    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.5k Views 175 Watching
      There are several scripts that mess with native class/methods.
      These cause several legitimate scripts to fail, because they will illegitimately cause some methods [particularly with 'groups'] to return the wrong values.
      These include SketchyPhysics, DrivingDimensions, SunTools, MatchBox and some versions of Podium...
        publied
        i don't have many words about this plugin... only one: amazing. is listed in the 'must have list plugin'!
        ciao and tnx!
        hire me@ http://www.publied.it !
          Laudibau
          You made my day! Thank you
            camsoccer2
            Hey Tig, in the lattice tool, is it possible to have the material choices include the material layers I have created in the project instead of the generic red, green, etc.?
            Cam
              Cam
              No, not unless you recode it yourself, and then the material-list will become unmanageably long ! ...
              So make it say 'Red', then edit the group, select a 'Red' face and use the context-menu to select 'all matching material'... Then use the Materials Browser to paint what's selected with any other material you desire - either in the Model or from an external Collect. You can do something similar for the 'Glass' too...
              It's only seconds to do, and this method allows you to change to whatever you want at any time...
                sepo
                OK here is whole error string... I believe the top is relating to extrude tools.
                Error Loading File #extrusionToolbar.rb
                can't convert nil into StringError Loading File 2D#.rb
                can't convert nil into StringError Loading File __loader.rb
                uninitialized constant TraductorError Loading File arc.rb
                can't convert nil into StringError Loading File attributes.rb
                can't convert nil into StringError Loading File babelfish.rb
                can't convert nil into StringError Loading File bezier.rb
                can't convert nil into StringError Loading File binary.rb
                can't convert nil into StringError Loading File bootstrap_Curvizard.rb
                uninitialized constant Curvizard::T6Error Loading File bounds.rb
                can't convert nil into StringError Loading File color.rb
                can't convert nil into StringError Loading File core.rb
                can't convert nil into StringError Loading File cursor.rb
                can't convert nil into StringError Loading File CurvizardAlgo.rb
                uninitialized constant Curvizard::T6Error Loading File CurvizardTool.rb
                uninitialized constant Curvizard::T6Error Loading File debug.rb
                can't convert nil into StringError Loading File definition.rb
                can't convert nil into StringError Loading File dimension.rb
                can't convert nil into StringError Loading File edges.rb
                can't convert nil into StringError Loading File entities.rb
                can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/examples/exampleScripts.rb
                undefined method file_loaded?' for main:ObjectError Loading File examples.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByEdges.rb
                undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByFace.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByFaces.rb
                undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByLathe.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByLoft.rb
                undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByOffset.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByRails.rb
                undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByRailsByFace.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByRailsToLattice.rb
                undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByVector.rb undefined method file_loaded?' for main:ObjectError Loading File extrudeEdgesByVectorToObject.rb
                undefined method file_loaded?' for main:ObjectError Loading File faces.rb can't convert nil into StringError Loading File FredoTools.rb uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb
                undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb
                undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb
                undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReverseOrientFaces.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb
                undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ThruPaint.rb undefined method register_plug' for FredoTools:ModuleError Loading File geom3d.rb
                can't convert nil into StringError Loading File gizmo_manipulator.rb
                can't convert nil into StringError Loading File gui.rb
                can't convert nil into StringError Loading File image.rb
                can't convert nil into StringError Loading File Image2Model.rb
                undefined method file_loaded?' for main:ObjectError Loading File inputbox.rb can't convert nil into StringError Loading File instance.rb can't convert nil into StringError Loading File javascript.rb can't convert nil into StringError Loading File json.rb can't convert nil into StringError Loading File locale.rb can't convert nil into StringError Loading File materials.rb can't convert nil into StringError Loading File Mirror.rb undefined method file_loaded?' for main:ObjectError Loading File modal_wrapper.rb
                can't convert nil into StringError Loading File model.rb
                can't convert nil into StringError Loading File point3d.rb
                can't convert nil into StringError Loading File point3d_ex.rb
                can't convert nil into StringError Loading File progressbar.rb
                can't convert nil into StringError Loading File ray.rb
                can't convert nil into StringError Loading File SectionCutFace.rb
                undefined method file_loaded?' for main:ObjectError Loading File selection.rb can't convert nil into StringError Loading File settings.rb can't convert nil into StringError Loading File simpletask.rb can't convert nil into StringError Loading File system.rb can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TheaExporter_files/loader.rb undefined method file_loaded?' for SU2TH:ModuleError Loading File TheaExporter_loader.rb
                undefined method file_loaded?' for SU2TH:ModuleError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TIG-Superdrape/TIG-Superdrape.rb undefined method file_loaded?' for TIG:ModuleError Loading File TIG-Superdrape.rb
                undefined method file_loaded?' for TIG:ModuleError Loading File toolbarwindow.rb can't convert nil into StringError Loading File toolwindow.rb can't convert nil into StringError Loading File tt_cleanup.rb can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_UV_Toolkit/loader.rb can't convert nil into StringError Loading File tt_uv_toolkit_2.rb undefined method file_loaded' for main:ObjectError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Utilities/utilitiesTools.rb
                undefined method add_separator_to_menu' for main:ObjectError Loading File utilities.rb undefined method add_separator_to_menu' for main:ObjectError Loading File uv_plane.rb
                can't convert nil into StringError Loading File uvq.rb
                can't convert nil into StringError Loading File version.rb
                can't convert nil into StringError Loading File webdialog_patch.rb
                undefined method is_osx?' for TT::System:ModuleError Loading File win32.rb can't convert nil into StringError Loading File window.rb can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Tools/AdvancedCameraTools/actloader.rb undefined method add_separator_to_menu' for FSCameraData:ModuleError Loading File advancedcameratools.rb
                undefined method add_separator_to_menu' for FSCameraData:ModuleError Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Tools/Sandbox/SandboxMenus.rb undefined method add_separator_to_menu' for main:ObjectError Loading File sandboxtools.rb
                undefined method `add_separator_to_menu' for main:Object
                  sepo
                  Should I attempt to have clean install of SketchUp?
                    sepo
                    OK... guess I was wrong... after clean install I have now ruby console. I will now first install thea and twilight and do one plugin in time and see.
                      Good idea... πŸ˜’
                      A screen-shot of your Tools & Plugins folder will help if you continue to have problems...
                      Check that you haven't [re]installed any old 'toolbar' compilations etc that might put old versions of 'system files' into Plugins when they should only ever be in Tools - e.g. 'sketchup.rb' ...
                        sepo
                        I have found the culprit which triggered all this problems. It is solar north extension.
                        Now I have Ruby Console and plugins so far installed are all loading without error.... β˜€
                          I wonder how the Solar North extension could cause all that?
                            Are you sure it's called Solar-North??
                            There was a known rogue script called something like Solar-Position...
                            That might have messed with the system-file Solar-North that has NO KNOWN issues πŸ˜’
                            Can you please post a screen-shot of your problem folders............ you make it doubly difficult for us to help when you don't help us...
                            We try to help... but the help goes to those that help themselves...
                            [missing out a 'God' reference there - as the more astute of you might have spotted...]
                            This lack of common-sense seems endemic πŸ˜’
                              sepo
                              I did not have any other plugins bar Twilight and Thea. Now everything looks fine apart from UV tools.
                                sepo
                                and here is SU folder
                                • panixiaP Offline
                                  panixia
                                  i remember i had some trouble using solar north about a year ago. it caused bugsplats every time i tried to use it.. so i don't try to use it anymore..
                                    The Extrusion tools are 11 in number - you have managed to get an extra blank first button πŸ˜’ What does it do if you press it ?
                                    This suggests something is [mis]loading twice ???
                                    • wind-borneW Offline
                                      wind-borne
                                      this toolbar behavior on Mac was discussed at length early in the thread when there were only a few tools πŸ˜•
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                                      %(#BF80BF)[SU 8 pro
                                        sepo
                                        It does nothing
                                          As mentioned in earlier threads, try changing it from a horizontal to a vertical toolbar arrange.
                                          Close and restart Sketchup and set the toolbar back to horizontal - the extra button should disappear - it seems to be a MAC only occasional glitch πŸ˜•
                                          The code makes an empty toolbar and adds the various tools onto it one at a time.
                                          Somehow on a MAC if the bar is horizontal it decides it needs an empty button, before the real buttons are made - however, flipping it vertical, restarting and making it horizontal again removes this oddity... Most MAC users and all PC users never get this happening... πŸ˜’
                                            sepo
                                            OK thanks ... I will try that when I get back home.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 31
                                            • 32
                                            • 16 / 32
