    Guidelines
    27 Posts 6 Posters 1.9k Views 6 Watching
      rumcajs
      Does Sketchup use guidelines? Often I have a need to make some line just for help, to remember position o point or line.
      • massimoM Offline
        massimo Moderator
        http://support.google.com/sketchup/?hl=en
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95005&topic=2458211&ctx=topic
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95007&topic=2458211&ctx=topic
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95009&topic=2458211&ctx=topic
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95010&topic=2458211&ctx=topic
          rumcajs
          OK, but what if I want to place a guide line onto top of cone? To describe the level or position on y axis.
          • massimoM Offline
            massimo Moderator
              rumcajs
              The left one.
                Have you even attempted to put in a guideline with the Tape Measure tool?
                  rumcajs
                  Yes. I've learned to make guideline going out of line. But in this special case the line does not go out of the lines leading to top of the cone.
                  • massimoM Offline
                    massimo Moderator
                    The left one.
                    1. Pick the tape measure tool;
                    2. Left click on the tip of the cone;
                    3. Move the cursor away from the tip in any direction then press the left arrow key (green axis) in order to force the inference along that axis. You should have something like the picture below;
                    4. Left click again anywere.
                      rumcajs
                      Thanks it works. I wonder why it did not work before.
                        If you want a guideline as shown on the left in Massimo's example, you could do it this way.
                        Click on the image for animation.
                        • massimoM Offline
                          massimo Moderator
                          Sure, like that it would be even simpler. πŸ‘
                            rumcajs
                            I see, so I need to have two axis to create crossing point. Thx
                              You need two lines to create a crossing point. One line, by definition won't ever cross itself. You can create a crossing point (also known as an intersection with two crossing guidelines, two edges, an edge and a guideline or an axis line and a guideline....
                                rumcajs
                                That's what I wrote, that I took two axis.
                                  raineysky
                                  Wow Dave!!! Always learning something from you to make working with Sketchup easier and faster. Thank You πŸ‘
                                  Paul
                                    rumcajs
                                    How can I move the guide line? Also how can I draw make parallel guide to a guide. I have drawn guide according red axis and now I want to either move it or just copy it and move or to draw a parallel guide, which will be in the same level as the original guide.
                                      To relocate a guideline...
                                      Select it and then use the Move tool.
                                      Pick the first point on the guideline itself, then a point on something else - the 'target' edge/face.
                                      Constrain its movement to be axial using the shift key if needed.
                                      Because a guideline is infinitely long it's easier than moving 'geometry where you will often want 'ends' to match up...
                                      OR probably even easier... delete the misplaced guideline and make a new one in the desired location...
                                      It's not black-magic... πŸ˜’
                                        rumcajs
                                        I believed that I have to select it and use move tool, but I was not succesfull to select it. I think the problem is that it was a part of group or what? I triple click to object to open it and edit... then. OK, done. Thanks.
                                          rumcajs
                                          Hm, that is what I was not successful to do. It is harder to describe without image
                                          http://i48.tinypic.com/307rtz6.png
                                          (The side side of the castle is not parallel to green x axis. And I could not to do it like in the post,
                                          massimo on Fri Aug 31, 2012 1:56 pm
                                          coz the guide would be not be parallel to green axis (it would intersect the green axis and then go to the point = not parallel).
                                            Why don't you put the castle on the ground plane? πŸ˜’
