_Toolkit/loader.rb
                        > can't convert nil into StringError Loading File tt_uv_toolkit_2.rb
                        The error message actually included this string "Plugins/TT_UV_Toolkit/loader.rb" ?
                        What if you type in the Ruby Console: load 'TT_UV_Toolkit/loader.rb' - what messages do you get then?
                        Can we see a screenshot of your Plugins folder? (Please include the whole Finder window)
                          sepo
                          you can see plugin folder and SU folder here
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=25362&start=300
                          I will try the ruby console when I get back home.
                          thanks for looking into this.
                            sepo
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;27; warning; already initialized constant BB_LEFT_FRONT_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;28; warning; already initialized constant BB_RIGHT_FRONT_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;29; warning; already initialized constant BB_LEFT_BACK_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;30; warning; already initialized constant BB_RIGHT_BACK_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;31; warning; already initialized constant BB_LEFT_FRONT_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;32; warning; already initialized constant BB_RIGHT_FRONT_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;33; warning; already initialized constant BB_LEFT_BACK_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;34; warning; already initialized constant BB_RIGHT_BACK_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;36; warning; already initialized constant BB_CENTER_FRONT_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;37; warning; already initialized constant BB_CENTER_BACK_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;38; warning; already initialized constant BB_CENTER_FRONT_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;39; warning; already initialized constant BB_CENTER_BACK_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;41; warning; already initialized constant BB_LEFT_CENTER_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;42; warning; already initialized constant BB_LEFT_CENTER_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;43; warning; already initialized constant BB_RIGHT_CENTER_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;44; warning; already initialized constant BB_RIGHT_CENTER_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;46; warning; already initialized constant BB_LEFT_FRONT_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;47; warning; already initialized constant BB_RIGHT_FRONT_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;48; warning; already initialized constant BB_LEFT_BACK_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;49; warning; already initialized constant BB_RIGHT_BACK_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;51; warning; already initialized constant BB_LEFT_CENTER_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;52; warning; already initialized constant BB_RIGHT_CENTER_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;53; warning; already initialized constant BB_CENTER_FRONT_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;54; warning; already initialized constant BB_CENTER_BACK_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;55; warning; already initialized constant BB_CENTER_CENTER_TOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;56; warning; already initialized constant BB_CENTER_CENTER_BOTTOM
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;58; warning; already initialized constant BB_CENTER_CENTER_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;59; warning; already initialized constant BB_CENTER
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;64; warning; already initialized constant MB_ICONHAND
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;65; warning; already initialized constant MB_ICONSTOP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;66; warning; already initialized constant MB_ICONERROR
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;67; warning; already initialized constant MB_ICONQUESTION
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;68; warning; already initialized constant MB_ICONEXCLAMATION
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;69; warning; already initialized constant MB_ICONWARNING
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;70; warning; already initialized constant MB_ICONASTERISK
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;71; warning; already initialized constant MB_ICONINFORMATION
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;72; warning; already initialized constant MB_ICON_NONE
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;74; warning; already initialized constant MB_DEFBUTTON1
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;75; warning; already initialized constant MB_DEFBUTTON2
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;76; warning; already initialized constant MB_DEFBUTTON3
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;77; warning; already initialized constant MB_DEFBUTTON4
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;82; warning; already initialized constant MESH_SHARP
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;83; warning; already initialized constant MESH_SOFT
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;84; warning; already initialized constant MESH_SMOOTH
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;85; warning; already initialized constant MESH_SOFT_SMOOTH
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;90; warning; already initialized constant POINT_OPEN_SQUARE
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;91; warning; already initialized constant POINT_FILLED_SQUARE
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;92; warning; already initialized constant POINT_CROSS
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;93; warning; already initialized constant POINT_X
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;94; warning; already initialized constant POINT_STAR
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;95; warning; already initialized constant POINT_OPEN_TRIANGLE
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;96; warning; already initialized constant POINT_FILLED_TRIANGLE
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;108; warning; already initialized constant VERSION
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;112; warning; already initialized constant PREF_KEY
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;16; warning; already initialized constant PLATFORM_IS_OSX
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;19; warning; already initialized constant PLATFORM_IS_WINDOWS
                            Error; #<TypeError; /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;22;in `expand_path'; can't convert nil into String>
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb;34
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/win32.rb;9;in `require'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/debug.rb;9;in `require'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;400;in `require'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;399;in `each'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb;34;in `require'
                            (eval);155;in `load'
                            (eval);155
                              sepo
                              after installing in this way it posts same error
                              Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb
                                huh!.... appear to be no temp path set in the environment variables...
                                Type this into the Ruby Console:
                                ENV.each { |k,v| puts "#{k.inspect} : #{v.inspect}" }; nil
                                  sepo
                                  "PATH" : "/usr/bin:/bin:/usr/sbin:/sbin"
                                  "DISPLAY" : "/tmp/launch-MHvctR/org.x:0"
                                  "SSH_AUTH_SOCK" : "/tmp/launch-Vm9A84/Listeners"
                                  "Apple_Ubiquity_Message" : "/tmp/launch-bpbd2b/Apple_Ubiquity_Message"
                                  "Apple_PubSub_Socket_Render" : "/tmp/launch-33EI0M/Render"
                                  "COMMAND_MODE" : "unix2003"
                                  "IG_ROOT" : "/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"
                                  nil
                                    My suspicion is confirmed.
                                    But I don't understand - it gives no info about where the system temp path should be. ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜•
                                    Exactly what OS do you have?
                                      sepo
                                      Lion 10.7.4
                                        sepo
                                        Could it be because it is installed in the root? just guess.
                                          When you installed Sketchup did you accept the default folder location ?
                                          The ENV variable should contain lots of data - like your user-paths, temp/tmp folders etc...
                                            I have no idea. I'm not that familiar with OSX - but this is the first time anyone ever reported an issue like this. I've also never seen a complete lack of environment variables... ๐Ÿ˜•
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 16 / 19
