    [Plugin] UV Toolkit
    377 Posts 86 Posters 398.6k Views 86 Watching
      sepo
      OK I will post the error from the extrude tools in the right thread.
        sepo
        load 'tt_uv_toolkit_2.rb'
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:46: warning: already initialized constant VERSION
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:47: warning: already initialized constant PREF_KEY
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_uv_toolkit_2.rb:48: warning: already initialized constant TITLE
        true
          This suggests to me that you have some duplicate files loading...
          One file where it ought to be and one already inside Plugins - where you have messed up an install earlier on...
          Please refer to the original tools' pages about 'what goes where'...
          Also check that nothing inside one of these tool's subfolders is also now inside the Plugins folder, e.g. if [on the of chance ๐Ÿ˜’ ] you have mis-installed files in the incorrect places earlier and you have failed to think about trying to rectifying your balls-up before restarting !
            No - I asked him to do that after SU had started. Those warning are there because the constants where defined when SU started. I was hoping that manually reloading would give me a full call stack trace... alas...
              Alack!
              I'm sure there's a simple explanation to how he's balls-up this all up...
              I'm sure its PEBKAC...
                sepo
                If I remove UV tools and lib.. I do not have problem.
                  sepo
                  I have reinstalled the tools and lib....and same error appears.
                    If you install it via this utility?
                    http://forums.sketchucation.com/viewtopic.php?t=42315#p375454
                      @sepo said:
                      Hi Thomas
                      I am trying to install your plugin on my Imac and it is posting this error.
                      Plugins/TT_UV_Toolkit/loader.rb
                      > can't convert nil into StringError Loading File tt_uv_toolkit_2.rb
                      The error message actually included this string "Plugins/TT_UV_Toolkit/loader.rb" ?
                      What if you type in the Ruby Console: load 'TT_UV_Toolkit/loader.rb' - what messages do you get then?
                      Can we see a screenshot of your Plugins folder? (Please include the whole Finder window)
                        sepo
                        you can see plugin folder and SU folder here
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=25362&start=300
                        I will try the ruby console when I get back home.
                        thanks for looking into this.
                          sepo
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;27; warning; already initialized constant BB_LEFT_FRONT_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;28; warning; already initialized constant BB_RIGHT_FRONT_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;29; warning; already initialized constant BB_LEFT_BACK_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;30; warning; already initialized constant BB_RIGHT_BACK_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;31; warning; already initialized constant BB_LEFT_FRONT_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;32; warning; already initialized constant BB_RIGHT_FRONT_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;33; warning; already initialized constant BB_LEFT_BACK_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;34; warning; already initialized constant BB_RIGHT_BACK_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;36; warning; already initialized constant BB_CENTER_FRONT_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;37; warning; already initialized constant BB_CENTER_BACK_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;38; warning; already initialized constant BB_CENTER_FRONT_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;39; warning; already initialized constant BB_CENTER_BACK_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;41; warning; already initialized constant BB_LEFT_CENTER_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;42; warning; already initialized constant BB_LEFT_CENTER_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;43; warning; already initialized constant BB_RIGHT_CENTER_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;44; warning; already initialized constant BB_RIGHT_CENTER_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;46; warning; already initialized constant BB_LEFT_FRONT_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;47; warning; already initialized constant BB_RIGHT_FRONT_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;48; warning; already initialized constant BB_LEFT_BACK_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;49; warning; already initialized constant BB_RIGHT_BACK_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;51; warning; already initialized constant BB_LEFT_CENTER_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;52; warning; already initialized constant BB_RIGHT_CENTER_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;53; warning; already initialized constant BB_CENTER_FRONT_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;54; warning; already initialized constant BB_CENTER_BACK_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;55; warning; already initialized constant BB_CENTER_CENTER_TOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;56; warning; already initialized constant BB_CENTER_CENTER_BOTTOM
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;58; warning; already initialized constant BB_CENTER_CENTER_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;59; warning; already initialized constant BB_CENTER
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;64; warning; already initialized constant MB_ICONHAND
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;65; warning; already initialized constant MB_ICONSTOP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;66; warning; already initialized constant MB_ICONERROR
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;67; warning; already initialized constant MB_ICONQUESTION
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;68; warning; already initialized constant MB_ICONEXCLAMATION
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;69; warning; already initialized constant MB_ICONWARNING
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;70; warning; already initialized constant MB_ICONASTERISK
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;71; warning; already initialized constant MB_ICONINFORMATION
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;72; warning; already initialized constant MB_ICON_NONE
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;74; warning; already initialized constant MB_DEFBUTTON1
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;75; warning; already initialized constant MB_DEFBUTTON2
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;76; warning; already initialized constant MB_DEFBUTTON3
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;77; warning; already initialized constant MB_DEFBUTTON4
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;82; warning; already initialized constant MESH_SHARP
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;83; warning; already initialized constant MESH_SOFT
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;84; warning; already initialized constant MESH_SMOOTH
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;85; warning; already initialized constant MESH_SOFT_SMOOTH
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;90; warning; already initialized constant POINT_OPEN_SQUARE
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;91; warning; already initialized constant POINT_FILLED_SQUARE
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;92; warning; already initialized constant POINT_CROSS
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;93; warning; already initialized constant POINT_X
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;94; warning; already initialized constant POINT_STAR
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;95; warning; already initialized constant POINT_OPEN_TRIANGLE
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;96; warning; already initialized constant POINT_FILLED_TRIANGLE
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;108; warning; already initialized constant VERSION
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;112; warning; already initialized constant PREF_KEY
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;16; warning; already initialized constant PLATFORM_IS_OSX
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;19; warning; already initialized constant PLATFORM_IS_WINDOWS
                          Error; #<TypeError; /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb;22;in `expand_path'; can't convert nil into String>
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb;34
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/win32.rb;9;in `require'
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/debug.rb;9;in `require'
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;400;in `require'
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb;399;in `each'
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb;34;in `require'
                          (eval);155;in `load'
                          (eval);155
                            sepo
                            after installing in this way it posts same error
                            Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb
                              huh!.... appear to be no temp path set in the environment variables...
                              Type this into the Ruby Console:
                              ENV.each { |k,v| puts "#{k.inspect} : #{v.inspect}" }; nil
                                sepo
                                "PATH" : "/usr/bin:/bin:/usr/sbin:/sbin"
                                "DISPLAY" : "/tmp/launch-MHvctR/org.x:0"
                                "SSH_AUTH_SOCK" : "/tmp/launch-Vm9A84/Listeners"
                                "Apple_Ubiquity_Message" : "/tmp/launch-bpbd2b/Apple_Ubiquity_Message"
                                "Apple_PubSub_Socket_Render" : "/tmp/launch-33EI0M/Render"
                                "COMMAND_MODE" : "unix2003"
                                "IG_ROOT" : "/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"
                                nil
                                  My suspicion is confirmed.
                                  But I don't understand - it gives no info about where the system temp path should be. ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜•
                                  Exactly what OS do you have?
                                    sepo
                                    Lion 10.7.4
                                      sepo
                                      Could it be because it is installed in the root? just guess.
                                        When you installed Sketchup did you accept the default folder location ?
                                        The ENV variable should contain lots of data - like your user-paths, temp/tmp folders etc...
                                          I have no idea. I'm not that familiar with OSX - but this is the first time anyone ever reported an issue like this. I've also never seen a complete lack of environment variables... ๐Ÿ˜•
                                            sepo
                                            Yes
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 16 / 19
